I built a workbench out of maple some years ago. Basically 30" x 60", 1 5/8" thick top, on a frame. I had the wood milled to size and put it together in my apartment without any power tools. You really need a bench to make a bench :-) Overall it worked out very well over the years. Some pictures below.
I am in the process of upgrading it. Just ordered a 24"
Twin Turbo Vice from Andrew Klein. Been following this for a while and seem pretty cool. With some modifications to the bench top, this will fit on the end of the bench. I plan to add some bench dogs to the vice and top.
Before I add the vice, I want to level the top. It's little off in places, but not consistently. I have thought of several approaches on how to do this and wanted your feedback. I was thinking of:
1) Level it by hand using hand planes. This probably requires the most skill and physical work, but will result in the least about of wood removed.
2) Build a router sled jig and use a router. I have a pair of long straight rails (TrackTubes) that can be used for this, need to make the sled, get a flattening bit, etc.
3) Use my TS75 and rip it apart at the glue joints, bring it to the jointer/planner to join edges and flatten each section, then use dominos and glue it back together. The will probably result in the biggest loss of wood thickness.
I would appreciate your feed back on these possibilities, or something I didn't think of.
Bob
