@neilc thanks!
@Svar you could totally make your own, too. I think the benefits are:
1) It's a well thought-out design with accessories that Rob sells that work extremely well with it
2) It supports a small business who really cares about woodworkers
3) Rob is a great guy and worked with me on making custom components to fit my existing bench
4) You'd benefit from future accessories or innovations that Rob does
All of the standard Festool clamps, dogs etc etc work perfectly in it.
@MrToolJunkie yeah!
@Crazyraceguy thanks!!
@MikeGE that's a great questions. I'm not sure. I'll try to measure it when I get down to the shop for you. I suspect that the distance between the dogs from bench to bench isn't the same as it is within one bench.
@squall_line yeah I think you're spot on with your answer there. Hahahah. thanks. I swear I do have sawdust like everyone else, I just clean it up!
@Cheese thanks man! Sort of yes and no. It's honestly just a walnut dowel that I have screwed onto a 90 degree bracket from 8020. It literally just holds the 1 ft. section of 27mm hose for me so it isn't sitting on the bench. I use that short piece with my sander and domino, and the 36mm on the boom arm for the track saw and router.
@vkumar thanks man! I gave the 3 MFTs to a great for free. Sorry!
Matt
