To start with, I hate crawling around on the floor, that said, I avoid cutting crawling around on the floor.
As Hans stated, we cut a lot of sheet goods, 2 bunks of 3/4, 30 sheets of half and 6 sheets of 3/4x10’ in the last 10 days. All of the sheet goods are cabinet grade.
A thread showing my cutting table, we now use two.
https://www.festoolownersgroup.com/festool-jigs-tool-enhancements/cuttingwork-table/msg342316/#msg342316As you can see, I cut on foam.
There is a thread on here somewhere with the cut list/sheet attached. I can’t find it right now.
If you do not want to make a table consider a Centipede;
https://boratool.com/work-stands/centipede-work-supportsFestool is doing a limited release for their cutting table, I need to order one before the deadline. Another option to consider.
Cutting on foam allows you to cut/rip solid wood also. Cutting on foam increases dust collection.
Take the time to learn the saw, practice on scrapes when you get a chance. Imagine a cut, you’ll figure out how to do it with the track saw. I have yet to run across a cut I could make with a little thought and planning.
I also have 8 MFT 3’s. Look for used one, hopefully one will come your way.
FULL DISCLOSURE———I test TSO products!!!!
Get the TSO rail square at a minimum, the GRS 16PE. You can add to the system as needs arise.
A simple cut just to show a few of the things you have to consider;
The diamond on the end of this island the joints are mitered. The obtuse angles were ripped using the TS 55, the angle is ~117° If I recall correctly.
