« Reply #14 on: March 29, 2015, 02:11 AM »
Hi there,
I too was inspired by wing79.
I copied his "four feet" shelving system. It works well.
The systainers lock in and they don't fall out even in windy roads.
To make them I simply placed a systainer on a pre sized pc of shelving. (16"x12")
First centered it then I used and engineers square to mark out feet location on shelf.
Then I connected my lines with a framing square. I drilled a through hole in each square and cut them out with a jig saw. Then I just clamped this jig on top of my shelf blanks and plunge routed each indent. I used a short top bearing 3/4 template bit. It took less than s minute per shelf. I think went to a depth of about 8 mms. I left the round corners on the indents DNS the systainers drop in perfectly with s nice "positive stop" feel.
I then cut out the front indent out of my template with a jigsaw. Again I clamped this on top of each blank and routed each front with a large top bearing template bit. Again each cut took only a minute. Thsnks for the inspiration fellow foggers!
Ts55, Ct36, of1400,Domino xl700, Trion ps300, Abrasives Sys2, various guides,rails 1 1400, 2 1400 holy, 2 connector sets, ETS 150(3),compact cleaning set,
Sys 1 toolbox(for router bits),Sys storage systainer (2),lr32 kit, sys4 tool box(holds veritas mk11 sharpening system),mft/3,Rotex 150,Tanos sys2/with attic,sys2 with fein tool insert,sys midi2(2)sys midi3,csx installer kit, rts 400, conturo edge bander, edge trimming kit, mfk700
