Author Topic: T-loc Track saw rail wall mounts  (Read 6259 times)
Offline StanB
« on: March 20, 2016, 12:35 AM »
Had a little time today so I made some track saw rail wall mounts.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM S ET | MX 1200 E MIXER | DF700 XL | PDC 18 | TID 18 | ConuoroKA 65  | Kapex KS120 REB | MFK700| RTSC 400 | LS 130 EQ
Offline SRSemenza
Re: T-loc Track saw rail wall mounts
« Reply #1 on: March 20, 2016, 12:37 AM »
Slick idea!  How are the T-Locs attached?
Offline StanB
« Reply #2 on: March 20, 2016, 09:25 AM »
The construction of the block is 6 mm ply laminated to 19mm birch for the lock section. The tloc is attached with a 1/2" hole with a counterbore from the back side to the thickness of the tang to the pivot surface of the tloc. That was it "clicks" in.
« Reply #3 on: March 20, 2016, 09:26 AM »
Lots of ways of making a swing lock but the T-locs work great with the theme, nice job
Offline Alan m
« Reply #4 on: March 20, 2016, 10:40 AM »
great idea
. I think festool or one of the after market guys should make these.
I think you should be banned (or at least severe retraining ) for not making the t locs festool green
« Reply #5 on: March 20, 2016, 11:41 AM »
Nice idea mate
Lots of the green stuff :))
Offline rst
« Reply #6 on: March 20, 2016, 02:33 PM »
I did something similar with the foam cradles that held my 118" rail in the packaging.  I taped the foam to aluminum j-hooks that I made from aluminum flat stock and hung them from my suspended ceiling.
Offline fritter63
« Reply #7 on: March 20, 2016, 06:52 PM »
I have a bunch of spare t-loc catches if anyone needs them. Pm me.
Offline Kev
« Reply #8 on: March 20, 2016, 09:03 PM »
Just curious ... Why not make it with a functioning T-Loc at the bottom ?
Offline StanB
« Reply #9 on: March 21, 2016, 12:17 AM »
For ease of access? I could see it done that way.
Offline TSO Products
    • TSO Products
« Reply #10 on: March 23, 2016, 05:34 PM »
while you're at it - simplitying this good idea: how about a single t-loc? the guide rail is not going anywhere once it stands on edge :)
TSOproducts.com
Offline EA Custom Millwork
    • www.eacustommillwork.com
« Reply #11 on: March 27, 2016, 08:19 AM »
Is that an after-market sleeve on the vac hose?
Offline StanB
« Reply #12 on: March 27, 2016, 09:23 AM »
It's 1.25" PET cable sleeve from cableorganizer.com I also just put on some heat shrink on the ends.
