Author Topic: Sys-bicycle-mft  (Read 5855 times)
Offline Beemers
Sys-bicycle-mft
« on: March 09, 2016, 02:05 AM »
Here in Amsterdam (The Netherlands) is getting around by bike much faster and cheaper than by car. So I came up with this: combination of a mft lp-800 plate and some t-tracks.
Maby usefull idea for others who work in congested cities.
Cheers
Beemers
Offline Kev
Re: Sys-bicycle-mft
« Reply #1 on: March 09, 2016, 06:31 AM »
I'm a little disappointed that the front wheel doesn't convert to a saw blade that rises up through the table [eek] [big grin]
Sydney hills would see you needing pedelec!!
Great idea. Did you waterproof the MDF?
@Beemers
Offline neeleman
Re: Sys-bicycle-mft
« Reply #2 on: March 09, 2016, 06:53 AM »
Looks nice although I'm not sure the systainers will stay in place when turning corners or riding over bumps.
The wooden side plates will not prevent the systainer from sliding, especially on the corners.
Or maybe they are somehow attached to the MFT plate?
Maybe you can use a few of these Tanos SYS-Connectors (#80600318)?
Festoolian since 1998.
FESTOOL:
RTSC400Li | CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1010 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
Offline Beemers
Re: Sys-bicycle-mft
« Reply #3 on: March 09, 2016, 03:13 PM »
@Beemers
Good idea Kev. And power the saw by pedaling
I didn't waterproof it because it's detachable, I only use when I need al lot of Systainers or a need a baby mft. A lot of times I just use the standard frontrack.
Offline Beemers
Re: Sys-bicycle-mft
« Reply #4 on: March 09, 2016, 03:21 PM »
Yeah, I thought about those sys connectors, but I wanted a flush table top for cutting etc.
It turned out to be very stable, really, even in corners. I will stack up more Systainers next week to test it to the max. Plus  I can always secure it with a strap if needed
Ill keep you posted
Offline ear3
Re: Sys-bicycle-mft
« Reply #5 on: March 10, 2016, 01:21 AM »
Bravo.
Offline Kev
Re: Sys-bicycle-mft
« Reply #6 on: March 10, 2016, 03:04 AM »
I think we have part of the formula for an interesting triathlon event here .. bike leg sorted, the 1000m track saw cut sorts out the run. No sure what power tools I'd consider in the swim leg [scared] [eek]
Offline Charlie Mac
Re: Sys-bicycle-mft
« Reply #7 on: March 13, 2016, 08:08 PM »
That's such a cool bike. It looks like it was designed for cargo.
Offline Untidy Shop
Re: Sys-bicycle-mft
« Reply #8 on: March 13, 2016, 08:18 PM »
I think we have part of the formula for an interesting triathlon event here .. bike leg sorted, the 1000m track saw cut sorts out the run. Not sure what power tools I'd consider in the swim leg [scared] [eek]
@Kev, obviously a C15/18. See around 2 mins in the video.
Offline Kev
Re: Sys-bicycle-mft
« Reply #9 on: March 13, 2016, 10:08 PM »
They are ... and very popular with bicycle couriers in Sydney!!
@Charlie Mac
