« Reply #4 on: August 29, 2010, 10:45 PM »
You need to think about what needs each station/machine has insofar as to how it deals with the materials you will be using at it. You need things on wheels, or setup to not interfere or work with close neighbours in unison, via sharing the same work height, thus can be used to straddle material.
Here's a few shots of how I squeezed more stuff and room into an 11.5 X 21 garage shop. Note the planner on wheels that actually pulls out from under where my miter saw is. The table the miter saw sits on, can slide the whole saw back and forth so that the router table and ras on each side can each be used to support pieces straddled across any one of them. The router table is actually on a sliding stand affixed to the wall and the manufacturers stand sits about six inches off the ground. It's actually a much nicer height to work at. I hate crouching to work all the time. The drill press has a clamp storage rack that is fully removeable of the rear, and has a debris tray, its own DC, and ample storage for forstners and bits. The whole DP is also on wheels. It has to be. Plywood storage is in a cage 3 feet off the ground, and there is ample overhead storage as well. It takes a lot of thought to set up a shop correctly with limited space, and I found that scale mapping with cutouts was one of the necessities to get this done right. I can't draw for beans, nor do them on a PC, most things happen in my head, with my hands, or with scaled cutouts as a last resort.
« Last Edit: August 29, 2010, 10:57 PM by Kevin D. »
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus, Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
