Author Topic: Sleeved Centrotec bitholder  (Read 4601 times)
Offline koenbro
« on: October 01, 2018, 12:57 AM »
How can I get a sleeved Centrotech bitholder similar to this: https://smile.amazon.com/DEWALT-DW2054-4-Inch-Compact-Magnetic/dp/B0000225P8?keywords=DEWALT+DW2054&qid=1538369589&sr=8-1&ref=sr_1_1
I need to be able to stabilize the screw initially, and the sleeve that rotates freely and slides forward is very convenient. The one that came with my CXS kit neither slides nor rotates separately.
Many thanks to all.
MFT/3 • TS 55 REQ • Carvex PS420 EBQ + Accessories • OF1400 + LR32 + MFS400 • Domino DF500 • AvidProCNC 24x48" • ETS EC150/5 EQplus • DTS 400 REQplus • CXS • CT 26E • Fuji Q4 + 3M PPS
Offline Sparktrician
Re: Sleeved Centrotec bitholder
« Reply #1 on: October 01, 2018, 07:29 AM »
I've never seen what you're asking for.  Alternatively, you can use the DeWalt unit in the standard drill chuck that comes with the CXS.
- Willy -
Offline Richard/RMW
« Reply #2 on: October 01, 2018, 08:57 AM »
Another option is to grind/file the extra groove into the Dewalt bit holder to "centrotec" it.
There are a couple thread on here showing how to do this.
RMW
Online Cheese
« Reply #3 on: October 01, 2018, 10:32 AM »
If you really want and need that bit holder, I'd just Centrotec it. Some people have used a lathe while others have used a drill press. The lathe is definitely easier, however if it's only 1 bit, the drill press is fine.
http://festoolownersgroup.com/festool-jigs-tool-enhancements/centrotec-ing-standard-bits/msg518762/#msg518762
Offline RKA
« Reply #4 on: October 01, 2018, 11:26 AM »
Some of these standard 1/4" quick release shanks do fit in the centrotec chuck, they just don't lock, but there will be a friction fit..  But some don't fit at all without filing down the edges a hair.  So it's kind of hit or miss with other brands, but if you don't need it to lock and you don't want to mod it, that may be an option if you can find a store that has a few available to try on your centrotec.
-Raj
Offline JD2720
« Reply #5 on: October 01, 2018, 12:37 PM »
RMW
That is what I did. It works.
Offline dupe
« Reply #6 on: October 01, 2018, 01:11 PM »
or try the Snappy Adapters
I assume the 1/4" Drill Bit Adapter will suffice. They're made for round drill bits and come in different sizes, looking to get one for a pocket hole step bit.
MFT.1080    CT.Midi    DF.500    DTS.400    ETS.EC150/3    RO.150    RO.90    CXS 10.8    RAS.115
Offline SRSemenza
« Reply #7 on: October 01, 2018, 02:53 PM »
One thing to watch out for when "centrotecing" a bit.   I did a countersink / counterbore bit and though there was enough room on the shaft to add the groove, there was not enough additional space between the added groove and the counter sink portion to allow the bit to be inserted into the Centrotec chuck far enough to engage. Not sure but that could be problem with "centrotecing" the sleeved bit.
 @dupe  That is an interesting idea to place a 1/4" hex into a 1/4" drill bit holder as an adapter. I have one. Need to check that out today.
Offline SRSemenza
« Reply #8 on: October 01, 2018, 04:24 PM »
   [doh]  Nope doesn't work. 1/4" hex bit is 1/4" across the flats. Too big.
Offline dupe
« Reply #9 on: October 01, 2018, 05:06 PM »
hex head, round hole  [doh] [doh] [doh] good catch @SRSemenza
@koenbro Snappy has adapters from 1/8" (round) bits up to 3/8" each with +/- 0.01" clearance for setting. Take your favorite mag holder and check the diagonal.
