Author Topic: Transit Van Fit Out - GunnyR  (Read 13370 times)
Offline gunnyr
    • Compass Custom Creations
Re: Transit Van Fit Out - GunnyR
« Reply #30 on: May 11, 2021, 12:20 PM »
You guys are making me reconsider getting an f150. Will 4 by 8s fit in any transit (not Connect)? From my reading there is about 126 inches behind the seat for the short version. So it seems so.
The van gives me the ability to securely and safely carry both materials and tools.  I no longer have to crawl around in the dark trying to dig out seldom used tools.  Now I can get to all my tools without unloading half the vehicle!
Take a look at my 26 Jan post.  4x8 sheets fit easily even with the bulkhead and storage area.  10' stock fits easily the way I am configured.  Without the bulkhead I could get 16' trim in.  Mine is a 148" wheelbase but is not the extended version.
« Last Edit: May 11, 2021, 09:55 PM by gunnyr »
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|ETSC 125|DTSC 400|RO 90|RO 150|OF 1400|OF 1010|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|STL 450|DUO-SET|SYSLITE KAL II
Offline tallgrass
« Reply #31 on: May 13, 2021, 02:45 AM »
Your work, as always, top drawer. I am a mechanical engineer with a organizational sickness. Deeply screwed on this. I have no need for portability in my shop. However when I see these build outs, which are well done, I always start thinking about weight, CG and other issues with the added mass of the "built in weight" on top of the tool weight.. Is it a consideration? Does it even matter, fuel costs and so on. For example did you consider light weight materials, such as honeycomb panels instead of plywood. Much like aircraft cabin construction. This is more of a curiosity question. Considering you seem to be thorough you planning, I was wondering if it a consideration, or like most engineers, I am simply over thinking this. :)
Offline gunnyr
« Reply #32 on: May 13, 2021, 06:52 AM »
Thank you for your kind words!
I did consider the CG and weight, but only in passing.  I quickly realized I was going to end up going down yet another rabbit hole.  I took the easy path and simply compared what I was doing to what I'd seen others do, and decided I was going to be ok.  I did choose a 3/4 ton chassis as I knew I was overloaded in my 1/2 ton pick up.  What I did not do was to get a vehicle weight at delivery.  Perhaps one day I'll stop and get a current weight and use the manufactures curb weight and then see where I'm at.  I will say that the van drives better today than it did when it was empty.
I've been using the set up for 4 months now and can say that I am very pleased with the layout in general.  I keep adding to my list of things to upgrade and finalize:
  • Add a bank of drawers
  • finalize the top of the drivers side shelving
  • Improve my tie down system
  • Devise a method to transport trim, thinking something like the system that @Kevin C. has in his rig
  • Add cab lighting
  • etc, etc....
All in all, I used a very unscientific approach to the weight and weight distribution and seem to have gotten away with it at this point. [blink]
Semper Fi,
Jeff
Offline Toolman32
« Reply #33 on: June 03, 2021, 02:20 AM »
I just bought almost an identical van and starting the process of racking it out. I like the charging station. Where did you get the inverter setup?
Offline gunnyr
« Reply #34 on: June 03, 2021, 07:01 AM »
Thank you!  My goal was to provide interior lighting and charging.  I don't have enough power to run power tools, I figure if that's necessary I can bring a generator.
This is the Inverter from Amazon.  Note that I also installed a separate house battery, isolator and fuse panel to distribute the house power.  There are lots of resources for Transit camper conversion and wiring schematics available.  Check out Pinterest and the Ford Transit USA Forum
Here is my list of electric supplies and materials, it's not totally complete but includes the major components.
Semper Fi,
Jeff
Offline gunnyr
« Reply #35 on: October 16, 2021, 05:29 PM »
Drawers!
When I did the initial FitOut I knew that I wanted to include drawers in the middle bay of the curb side rack.  I wasn't sure exactly how they needed to be configured so I used Ridgid tool boxes to get started.  The Ridgid boxes are great but quickly getting tools and supplies was difficult.  Several tools were kept in the blow molded cases and some were stored behind other tools.  Now I can get to all those tools quickly and easily.
I settled on Paulk Style Drawers in two different sizes.  Several of the drawers have been fitted out for specific tools and others I have left open for the time being.
Before:
During:
After:
« Last Edit: October 16, 2021, 09:54 PM by gunnyr »
Semper Fi,
Jeff
Offline ForumMFG
« Reply #36 on: December 12, 2021, 08:13 PM »
Drawers!
Before:
(Attachment Link)
During:
(Attachment Link)
After:
(Attachment Link)   (Attachment Link)   (Attachment Link)
Can you tell me where you found your black buckle straps so your equipment doesn't come flying off the shelves?  i love that idea and i need those
Offline gunnyr
« Reply #37 on: December 12, 2021, 10:22 PM »
I used 1 inch webing, buckles and Tri Glides from Amazon to make up what I needed.
Tri Glides:
https://www.amazon.com/YGDZ-100Pcs-Plastic-Triglides-Slides/dp/B074MQCDDJ
1 Inch Webbing:
https://www.amazon.com/Strapworks-Heavyweight-Polypropylene-Webbing-Strapping/dp/B01KTVG0KI
FasTex Buckles:
https://www.amazon.com/10-Adjustable-Release-Plastic-Buckles/dp/B00DCZRLZW
I found it best to cut the webbing with red hot utility knife blade held in a pair of vise grips.
Semper Fi,
Jeff
Offline gunnyr
« Reply #38 on: December 13, 2021, 07:10 PM »
Rear Door Storage
The front left corner had become a catch-all for long objects that didn't fit any place else.  The space is mostly dead space but is primarily needed to store my ladder.  After battling (and losing) with retrieving my pry bar one too many times I finally moved much of the mess to the unused space on the rear doors.  I'm really afraid that all I've really accomplished is creating space to carry yet more 'stuff'! [embarassed]
Semper Fi,
Jeff
Offline ForumMFG
« Reply #39 on: December 14, 2021, 12:59 AM »
Do you care to go into anymore detail regarding your charging station?  I have been looking for something like what you put together for 6 months now and what you have is perfect.  I too would have 3-4 different charges but never thought out how to make it work.  So could you go into the specifics regarding the house battery, fuse, and power inverter.  I would really like to duplicate what you have.
Offline ForumMFG
« Reply #40 on: December 14, 2021, 01:03 AM »
Nevermind, i just saw one of your previous posts.  Is the house battery just for charging while the van is turned off?
Offline gunnyr
« Reply #41 on: December 14, 2021, 07:41 AM »
The house battery will provide power both when the van is running and when it's turned off.  There is an isolator between the positive terminals of the house and vehicle batteries that prevent the house battery from drawing power from the vehicle when the voltage of the vehicle battery is below 14v or so.  What this means is that power will only flow from the vehicle battery to the house battery when the vehicle is running and prevent the house battery from draining the vehicle battery.
My house battery is located under the driver's seat, along side the vehicle battery.  Note that if you have a Transit and don't need/want a house battery that Ford has provided a fuse protected 60 amp power connection point at the rear of the driver's seat.  I recommend you do a search on the Ford Transit USA Forum for more ideas about house power to your van.  You'll find references to solid grounding points that Ford has provided as well as recommendations on attachment points.
I do not have any hardwired provisions to charge the house battery with shore or solar power at this point.  What I've found is that the house battery gets sufficiently charged for my needs during normal driving.  I've also mounted my chargers and power strip on a removeable board so that I can easily take the chargers into the job site.  I've also sometimes run an extension cord out to the vehicle to plug my charging station into.  My set up is not really strong enough to charge two of the DeWalt FlexVolt batteries at the same time using the inverter.  I've really not found that to be an issue.
Semper Fi,
Jeff
Offline ForumMFG
« Reply #42 on: February 12, 2022, 01:19 PM »
Does your m12 battery ever fall out of the charger while you are driving?  Just curious if a good bump will knock it out.
Offline gunnyr
« Reply #43 on: February 12, 2022, 01:34 PM »
No, I've not had any problems with M12 batteries falling out.  The holders have held up well also.  I keep thinking I want to mount them at an angle to recoup some wall space but haven't yet gotten to it.
Semper Fi,
Jeff
