Tom, you wouldn't be willing to part with one of your extra vests for a nominal fee would you? I have the Sawstop JSS mounted in my truck which I like for the most part. How's the Mafell? Power? Weight? Why not use plywood for your roof instead of FRP, so you can attach hangers for brooms, guide rails, and ladders.
Cheers
Curt
Hi Curt!
I sent you a PM regarding who still has some of the 4294 vests in stock.
The Mafell Erika saws are amazing!!! I have the Erika 70, 120v. At 2200 watts, it has oodles of power. I particularly like it because it pairs nicely with a track saw (in my case, MT-55cc or KSS-400). I use the hand held saw to break down larger goods (plywood, for instance), then use the Erika for final dimensioning. The ability of the Erika to rip AND crosscut means I can leave my Kapex in the shop, only taking it out for crown moulding projects. With the table extensions the Erika will rip 24"+, with the sliding table I think you get roughly 36" crosscut, and you can add infinite sections of fence and stops for repeated crosscuts. At 70lbs, the saw isn't light, but I don't have a problem carrying it up or down stairs, and I installed the wheel kit so it's easy to move around once it's all set up.
For the van ceiling, the insulators sprayed the foam a little thicker than I'd like. As I have time, I've been trimming the foam back, with the ultimate goal of lining the ceiling with FRP, then running some LED lighting. I'm 74", and I think the van ceiling is 72", so I'm wary to install anything that would further reduce headroom.
