Author Topic: Sheet good handling  (Read 12689 times)
Offline dmccririe
Sheet good handling
« on: August 20, 2018, 02:09 PM »
As I get older and weaker and my back is less tolerant, I'm looking for ways to handle sheet goods without the clean and jerk.  I almost exclusively work alone, and I see a variety of carts and racks that allow you to go from vertical to horizontal to load the sheet goods onto sawhorses or table saws or whatever.   What are your experiences, pros and cons, good and bad, etc. I really don't want to build one because I have too many other projects pending.  Thanks in Advance!
Dale
Offline tjbnwi
Re: Sheet good handling
« Reply #1 on: August 20, 2018, 03:02 PM »
Offline Wooden Skye
« Reply #2 on: August 20, 2018, 03:05 PM »
The first question is how you are getting sheet goods home.  If you are using a truck, slide them right off the bed onto saw horses to break down into more manageable sizes.  If being delivered most likely they are taking off with forklift, I would have him place on saw horses.  There was also a panel lift that bolted to table saw and then could be swung up.
Bryan
TS 55, (2) 1400 Guide Rails, 1900 Guide Rail, MFT/3, Domino ETS 150/3, RO 90, CT 26, OF1400, RO 150. RTS 400, LR 32 set, PS300 jigsaw, 3 abrasive systainers, (2) sys toolbox, (2) sys mini, clamps and other accesories
Offline hdv
« Reply #3 on: August 20, 2018, 04:12 PM »
I think Wooden Skye might hint at this Gorilla's Leg Up (see https://www.gorillagripper.com/leg-up.html).
Another option (albeit Festool-like expensive!) is the FAT 300 S height adjustable working table from Felder (see https://www.felder-group.com/fg-en/products/workshop-equipment/work-table-fat-300-s.html) in combination with their panel tilting device (see the accessories section on the same page). I have had my eye on them for a while now. Need to save up first though... ;-)
Offline RDMuller
« Reply #4 on: August 20, 2018, 04:13 PM »
I have had the Crazy Horse since mid February.  Love it.
Search for a post I started late last year on this website
Offline waho6o9
    • Garage Door Handyman.com
« Reply #5 on: August 20, 2018, 09:07 PM »
284011-0
Dimension the sheet goods right off the truck as mentioned above.
I use a WalkoIV on Stanley horses and it works well, using a TS75 and a several clamps I can cut 3 sheets at a time.
Festool rocks.
Offline dmccririe
« Reply #6 on: August 22, 2018, 10:41 AM »
@Wooden Skye:  I transport the sheet goods home in my pickup but I have help loading them in and out.  When I'm in my shop, I don't typically have help and I also am cramped for space.  I have seen the crazy horse and ultimately, that may be the way I go but it will not work as well given the configuration of my shop.     Again, just looking for others ideas, experiences so I can explore what will work best for me.
Dale
Offline tomp
« Reply #7 on: August 22, 2018, 11:41 AM »
I have a knock-down grid that I made to sit on top of a pair of sawhorses. The combined height lets me slide a sheet of plywood off the back of my truck onto the grid with minimal handling. Mostly break down the sheets using a Eurekazone UEG first to rip to width and then cross-cut to length on the MFT. If there will be large panels - e.g. base cabinet ends, I use the UEG and then a track with the TRO square to cut final size without lifting anything off the grid.
284128-0
284130-1
284132-2
284126-3
The grid breaks down for storage and, as an added plus, can be used as an assembly table.
284134-4
Offline waho6o9
« Reply #8 on: August 22, 2018, 11:48 AM »
Good job on an excellent grid tomp!
Offline 3PedalMINI
    • Signature Sound & Video
« Reply #9 on: August 22, 2018, 01:41 PM »
im thinking about picking this up https://www.rockler.com/rockler-material-mate-panel-cart-and-shop-stand?sid=V9146?utm_source=google&utm_medium=cpc&utm_term=&utm_content=pla&utm_campaign=PL&gclid=EAIaIQobChMIurO805mB3QIVFVYNCh0SMApTEAQYASABEgKz3PD_BwE
Im 29 but still have a hard time dealing with the sheet goods. I just got a powermatic PM2000 saw and was thinking about this same thing. I actually think what im going todo is to get the rockler piece and modify it to use a "knockdown grid" like posted above. Slide them out of my truck and onto that then use the TS55 to break it down into more manageable pieces.
The Bitterness of poor quality remains long after the sweetness of low price is forgotten -Benjamin Franklin
Professional Custom Audio Video System Designer/Installer serving Southern - Middle NJ, Eastern PA & the Surrounding Shore Points.
www.sigsv.com
Kapex 120,TS55,RO150,ETS125,CT-26,CT-MIDI,Tradesmen Cleaning Kit, Festool Ratchet Kit, Sys-lite, Sys Roll Cart, T18 +3, 2013 Centrotec Kit, Carvex 420, Carvex Accessory Kit, CXS,RO90, TI15 and Various Festool Systainers
Offline IndyMike
« Reply #10 on: August 28, 2018, 01:47 PM »
The CrazyHorse looks awesome.
My biggest issue was taking the plywood from leaning against the wall to up and on top of my saw horses - without knocking the saw horses over.  If the horses were stuck the the floor / more sturdy it wouldn't be an issue.
That said I planned on building a grid like @tomp's and just laying it on the floor rather than on top of saw horses - which will make dropping the plywood onto it much easier.
Mike
Offline lunchman
« Reply #11 on: August 29, 2018, 08:07 AM »
I've got one of these Bora Portamate carriers -
https://www.amazon.com/Portamate-PM-1800-Carrier-Allows-Person/dp/B01AWI8ILW
The verdict: Meh.
It performs as intended, but at times can be a bit unwieldy when loading. The leg needs to be folded out and if you don't quite get the plywood centered when first loading, the unit can get tippy.  It's also necessary to set the height prior to loading as doing so afterwards is difficult.
Once loaded though, it does make it easy to move sheets around. I've loaded 3/4 ply on it with no weight issues. When I was breaking down sheet goods on foam on my workbench it was quite useful to get it at the right height. Now that I use a lower track saw cutting station on saw horses it's easier to manage the sheets without it.
Offline ChuckS
« Reply #12 on: August 29, 2018, 10:57 AM »
I have had no experience with the Bora panel carrier. Did you see the improvement measures suggested by the reviewer J. Kinney (May 21, 2017)?
Offline IndyMike
« Reply #13 on: August 29, 2018, 11:00 AM »
Have a link?
I'm looking at getting something myself to help me manage 3/4" sheet goods myself.  The GF doesn't mind helping but she's tiny and 3/4" hardwood ply is heavy :).
Mike
Offline ChuckS
« Reply #14 on: August 29, 2018, 11:02 AM »
Offline IndyMike
« Reply #15 on: August 29, 2018, 11:03 AM »
The Rockler cart looks solid. Unfortunately, my shop won't have room for it, unlike the Bora panel carrier that can lead on a wall.
That's one of my issues too - I'm running out of places to store things.  I'm turning to the ceiling soon.  Pulleys and rope :P.
Mike
Offline ChuckS
« Reply #16 on: August 29, 2018, 11:21 AM »
Have a link?
https://www.amazon.com/Portamate-PM-1800-Carrier-Allows-Person/dp/B01AWI8ILW#customerReviews
The first comment with photos, too.
Offline lunchman
« Reply #17 on: August 29, 2018, 11:54 AM »
Yeah, I came across that review with the user mods to the Bora Portamate just this morning, will have to look into it.
I hope I didn't give the impression of a thumbs down, buy something else. The cart is useful, it's reasonably priced, will easily carry a 3/4" 4x8 sheet of ply and it does store in a compact footprint. Perhaps the mods made by that reviewer will help with some of the issues I've run into.
I'm in my 60s so wielding sheets of ply out of my truck bed isn't as easy as it once was. I think my initial intent was to set the unit up in its horizontal position to attempt sliding the sheet out onto it, which wasn't overly successful.
-Dom
Offline sprior
« Reply #18 on: August 29, 2018, 12:03 PM »
Not being a pro I've got a few extra challenges in material handling.  My shop is in my basement accessed via a bulkhead door/steps (at the other end of the house from my driveway), so the first challenge is to get the plywood from the garage to the top of the bulkhead steps.  Next is getting it down the steps and onto my wood rack.  Then when I want to use it get it from the rack to the next room up onto my big work table where I use the TS55 to part it.
So in addition to the products mentioned above, someday when it becomes harder for my wife and I to manage the plywood I'll have to come up with a solution for the bulkhead steps - I've been imagining a track down the side of the steps and a small carriage that rides the track with a winch to raise/lower the carriage.  The plywood might need to go down at an angle to clear the doorway, so possibly a second removable track might be needed.
« Reply #19 on: August 29, 2018, 12:11 PM »
You just need to alter the workflow so it’s “parted”, or at least rough parted, in the garage.
Offline ChuckS
« Reply #20 on: August 29, 2018, 12:22 PM »
I could not imagine how challenging it must be to work out of a basement shop. The thought of moving big machinery down the stairs is daunting enough for me (one of my friends managed to get a SawStop PCS into his basement with only one extra helper).
My basement (walk-out) is a place to store my lumber (on a pool table), but in the winter time when it is snow everywhere, I will try to move the lumber via the stairs -- doable with a bit of care. 4 x 8, if any, probably won't work and must go through the basement door. But then, I usually have a full sheet pre-cut into two at the lumber yard or big box store.
Offline sprior
« Reply #21 on: August 29, 2018, 12:28 PM »
That's not a good option for me, besides the garage being a nowhere near as nice environment as my workshop I also tend to keep some plywood "in stock", so there's no specific cuts to be made at the time of purchase.
Maybe someday when I retire I'll move and get a shop at ground level, but that's not soon.
Offline sprior
« Reply #22 on: August 29, 2018, 12:37 PM »
Depends on how determined you are, I've seen pictures of Brideport mills in basements.  I suspect it'll take a Sawzall to get my big work table out of there.  Not being a city dweller I just recently heard that there are people who specialize in  performing surgery on (and then repairing) furniture to get it to fit in elevators for apartment buildings.
Here's a picture of my workshop, most of the Festool stuff is out of frame behind me as are tools like band saw, table saw, jointer which are stored in a corner and get rolled out on demand.  BTW, almost everything is on wheels and a few weeks ago it took me only 90 minutes to clean out this space to the bare walls (everything to the adjoining room) all by myself.
My current project is building a new miter saw station that has systainer storage.  The platform on top is the old one temporarily borrowed, I'm building a new bigger one with drawers under the top deck and a removable extension wing.
« Last Edit: August 29, 2018, 01:01 PM by sprior »
Offline lunchman
« Reply #23 on: August 29, 2018, 01:15 PM »
Since I had to make a trip to Lowe's today for plywood and drywall, I figured I'd give the Portamate another go in unloading the sheets off the truck. I only used it for the plywood, which was 1/2",  I carried the sheetrock in by hand.
I set up the Portamate in its horizontal orientation far enough away from the tailgate and slid the ply out onto it. Honestly, it wasn't as bad as I had recalled, but this is 1/2" ply and I normally work with 3/4". Lowering the sheet back down to vertical is easy enough with the lever handle. The  tricky part is trying to push the button to retract the extended leg while keeping the sheet almost upright so it won't tip over. As I'd done in the past, I just left the leg extended and wheeled it the 20' into  my garage.
In the past when I had a lot of 3/4" ply to unload, it was handy to have this. This 1/2" sheet could easily have been hand carried, but I wanted to give it another go as a refresher.
Fortunately I can break down sheet goods in the garage with the TS55. There's no room in the basement shop to store 4x8 sheets nor do I want to carry one down the bulkhead stairs.
And those are the results for today's experiment.  Back to making French cleats.  :)
-Dom
Offline jobsworth
  • Festool Baby.....
« Reply #24 on: August 29, 2018, 01:19 PM »
I have a garage shop with the garage in the back of the house behind a gate with a block wall fence. So what works for me is a cheap harbor fireight movers dolly. Yea I still have to muscle the sheet goods outta the back of the truck but once on the dolly its easy peasy to roll in the shop one or 2 at a time then muscle them on to my MFT. I get these on sale with a coupon for about $8 and they are small and easy to store
https://www.harborfreight.com/18-in-x-12-in-1000-lbs-capacity-hardwood-dolly-63095.html
Offline lunchman
« Reply #25 on: August 29, 2018, 08:18 PM »
@sprior , nice shop btw. I wish I had that much room in mine,  but it's a vast improvement over working in the garage.
Offline Mario Turcot
« Reply #26 on: August 30, 2018, 10:32 AM »
I second that ^^
Looks like a high ceiling. The only negative thing is the x-carve   [eek] I have a Shapeoko 3  [tongue]
Mario
Offline sprior
« Reply #27 on: August 30, 2018, 11:08 AM »
I second that ^^
The ceiling height is high, the downside is that it is bare fiberglass which usually isn't much of an issue except like last night when I aimed a compressor blow nozzle up while I was emptying the tank.  It'd be nice to cover it, but I've got a LOT of wiring (mostly networking, video), ducts, and plumbing that would be in the way.  A friend once suggested stapling up Tyvek house wrap.
When I got my X-Carve the Shapeoko 3 XXL wasn't out yet, but knowing what I do now I'd go in that direction.  My X-Carve works really well, but I had to spend too much time/money upgrading it for stiffness and other stuff.  Having now seen the difference between the X-Carve and Shapoko extrusion beefiness it's clear who's better int hat regard.  And my dissatisfaction with Easel's cloud based approach has only grown over time, and them pushing the Easel Pro subscription just makes me mad.  I actually use Fusion 360 for my design work and have just been using Easel as my g-code sender out of laziness.
« Last Edit: August 30, 2018, 11:32 AM by sprior »
Offline lunchman
« Reply #28 on: August 30, 2018, 10:37 PM »
I was prowling thru YouTube videos this evening and came across a Stumpy Nubs review of the Bora Portamate, which may help in a decision re: what to purchase.
And it seems that my method of not retracting the leg during transport is what they did when they used their unit.
Offline tjbnwi
« Reply #29 on: August 30, 2018, 11:23 PM »
 [big grin]
« Reply #30 on: August 30, 2018, 11:25 PM »
You are insecure and went berserk on the plywood? or you just want to be busy for the long weekend  [eek]
Mario
Offline tjbnwi
« Reply #31 on: August 30, 2018, 11:34 PM »
I order 3 or 4 bunks at a time.  Normally last 3 to 4 weeks.
Solids (hard and soft maple) I buy in increments of 500 board feet, unless it happens to be a one off. Then I order what I need plus 15%.
Blum drawer slides I order by the pallet. The last two house used just under 300 drawer slide pairs. House we’re doing now will use 278 pairs of drawer slides.
Hinges and back plates 1000 at a time, edge banding by the mile (speaking of which I need to order 10 more rolls).
Finish is ordered 25-50 gallons per order.
« Reply #32 on: August 30, 2018, 11:40 PM »
wow  [scared]
Mario
Offline waho6o9
« Reply #33 on: August 31, 2018, 08:49 AM »
Impressive
Offline awil66
« Reply #34 on: August 31, 2018, 09:07 PM »
Was that a mic drop by Tom!?!?i think it was !
Offline IndyMike
« Reply #35 on: September 01, 2018, 01:33 PM »
I had a dream that I was handling sheet goods - and that I had some cool multi-use system that not only handled sheet goods but helped me with like 8 other things........ I think it was too good to be true [i.e. I don't think it was physically actually possible]...
When you start dreaming about plywood :P.
Mike
Offline JimD
« Reply #36 on: November 16, 2018, 07:58 PM »
My shop is too small to run full sheets through the table saw (14x24).  I like the track saw better anyway.  I haul the wood home in a small trailer which has short wooden sides.  Sometimes I just get a sheet on top of the sides and cut it there with the tracksaw.  Usually I tip it out of the trailer and carry it under my arm, clamped to my side, to the shop garage.  I put a 1 inch thick piece of foam on top of the outfeed/assembly table (3'x7') and lift the sheet on top.  The foam slides some but the table has locking casters and is loaded down with tools so it does not move.  I have to shift the foam a bit once the plywood is up but it works.  I'm 63 but can still handle full sheets of 3/4 OK, but I'm doing this as a hobby so a couple sheets in a weekend is about as much as I typically cut up.
Slickest setup I've seen was a wooden lattice of 1x3s or 1x4s with folding legs so it can be setup as a cut table.  The guy who used it had health issues where he couldn't manage the sheets but he could slide them off his pickup onto the cut table.  From there, he finish cut with a track saw.  He never had to lift a whole sheet.  If it gets to where I need it, I might do this.  But so far, one lift onto the table is OK.  Carrying it 20 feet or so from the trailer to the shop garage isn't a problem.  I can back the trailer into the shop garage but usually I'd rather carry the plywood (I also have to pivot it 90 degrees while backing it and I'm not great at it).
Offline BarneyD
« Reply #37 on: November 16, 2018, 08:36 PM »
The older I get, the less I find myself willing to lift. I have a cutting table I made of 3/4" ply on folding legs (so I can easily store it). And my shop is fairly small so I prefer to do this outdoors where I have plenty of room.  I just slide the sheets out of the truck onto the cutting table and have a go at them with the tracksaw.  Sliding is way easier than lifting.
Barney
Offline jobsworth
  • Festool Baby.....
« Reply #38 on: December 27, 2018, 11:10 AM »
@BarneyD
Good idea Is that table one of those ones with the plastic top and the fold away legs?
« Reply #39 on: December 27, 2018, 01:15 PM »
“a cutting table I made of 3/4" ply on folding leg”
Offline BarneyD
« Reply #40 on: December 27, 2018, 01:17 PM »
@jobsworth , Yes the legs were from one of those cheapie tables. But I threw the top away and made my own top from some plywood scraps. When it gets too chewed up I just make a new one.
Cheers
Barney
Offline jobsworth
  • Festool Baby.....
« Reply #41 on: December 28, 2018, 11:27 AM »
Good Idea. Im looking for something like that for my small shop.
Im taking in all ideas....
Maybe use one of the hole pattern jigs and make a MFT style top for it, set it outside of the shop and use it as a cutting table,
ya got me thinking already :>D
Offline TSO_Products
    • TSO Products LLC
« Reply #42 on: December 28, 2018, 03:15 PM »
PortaMate: for our needs to move full sheets of MDF, Melamine and Plywood in congested space from vertical storage to workbench height  - we bought one PortaMate for our own use when it first came out.
We used it again just before Christmas. For our needs it meets the requirement at a very affordable price and very affordable storage space needs.
We like the product so well,based on our experience with it over several years, that we intend to add it to the product line up we offer for sale in 2019.
Hans
Offline gnlman
« Reply #43 on: January 14, 2019, 01:12 PM »
I'll second the portamate. We have travel trailer in front of my shop in driveway now. I used to be able to back in shop move sheets pretty easy. Now I have about 40 feet to travel with sheet goods. I picked one of these up from amazon and moved 5 sheets of 3/4 melamine..I think they are about a 100 pounds. Took a sheet or two to get it down, but it works great. I only moved one sheet at a time as that is all I was comfortable with. There are parts of it that seem a little flimsy, it's not perfect, but given the price it works just fine. I see some folks have done a couple of improvements to it, I could see if there was a way to lock wheels it would help. If they ever come out with something a little more "Industrial" I'd have no problem paying a premium for one. I'm not using it as an infeed table, but just to get goods to sheet storage. Buy one it will save your back and shoulders....lol
