For just $100, I've got an opportunity to purchase a used Lennox natural gas heater for my new detached shop build-out. The shop in question is an open, three-car garage, approximately 1,100 square feet with open attic access (which I will be sealing with a drywall ceiling and insulation above that). The shop is located in the PNW, not a very cold climate but this time of year it does get to 30-40 degrees F on a regular basis. This heater looks to be 75,000 BTUs and 80% efficient which should work fine for my space... It may even be a bit on the large end but advice I've received tells me this BTU range would be a good fit. I was removed from a home because the owners were converting the garage to a living area and doing some further renovation work; I've been told it was working at the time it was removed. It has been in garage storage for about a year.
I've been looking at natural gas shop heaters but new, they're around $750 and when you add venting, the total cost can easily climb over $1,250. I'm already going to take a hit of $500 for the utility to run a second gas line to the shop and install a meter on the side of the shop (which is a subsidized cost, quite a deal actually).
Here's the complete instruction sheet with specs:
https://www.lennoxpros.com/docs/Technical/490045.pdfMy actual question - what's your feeling on using a whole-house heater like this, for just the garage? I see it does have a horizontal attic mounting option which might work for my application. For $100, I'm willing to spend a little more time on a custom install. I'd like to keep it in the attic or along the ceiling so it doesn't obstruct floor space, but if I need to build a cabinet for it, that's fine too. It's not very large (about 3x3x2 feet).
Will the costs of venting be more than a standard garage heater (which I think is usually a 6" diameter tube)? Are there any other costs/accessories I need to account for? The instruction manual shows a Cooling Coil, Electronic Air Cleaner and Automatic Humidifier used in the horizontal attic installation -- are these required or optional?
Any others cons to this approach or things to keep in mind?
Pictures of the beauty:
