Author Topic: plywood rack in van  (Read 3436 times)
Offline treesner
  • DESIGN / CRAFT / ROAM
    • Trailboundco
plywood rack in van
« on: April 20, 2018, 06:52 PM »
how do you guys strap plywood against the wall in your tall vans? I always lean it, use a tie down across the middle of it long wise but it rattles around still, kind of annoying
Online Frank-Jan
Re: plywood rack in van
« Reply #1 on: April 20, 2018, 08:12 PM »
I usually put it fairly plumb against the racking, then secure it with a few vertical telescopic shoring poles with little blocks of foam between the pole and the material so it doesn't have room to rattle or get damaged (the foam blocks I save from double glazing packaging)
Mine were custom made for my van, but there are systems with tracks that are commercially available.
« Last Edit: April 20, 2018, 08:15 PM by Frank-Jan »
