Author Topic: Paint that dust doesn’t stick to  (Read 1664 times)
Offline treesner
  • DESIGN / CRAFT / ROAM
    • Trailboundco
« on: August 11, 2020, 02:19 AM »
Any recommendation for paint that dust won’t stick to? Would like to do a white that helps light the space on plywood or T111 but know dusty walls is a thinn ive dealt with on drywall shops so wondering if there’s something good I can coat it with?
Offline JeremyH.
Re: Paint that dust doesn’t stick to
« Reply #1 on: September 28, 2020, 07:18 PM »
Just leave the paint in the bucket.  [wink]
CXS;RO150;ETS EC 125/3 EQ;CT26e  KSS400;MT55cc;DDF 40
Offline Bob D.
    • My Cordless Workshop
« Reply #2 on: September 28, 2020, 08:11 PM »
Unless your ply or T111 is smooth I don't think it will matter much what coating you put on it.
Nothing will fill all those crevices to the extent that sawdust will not find a home there. You'd need glass smooth walls and even then static charges on the dust particles will cause it to adhere to just about any surface.
I think coating could help with removal by keeping the dust from penetrating into the wood grain/fibers but it won't prevent it. Then you could use a shop vac to clean the walls occasionally.
Being anal about collecting/stopping dust at the source would probably do more. I use my shop air cleaner AFTER a work session. If I run it while I am generating sawdust it will tend to spread whatever it does not trap. But afterward with no air movement other than what it creates I think it does a better job. Mine has a adjustable timer on it so I can set and forget it.
Offline cubevandude
« Reply #3 on: October 02, 2020, 08:18 AM »
Gloss paint, sand between coats.
Offline Rich M.
« Reply #4 on: October 06, 2020, 09:30 PM »
I agree with Bob D.  Trap the dust at the source.  I use my dust extractors as much as possible, and my garage shop stays fairly clean.  Nice photos, you gave me some good ideas !
Offline SRSemenza
« Reply #5 on: October 07, 2020, 11:42 AM »
Maybe something like this ---- https://www.antistaticindustries.com/static-paint/
I just searched for anti static paint. Several popped up. I think it is meant more for non-conductive environments but it might help keep dust off the walls too.
