JMB quote>>> If it wasn't for me wanting to get rid of my of fcuts and make use of them. I think it would have been better of in terms of time to Cnc the lot from a sheet. I think in terms of cost per sheet and my time I recon just spending money on a sheet would have been more cost affective. <<<
The biggest part of my problem in my own small shop space has been the scraps ("off cuts"). a lot of the smaller scraps i save for kindling for my son. everything else gets piled in corners, leaning against walls (too little wallspace to begin with), leaning against work benches and just plain cluttering the floor (not much floor space to begin with either). I am building shelves that are screwed into wall studs. If i change my mind about placement, about four screws for each shelf set is all that is necessary. Since all is being constructed with scrap wood, nothing really matches up. i spend a lot of time searching thru scraps just to find the closest fit.
One thing that is happening by now is, i don't have such an assortment to search thru as when i started. A lot of mixes of pine, fir, tulip, 3/8, 1/2, 5/8, 3/4 ply in all grades. It probably would have been a whole lot quicker for me to just go out and buy the lumber to do the job, draw up plans and lay everything out so i could mass produce. But then, i would have ended up with a bigger pile of offcuts. Probably would have to build a separate shop, after which, i wood have a bigger pile of scraps.
![Scared [scared]](https://www.festoolownersgroup.com/Smileys/default/scared.gif)
Oh well, I am looking thru stacks of plans and pics of very small projects for ideas for Christmas. Those will make use of the scraps from my shop shelves project that has been done with scraps.
![Unsure [unsure]](https://www.festoolownersgroup.com/Smileys/default/unsure.gif)
BTW: I used to dump the sawdust and planer shavings out in the woods or take to the landfill. I now save the coarser planings and shavings for my driveway in the winter. I used sand for years and would spread from my sander along with about 30 other driveways on my snow plow route. I used what was left in the sander when finished with my route and always had some on hand. I always worked it to have a few wheelbarrow loads left in the hopper in case a customer called with an emergency. Last winter, my son, who is partner with me in the sno plow biz, took over the sanding. One of his crew from his excavating biz now does the sanding. I somehow get lost on the list every now and then, putting me even further down on the list beyond being last. I have found that the sawdust seems even better than sand. As the ice and snow melts, sand always sings to the bottom during the day and then the soft ice gets real hard by nite. It will always stay hard once the salt/sand sinks down thru and it is icy till another application. The sawdust does not sink thru, but a lot stays on top so we have a bit of grit until we get more snow. I have a customer whose husband is handicapped and we need to supply extra sand around the garage and at end of ramp to the house. I am going to leave them with a couple of large containers for emergencies or for while they are waiting for us to bring sand.
Yeah, offcuts are useful, even when they get down to dust sized cutoffs.
Oh! and THE BOSS likes the sawdust much better. When it gets tracked into the house, it is MUCH easier to cleanup than sand and salt
Tinker
