Author Topic: My take on the System Workshop  (Read 4320 times)
Offline chrles
« on: February 21, 2018, 10:11 PM »
My take on the
 System workbench and cabinets. Since I am not planning to use this for woodworking I eliminate
torshion box top and the rails and peg mounts. I also made the cabinets wider to fit Stanley Fat Max sort boxes.
The rolling cabinet on the right is the low cabinet with wheels added. No doors because of the limidted clearance when the cars are in the garage.
Overall I was quite pleased with the results as this was the first time that I have made cabinets. It was a very satistied feeling when I slid the drawer bottom into place and the drawer box popped into square. I started with the low cabinet, which is a little out of square, then the workbench, which is not as bad but still not square and finished with the wall cabinet doors which came together quickly and square.
Major tools that I used:
1. Festool track saw with the 4 ft and 10 ft rail.
2. Bosch compound miter saw
3. Festool and Porter Cable routers
4. Porter Cable palm sander
5. Multi-Function slab on Stanley Fat Max sawhorses adjusted for a tall guy.
6. Parf and Quazz dogs
7. Kreg cup hinge, 32mm and pocket screw jigs
8. Woodpecker Square
9. Hitachi 18ga nailer
10. Rolair compressor.
After fighting to get that first cabinet close to square, I regrouped and made the following improvements to the processes.
1. Bought a Woodpecker and a Starrett square to replace the framing square I had been using
2. Used the squares to verify layout, jig setup and assembully.
3. Used a story pole for layout.
4. Used jigs and clamps as much as possible.
5. Do all of the cuts in batches. Do all of my rips, then do all of my crosscuts.
6. Took more breaks and cut my daily hours on the project. A tired woodworker is a inaccurate woodworker.
Thanks to everyone here and on YouTube for sharing their knowledge. Especially Tim at benchworks.be for a great set of plans.
Offline Rob Z
Re: My take on the System Workshop
« Reply #1 on: February 22, 2018, 01:15 AM »
Hello Charles
Nice work you've done, especially for a first time building cabinets.
You're right about Tim Wilmots cabinets in his shop--if I had the wall space I would for sure follow his plans and build the same thing.
Offline ear3
« Reply #2 on: February 22, 2018, 08:51 AM »
Thanks for sharing!  Looks like you got the chaos under control.
The challenge of any redesign is balancing your current and future needs -- if you make spaces that are too specific for your current tool line up, then you find yourself locked in when you start to add or change your kit (one of the advantages of the systainer system, of course, is that it allows for an orderly growth process).  It looks like you've struck the right balance so far.
Good call on securing a decent square/layout tool.  All of those good enough cuts one makes with a questionable square come back to bite you when you start assembling the furniture, as you witnessed first hand.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • Planex Easy • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 36AC w/BT module • CT Sys w/Long-Life Bag • CT-VA 20 • MFT/3 • STM 1800
