Author Topic: My retirement shop make over.  (Read 3510 times)
Offline RJNeal
« on: April 10, 2020, 10:41 PM »
313067-0313069-1
Offline RJNeal
Re: My retirement shop make over.
« Reply #1 on: April 10, 2020, 10:55 PM »
Well I’m glad I got some pictures to post.
My wife and I relocated  north of the Napa valley. Bought a beautiful house on the river. [thumbs up]
I decided to buy a commercial building in town rather build one at the house.
I’m semi retiring for a bit.
I picked up a old soda shop built in 1953. Later was added on by the previous owner to a total 1500 sq ft. Block construction. Front retail side is 15by 39 and the back is L shape 39x 12 and 14.5by 16.
So I started removing some walls in the back portion. Set up an alarm and camera system. I’ve decided to just seal the floor and use mat as needed.
This week I brought in the big equipment and working on placement so the electrician can do his job. Also will need to figure out and order DC ducting.
That’s it for now.
Rick
Offline RJNeal
« Reply #2 on: April 10, 2020, 10:58 PM »
313071-0
Offline Don T
  • Phoenix, Az
« Reply #3 on: April 10, 2020, 11:08 PM »
Sounds like you are going to have a nice size shop.  Enjoy your retirement.
Offline Thompmd
« Reply #4 on: April 11, 2020, 08:28 AM »
First off congratulations on retirement , I did that myself 2yrs ago at 53....luv-it!! Relax and enjoy it. I would enjoy occasional pics as you move along with the shop(doing one myself). One of the most enjoyable parts of it is being able to get what I call side tracked, spending time working on areas of the shop you didn’t feel you had time before.
Sawstop Industrial Saw, TS75,2 1400 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,OF1400 EQ-F-Plus, MFT/3, MFT-SP, FS-HZ 160
Offline Peter Halle
« Reply #5 on: April 11, 2020, 09:25 AM »
Congratulations!
Can't wait to see more pictures.
Offline RJNeal
« Reply #6 on: April 11, 2020, 11:54 PM »
Thanks guys. Have to make a trip to my old stomping grounds. This week end.
Rick
Offline RJNeal
« Reply #7 on: May 06, 2020, 08:51 AM »
Sorry I haven’t updated in a bit.
The electrician is slowly working on the project. (He’s also has two other jobs)
I’m starting to make some saw dust working on carts modification.
My Prometheus boom arm showed up yesterday. In great shape.
313936-0
Rick
Offline RJNeal
« Reply #8 on: May 14, 2020, 05:57 PM »
So yesterday I installed my new Prometheus 120.
Pretty easy. I have a little over 8’ clearance.
After mounting the bracket I rigged the boom arm with rope and hoisted it up.
Nice addition to the shop.
314423-0314425-1
I just need to figure out what I want in the auxiliary tube.
Offline RJNeal
« Reply #9 on: May 18, 2020, 07:57 PM »
Today I had a family reunion....
Offline Richard/RMW
« Reply #10 on: May 19, 2020, 12:48 PM »
Rick, the Fog-tainers are dating you...  [poke]
Jealously speaking, I've always wanted a shop/playroom located away from the house in a walkable commercial area. I picture sitting out front drinking coffee and chatting with passer's by or folks dropping in to enjoy the shop with me.
Hope you are enjoying retirement.
RMW
Offline RJNeal
« Reply #11 on: May 19, 2020, 08:30 PM »
Thanks Richard. I’m only semi retired so the shop is for work and play. I’m planning on working 16-20 hours a week.
Also looking forward to making things. Right now still setting up shop.
Rick
Offline RJNeal
« Reply #12 on: June 09, 2020, 10:04 PM »
316126-0
Offline RJNeal
« Reply #13 on: June 09, 2020, 10:07 PM »
Please bear with me. I have the hardest time posting pictures here.
But just finished up a utility cart. Vac-sys - work bench.
Offline RJNeal
« Reply #14 on: June 09, 2020, 10:08 PM »
316128-0
Offline RJNeal
« Reply #15 on: June 09, 2020, 10:08 PM »
316130-0
Online CeeJay
« Reply #16 on: June 09, 2020, 11:37 PM »
(Attachment Link)
Now that is nice work Rick!!
Offline GarryMartin
« Reply #17 on: June 10, 2020, 05:44 AM »
I like the idea of a "holster" for the VAC SYS rather than direct attachment. Might steal that... ;-)
Offline RJNeal
« Reply #18 on: June 10, 2020, 07:05 AM »
Thanks guys.
Garry, I was going to attach directly with tee- bolts, then I saw a post last week here where the someone made this kinda set up I used finished plywood so I can “suck up the slop”. Pretty much designed it are lots of ideas I read here.
Rj
« Last Edit: June 10, 2020, 07:13 AM by RJNeal »
Offline GarryMartin
« Reply #19 on: June 10, 2020, 02:22 PM »
Exactly that. You don't need to worry about stability in the holster once it's switched on because it will create the vacuum to the surface it's sitting next to. Genius
Offline RJNeal
« Reply #20 on: June 10, 2020, 05:47 PM »
You just need to push them back at the beginning if there is no more vacuum, I think I left 1/16 strong( 2mm+) on the play to ease them in and out.
Rick.
