Author Topic: Mitsubishi Mini Split  (Read 7317 times)
Offline Rob Z
« on: February 13, 2018, 01:59 AM »
FYI in case it helps others who are thinking about installing a ductless split system in their shop....
One thing I never considered when I decided to install a ductless split system is the de-humidification feature that the system has available.  Here recently we've had some strange weather with a lot of dampness/humidity. Once I open the garage door all that humidity sneaks in to the shop.  The Mitsubishi unit I have has a setting that is strictly for removing humidity.  I haven't measured the humidity levels once the unit has been running in this mode, but it is quite obvious that the air is dryer after not much runtime.
When I was doing remodel work I used to coordinate with my HVAC sub to get these installed for our customers.  I never gave ductless splits much thought until I got this one installed. I love it and would really prefer to have these throughout the house instead of our builder's grade forced-air system.
Offline JBag09
Re: Mitsubishi Mini Split
« Reply #1 on: February 14, 2018, 09:09 PM »
I’m currently having a shop built myself, and after my son and his friend do HVAC work, this type of unit is what they both recommend for many reasons including what you mentioned. So I will definitely have them installed once I’m ready.
Offline Runhard
« Reply #2 on: February 14, 2018, 09:24 PM »
Here’s another vote for the mini split system. I do not have one installed yet, but I plan on installing one in my 3 car garage/future shop. My contact for HVAC also recommends Fujitsu and said that I will need one rated for -15°.
Daniel
Offline JBag09
« Reply #3 on: February 14, 2018, 09:38 PM »
I’ll be using ComfortStar actually, and luckily I know someone at our local supply store and my son can install it, I was amazed at the actual cost of these units compared to the “installed” cost
Offline Rob Z
« Reply #4 on: February 14, 2018, 09:40 PM »
Hey Daniel
Fujitsu is good equipment, although I chose Mitsubishi because I had a lot more experience with the brand.  Mitsubishi has a line called "Hyper Heat", which is what I bought, and it is able to produce 100% of rated output down to temps of about 6-7 degs F.   I',m sure Fujitsu has a similar product line.
My unit is a one ton unit, for a <400 sq ft garage in an end unit town house, top quality insulated garage door and one insulated  exterior wall on the side.  We did the load calcs and the one ton unit was enough.  So far, that has turned out to be correct.
Offline Mikeoutrage
« Reply #5 on: February 15, 2018, 06:27 AM »
I just installed the diy mr cool 24000 btu unit in my 24x32 shop right after summer. Took about 3-4 hrs to install myself and has been running like a clock ever since maintaining 68 degrees. It was $1400 out of pocket. Not to bad. The humidity was around 70 to 75% and now it is a
steady at 35-40%.
Online Michael Kellough
« Reply #6 on: February 15, 2018, 08:05 AM »
@Mikeoutrage “mr cool” is that a thing?
Offline Mario Turcot
« Reply #7 on: February 15, 2018, 08:26 AM »
@RobZ I am interested in a mini split, can you tell me which one from that link you would suggest. My shop is 400sqft and the weather goes from -30 to 30 Celsuis.
Thanks, Mario
Mario
Offline Rob Z
« Reply #8 on: February 15, 2018, 08:43 AM »
Hello Mario
I just looked at the model numbers of the equipment I bought and they are slightly different from those listed on your link.  But even so, I don't think it would be prudent to try to size your system from afar.  You can look this stuff up on the web and figure out your heating/cooling  load, which will be based on various factors such as square footage, insulation in the walls and ceiling, windows, etc.  I know just enough, as the saying goes, to be dangerous  [big grin] , so it wouldn't be prudent to choose a particular model from afar.
« Reply #9 on: February 15, 2018, 08:58 AM »
Hello Mario
And I thought you were an expert  [tongue]
When I built my shop last summer I looked into mini split. I went on another direction adding two convection heater instead, mainly because of the installation price on the mini split. I may reconsider the mini split based on the humidity control feature  [big grin]
Thanks, Mario
Mario
Offline Rob Z
« Reply #10 on: February 15, 2018, 09:08 AM »
Mario, sadly , about the only things I rate as  expert is grilling a good steak and trivia from the movie The Big Lebowski  [big grin].
Offline tomp
« Reply #11 on: February 15, 2018, 10:32 AM »
I have the Mitsubishi mini-split, don't remember the model without looking it up, but picked it because it was rated to produce heat at -15 °F outside temperature. I believe that I paid around $1500 for the package, a little higher than some of the other options, but Mitsubishi has a good reputation and I wanted the features. I installed the unit myself, but paid a local HVAC contractor $300 to connect the copper tubing, pump the system down and make all the adjustments. Well worth the money, plus I understand that Mitsubishi gets sticky about the warranty if a licensed contractor doesn't sign off on the installation - I mailed the completed form to them and got an acknowledgement in about a week that the warranty was in effect. And the unit will be three years old this year, working fine.
Offline deepcreek
    • TimberFire Studio
« Reply #12 on: February 15, 2018, 11:42 AM »
Another option is a PTAC unit like they use in a lot of hotels.  I've had good luck with Amana but there are other manufacturers.
It is a complete slide-in system with a fixed wall sleeve so the unit can be replaced in the future.  No licensed HVAC installation required.  It's ready to go out of the box.
https://www.amana-ptac.com/
Joe Adams
TimberFire Studio
Houston, Texas
Offline Sayn3ver
« Reply #13 on: March 07, 2018, 02:24 PM »
How's the mini split dealing with the dust of shop life. They don't come with great filtration and their efficiency drops when the evaporator coil gets dirty. They also apparently tend to spit condensation when the coil gets dirty.
I was gung hoe to use one in the future for my garage when it gets redone but I'm cautious to the dust and dirt aspect. At least forced hot air as efficient and relatively cheap filters. Both washable and disposable and the addition of both supply and return register filters make another layer of dust removal.
I love mini splits btw. Easy install. Cheap. And I'd you dont feel you need the warranty can be had and installed by yourself depending on your locations permitting.
Keep the lineset lengths within the parameters of the precharge and you don't need to add refrigeratant nor then require a technician.
Really only need to invest in a set of gauges, an open end torque wrench and a decent vacuum pump.
And now Mitsubishi has some sweet stats and control options if you want to go mobile, integrate with an existing smart stat or need to add a mini split condensate pump. Their one stat is Honeywell redlink ready.
"A race is not won on race day, instead a race is to show what you have accomplished in practice."
Offline fignewton
  • "Fine Quality Sawdust"
« Reply #14 on: March 16, 2018, 08:47 PM »
I have a Mr. Slim, which has been great for heat and AC.  It has two fine-mesh screens over the air intake which pull out easily and can be washed out.  While out I use the CT26 and brush attachment to vacuum the coils, pulling the air back through them.  Doesn't seem to have any adverse effects, but I try to control dust and clean up as I'm working.
TS55, MFT3+, OF1400, C12, CT-26, LR-32 system, Domino 500, RO125, MFK 700, Carvex w/ accsy, Sys-roll,  CXS, Kapex, UG with extensions, RO90
Offline tzed250
« Reply #15 on: May 28, 2018, 08:07 PM »
We heat and cool our house with a Sanyo (now owned by Panasonic) mini-split system. Our original installer made several mistakes during the initial install which he chased for 5 years before giving up. We finally found a local HVAC company that has gotten it running correctly, 7 years after the initial install.
Word to the wise, whatever brand you choose RESEARCH THE INSTALLER and make sure they have a LOT of experience with the equipment and getting it to run correctly.
Offline bmh
« Reply #16 on: May 28, 2018, 09:24 PM »
Installed a Daikin minisplit system for the house and only used the house forced air a total of 3 days. I suspect when I get the house correctly insulated I won't need the force air unit anymore. Going to instal one in the shop next year
