Author Topic: Parf Guide Inspired Workbench - Making Slow Progress  (Read 17051 times)
Offline HarveyWildes
« on: April 23, 2017, 11:58 AM »
I'm making slow progress on my new workbench, which used the Parf Guide System to drill holes in the top.  The top of the front apron will eventually have a row of holes matching the rest of the bench, and also the vertical surface of the apron will as well for planing.
« Last Edit: April 23, 2017, 12:17 PM by HarveyWildes »
Re: Parf Guide Inspired Workbench - Making Slow Progress
« Reply #1 on: April 23, 2017, 12:10 PM »
Whoops!  I hit the post button before adding info about the vise.  I decided to add the Veritas tail vise to this bench because it looked considerably easier than a traditional tail vise.  It was very easy to install, but you do have to pay attention to the installation instructions to make sure that the vise travels exactly parallel to the front of the bench.  The vise jaw is 2" thick, and about 5" wide.  Note how far down the bolts are on the jaw - that reflects how far down the mechanism extends.  The bench top is only 1.5" thick, so for a thicker bench, the jaw would have to be that much wider.
The jaw is made of jatoba.  The apron is made of cherry with jatoba laminated on top and bottom for strength.  both the apron and jaw will have jaw pads of Jatoba screwed in and countersunk so that they can be replaced if needed.  The breadboard ends are cherry, and the top is alternating granadillo and soft maple.  I used some pallet oak for hidden structural pieces.  The jatoba was supposed to be granadillo, but I picked up the wrong board because I was in a hurry :).  At least the jotoba is plenty hard and will be up to the task.
« Reply #2 on: April 23, 2017, 12:38 PM »
It's gonna look nice!
« Reply #3 on: April 29, 2017, 05:39 PM »
All the top holes are drilled using the Parf Guide system, and the top is done aside from finishing.  Haven't drilled the apron side holes yet.
I did in my C18 drilling the top holes in the apron, per another post.  Finished it up with a Milwaukee M18 drill that started getting a little hotter than I liked, and finally finished up with a DeWalt 20V (not brushless).  When using the Milwaukee and DeWalt drills I used the 20mm bit that came with the Parf Guide to drill the tops of the holes, but it is enough shorter that I could not get the full depth and had to do a second pass with the Centrotec version of the bit.
I was going to add on a Moxon vise, but the Veritas tail vise seems to hold boards firmly.  We'll see how it does in use.
Here are some pictures of MFT clamps and dogs on the bench.
« Last Edit: April 29, 2017, 11:09 PM by HarveyWildes »
Offline ear3
« Reply #4 on: May 07, 2017, 08:13 PM »
Coming out great. How square is the hole pattern?
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • Planex Easy • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 36AC w/BT module • CT Sys w/Long-Life Bag • CT-VA 20 • MFT/3 • STM 1800
« Reply #5 on: May 09, 2017, 07:54 PM »
I drilled all of the holes except those in the apron about two months ago (?) or so.  At that time they were pretty much as perfect within the limits of my ability to measure.  When I came back to drill the apron, I checked out the Parf guide on the holes to see how they fit.  With the grain the fit was still perfect on the 5-10 holes that I tested.  Cross the grain the fit was maybe .1mm or less off, I presume due to wood movement.
Wood movement in Colorado is minimal due to the low average humidity, so that helps.  Most wood shrinkage occurs between 100% and 60% relative humidity.  Colorado humidity averages lower than 60%.  http://festoolownersgroup.com/building-materials/wood-shrinkage-in-colorado/msg497873/#msg497873
Offline ben_r_
« Reply #6 on: May 10, 2017, 05:35 PM »
How thick is the top?
Offline ear3
« Reply #7 on: May 20, 2017, 03:29 PM »
I was just reflecting on how since I finished my bench last Fall with the integral vises, and in particular the benchcrafted wagon vise, I can count on one hand the number of times I've had to resort to the clamping elements, which, prior to the bench, were my most frequently used clamps.
It's amazing how much of a difference a customized bench makes.
« Reply #8 on: May 20, 2017, 09:37 PM »
Offline Vondawg
« Reply #9 on: May 21, 2017, 08:07 AM »
HW - I see you're using your Festool clamps...with the 'inch and a half' thick  top did you have to open up the holes underneath to allow the clamps to fit in or use a round over bit? I'd be interested to know how they work... Sometimes even on mine (not as thick) it's a challenge.
Offline ben_r_
« Reply #10 on: May 21, 2017, 12:41 PM »
Where do you see him using Festool clamps? I dont think he can with an 1.5" thick top. That was why I asked how thick it was. As I understood it the Festool clamps can only be used with a tabletop thickness of around 3/4" or less, like the MFT/3 has.
Offline Richard/RMW
« Reply #11 on: May 21, 2017, 01:08 PM »
I think he disassembles the clamp and inserts it from below, note the pin in the end of the clamp in this photo.
RMW
Offline ben_r_
« Reply #12 on: May 21, 2017, 06:45 PM »
RMW
Good catch. I think you might be right. Kind of a pain, but nice to get the advantages of using clamps like that AND a nice thick work top.
« Reply #13 on: May 21, 2017, 11:18 PM »
I tried opening up the holes underneath and found that it simply does not work - at least not leaving a good 3/4" deep hole from the top for dogs, etc. to grab.  The person who suggested that I dissembled the clamps and insert them from below was correct.  Given that, they still work great.  You just have to make sure that you don't fill the space immediately below the top (for ~ 6" or so) with drawers and such.
Offline Vondawg
« Reply #14 on: May 22, 2017, 12:09 PM »
Thanks Richard I didn't look close enough.
And thanks Harvey...great bench!
Offline Bert Vanderveen
« Reply #15 on: May 22, 2017, 04:11 PM »
Bessey just introduced clamps with workbench-adapters for most of the hole-systems in use. It is modular, eg you buy a base for the hole diameter you use and the clamp that attaches to it is sold separately.
Unfortunately Bessey's website is not working properly, but the downloadable new catalog is available. The new Workbench adapters and Clamps are on page 113-115.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline Svar
« Reply #16 on: May 22, 2017, 04:39 PM »
This one?
It has one limitation. The leverage is too great for thin MDF top and will deform the hole. Will work fine in steel welding table or thick wood bench.
« Last Edit: May 22, 2017, 04:48 PM by Svar »
« Reply #17 on: May 22, 2017, 04:59 PM »
Yep. But the illustrations in the catalogue show the system in use with what looks like material that is about 40 mm thick. Which would suit the OP.
On order: … [ ! ]
Offline PaulH99
-Paul
CT 26 • DF 500 • ETS 125 • KS 120 • OF 1400 • PS 420 • RO 125 • TS 55 R
« Reply #19 on: May 23, 2017, 07:52 AM »
Just take a look under Clamps for Woodworking. The last item in the menu:
http://www.besseytools.com/en/subcategory?ASIMOID_SC=000000030003cd8400040023&ASIMOID_MC=000000000001f3f000030023
[BTW  I just relay information that I found in the catalogue. I never make up stories about clamps…]
On order: … [ ! ]
Offline PaulH99
-Paul
« Reply #21 on: May 23, 2017, 09:38 AM »
Is there a 20mm adaptor for the Bessey clamps?  I did not see one.
I got a Veritas Surface clamp http://www.leevalley.com/us/wood/page.aspx?p=70684&cat=1,43838,70865 but apparently I have to be careful not to tighten into the hole too tightly or I will deform the hole.  The main reason I got it was for horizontal clamping on the front of the bench.
« Reply #22 on: May 23, 2017, 12:48 PM »
The 20 mm adapter is on the German site, not on the English/American one… Yesterday it was on neither, so there is hope.
http://bessey.de/de/product_details.php?ASIMOID=00000001000029b100060023&ASIMOID_SC=000000030002a4e400060023&ASIMOID_MC=000000000000a94700020023
Note the photo — with a wooden bench! Exclamation mark! !
On order: … [ ! ]
Offline Vondawg
« Reply #23 on: May 24, 2017, 07:25 AM »
Great info here Bert thanks !
Offline ear3
« Reply #24 on: May 25, 2017, 03:54 PM »
There's also the Seneca clamp dogs, though you have to secure them with a knob from the bottom, like the Festool clamping elements.  I've got Kreg automaxx clamps mounted to mine: https://www.senecawoodworking.com/blogs/news/8385791-introducing-the-seneca-woodworking-mft-clamp-dog
« Reply #25 on: November 29, 2017, 01:05 AM »
How slow is slow progress?  Well, the last post on this thread was May 25.  Summer was crazy, didn't get started on the legs until September.
There are three leg sections separated by stretchers, out of African mahogany.  They are sanded to ~800 grit, finished with two coats of oil and one of wax.
The legs are joined with oversized 8mm home-made dominos.  There are two dominos in parallel per joint.  The picture shows the domino I made, compared to the stock Festool domino.  The additional size gave me the confidence to use dominos rather than mortise and tenon joints.
I'll be putting narrow shelves in the front under the bench, and systainer storage shelves behind, pulling out to the side.  The idea is to put various dogs, clamps, etc both on the shelves and the systainers on the side, so that everything is handy.  Of course I'll leave enough space under the top to reach in with clamps if needed.
« Last Edit: November 29, 2017, 01:13 AM by HarveyWildes »
« Reply #26 on: November 29, 2017, 01:27 AM »
I also thought I'd showcase some Lee Valley 20mm accessories.  My relationship with Lee Valley is relatively good customer - I didn't get anything for this.  I just like their stuff - well designed and well made.
The first is a bench anchor.  Between the front holes in the bench and the top holes, I expect to be able to create a variety of jigs and clamping fixtures that are anchored to the bench using these.  http://www.leevalley.com/us/Wood/page.aspx?p=59754&cat=1,41637
The second is a bench blade.  useful for quick release where the main vise can't be used.  http://www.leevalley.com/us/Wood/page.aspx?p=64685&cat=1,41637
The third is a Festool branded plane stop that I assume is made by Veritas.  I've found these useful on my old bench, and a nice low profile on the bench.  http://www.leevalley.com/us/Wood/page.aspx?p=69837&cat=1,41637
Finally, I got two surface clamps that allow me to edge plane on the front of the bench.  http://www.leevalley.com/us/Wood/page.aspx?p=57059&cat=1,41637
Just say thanks, Lee Valley :).
« Last Edit: November 29, 2017, 01:40 AM by HarveyWildes »
« Reply #27 on: February 03, 2018, 06:57 PM »
Finally got the finish on the top - four coats of oil and a coat of wax.  Ended up with way more character than I expected it would have.
Next - drawers on both sides.  The right side will have two drawers that will fit two sys1's.  One is a Festool MFT set, the other has a variety of other 20mm accessories.  The slides will be 20" slides so that the systainers will come out well clear of the bench, and I'll be able to open them without removing them from the drawers.  The left side will have one shallow drawer for chisels and carving tools, and whatever, and one deeper drawer for hand planes and whatever.  I might have to beef up the drawer slides for the hand plane drawer - currently I just have 100 lb capacity slides on hand.  I'll probably also put a lower shelf on the left side.
« Last Edit: February 03, 2018, 08:52 PM by HarveyWildes »
Offline Dick Mahany
« Reply #28 on: February 03, 2018, 08:12 PM »
Looking great.   It will be a joy to use.
Offline TSO Products
    • TSO Products
« Reply #29 on: February 03, 2018, 08:16 PM »
@HarveyWildes : "well done" - no,make that "very well done" !
if this bench turns out to take too much room after all, let us know, we'll be glad to store it for you  [wink]
I still have a brand new RECORD benchvise (made in England before they quit making them) and waiting for the right bench to arrive to mount it on. You thanks for sharing - you encourage me to find a home for it in our shop.
Hans
TSOproducts.com
