Author Topic: shop festool cabinets  (Read 5552 times)
Offline lambeater
« on: January 16, 2018, 08:12 AM »
Just built these for my Festool systainers and to reorganize a little. Took my last 2 sheets of prefinished ply and some scrap. Also drilled all the shelf pin holes with my 32 system so I can start installing some pull outs.
[ Specified attachment is not available ]
Lambeater.
« Last Edit: January 16, 2018, 09:03 AM by Peter Halle »
Offline Mario Turcot
Re: shop festool cabinets
« Reply #1 on: January 16, 2018, 08:19 AM »
Would fit perfectly in my shop :)
Well done!
Mario
Offline lambeater
« Reply #2 on: January 16, 2018, 08:21 AM »
thanks wish the images would stop rotating.
Lambeater
Offline Peter Halle
« Reply #3 on: January 16, 2018, 09:00 AM »
Lambeater
Fixed.
« Last Edit: January 16, 2018, 09:04 AM by Peter Halle »
Offline Stoli
« Reply #4 on: January 16, 2018, 09:59 AM »
You'll certainly want to install the pullouts.  The tool you want next is always going to be at the bottom of a stack.
DF500; OF1400; ETS125; CXS; installer Kit;  Kapex
Offline lambeater
« Reply #5 on: January 16, 2018, 10:52 AM »
thanks Peter
Offline lambeater
« Reply #6 on: January 16, 2018, 10:54 AM »
yes I will, already drilled for them.
lambeater
Offline egmiii
« Reply #7 on: January 16, 2018, 11:08 AM »
Curious why you put them so high. If you put the cabinet on the ground, then used SYS-AZ drawers, you could remove a tool without removing the systainer. I feel like I'm missing something.
Offline lambeater
« Reply #8 on: January 16, 2018, 11:16 AM »
yes I put them high because my shop is only 12ft wide in the main part so needed to utilize space and still be able to use table saw. seemed the best option.
Lambeater
Offline Ves
« Reply #9 on: April 01, 2018, 12:58 PM »
Looks great. Nice apron
