Hi folks, I'm late to this conversation, but I hope I have something worth reading. I've owned a Dylos meter for about three years. Although I've done very little woodworking in my basement wood shop during that time, I've used the Dylos meter enough to be confident that I've got reliable baselines and reliable data when I'm making sawdust. That said, here are some things I've observed.
Baseline particle counts depend a lot on the outside air, and the particle counts of outside are vary a lot from day to day.
The particle counter measures water vapor particles, so the more damp or humid the air, the higher the particle count.
The particle counter is very sensitive and its readings are very consistent. Anything that causes air motion in the wood shop, even just me walking from one side of the shop to the other, will cause the particle counts to rise a predictable amount.
In my limited experience with only two dust collectors that collect dust at the source, I've found that they cause fine particle counts to rise, even if not connected to a machine making wood dust, and even if I'm not making new wood dust. That was true of my Oneida Dust Cobra (which I sold) and is true of my Festool CT-11 (twelve years old and running like new). I believe this is the net result of two things: they cause air motion in the shop, but they don't filter as much fine dust as they stir up. They're great for keeping coarse dust from falling under foot, or spraying all over the work surfaces, but they don't decrease the number of fine dust particles in the air.
On the other hand, my Jet ambient air filters quickly reduce particle counts, even in the 0.5 micron range. (Jet doesn't even make any claims regarding filtration of particles that small.) Contrary to claims I've read that ambient air filters simply blow dust around, they're the most effective collectors of fine dust in my wood shop.
If I don't run any dust collectors or air filters, airborne particle counts in both ranges decrease to baseline over a period of about 5-10 minutes, contrary to claims I've read that particles in the 0.5 micron range remain suspended indefinitely.
--John
