Author Topic: Lighting? Anyone install any after markets?  (Read 5873 times)
Offline wing79
    • Macomb Stairs and Millwork
« on: February 16, 2014, 10:43 AM »
Hey all,
Anyone install any aftermarket lights
in the cargo area?  If so which ones did you go with?  I'm in search of a good solution possibly led setup.  I've got the tall promaster and the two factory light just don't cut it.  Any info or pictures [eek] would be great!
Thanks for any info!!
Jim-
wing79
Kapex w/UG Stand, ETS 125, ETS 150/5, RO 90, RO 125, RAS 115, TS 55, 1010, 1400, WCR 100, CXS, CT 22, CT Midi, DF 500, DF 700, MFT 3
Offline MAK
Re: Lighting? Anyone install any after markets?
« Reply #1 on: February 16, 2014, 11:25 AM »
I got a kit of ebay. I think about 10 led (cluster of 3's) . I put two lines across top of van roof. No problem seeing at night or early morning now. I'll take photo tomorrow.
Kapex & UG, TSR55, MFT3, OF1400, C15, CXS, Carvex, Midi, T18, EHL65
Rts400, CTL26, TSC55,  BHC18
Offline 3PedalMINI
    • Signature Sound & Video
« Reply #2 on: February 16, 2014, 04:32 PM »
I am making my own for my transit connect.
I ordered this: http://www.ebay.com/itm/ABI-600-LED-Strip-Light-5M-Super-Bright-Double-Density-Warm-White-3000K-3528-/360828482084
and then ordered track and diffuser from here; http://www.aliexpress.com/snapshot/6019464987.html
all in im at about $110 bucks and ill have a custom lighting solution for the transit. Ill be sure to post pictures of how im doing it.
The Bitterness of poor quality remains long after the sweetness of low price is forgotten -Benjamin Franklin
Professional Custom Audio Video System Designer/Installer serving Southern - Middle NJ, Eastern PA & the Surrounding Shore Points.
www.sigsv.com
Kapex 120,TS55,RO150,ETS125,CT-26,CT-MIDI,Tradesmen Cleaning Kit, Festool Ratchet Kit, Sys-lite, Sys Roll Cart, T18 +3, 2013 Centrotec Kit, Carvex 420, Carvex Accessory Kit, CXS,RO90, TI15 and Various Festool Systainers
Offline jimbouk
« Reply #3 on: February 17, 2014, 04:06 PM »
I have pretty much the same thing, 12v led strip wired directly into the old interior lights, will get you a pic tomorrow.
BHC 18, TSC 55REB, OF 1400, MIDI, TS55, TRION, Df500, CSX...
Offline 3PedalMINI
« Reply #4 on: March 17, 2014, 12:25 AM »
Finished the lighting today!
Lights
This is at night, it is SUPER BRIGHT in there!!
I did a rail of light at the top of the exterior cabinet so i could see them better at night or in parking garages
www.sigsv.com
Offline galwaydude18
« Reply #5 on: March 17, 2014, 02:01 PM »
I have a 5metre led strip light that can be cut to length and joined together to loop it together. It has a transformer that goes from 240v to 12v. How would I wire that into my van?
Offline Wintoh
« Reply #6 on: March 18, 2014, 03:28 PM »
If I'm correct you should be able to wire this straight in without the transformer. But someone please put me right if I'm not correct
Offline Peter Halle
« Reply #7 on: March 18, 2014, 04:29 PM »
I checked a couple of my strips here in the house.  You should be able to wire them thru a fuse to a switch to your strips directly from your battery or from the van fuse panel if you have any spares.
Offline jimbouk
« Reply #8 on: March 29, 2014, 01:30 PM »
Use the existing cabling for you internal light, just replace the existing fitting with the 12v aftermarket. You wont need the transformer as vehicle already running 12v.
Best to disconnect battery first!  [wink]
