Author Topic: Kitting out my van  (Read 4092 times)
Offline jimbouk
Kitting out my van
« on: July 21, 2014, 04:04 PM »
Just starting out on kitting out the back of my new van a citroen relay lwb high roof (Promaster over the pond)
Has anyone got any advice or recomendations for isulating the back?
Thinking of flashband and celtotex then carpeting the ply boarding.
Anyone got links for buying the carpet for lining it?
Gonna fit leds for lighting and some kind of systainer racking as well as materials storage.
BHC 18, TSC 55REB, OF 1400, MIDI, TS55, TRION, Df500, CSX...
Offline E30Mark
Re: Kitting out my van
« Reply #1 on: July 21, 2014, 08:16 PM »
Always hear good things about http://www.megavanmats.com
And as far as soundproofing, chat with http://www.classicacoustics.co.uk
Offline jimbouk
« Reply #2 on: July 22, 2014, 01:39 AM »
Nice one cheers Mark.
Offline jonny round boy
« Reply #3 on: July 22, 2014, 07:37 AM »
Jimbo,
When I did mine I used flashband on the panels (for sound deadening), then celotex (50mm in most areas, and 25mm in the thinner bits). Sealed around the edge of the celotex with expanding foam, them stuck foil insulation over the top with gaffer tape, overlapping the joints, to act as a dpm.
Jonathan
TS55R EBQ saw - CTL26 - CTL Mini - OF1400EBQ router - KS120 Kapex SCMS - ETS150/3 sander - RO90 sander - DF500 Domino - PDC18/4 drill - PSC420 jigsaw - OFK500 trimmer
Offline jimbouk
« Reply #4 on: July 22, 2014, 09:45 AM »
Jrb thats pretty much exactly where I got to thinking with this. One of the boys on site just said hes got 3 sheets of 25mm celotex spare as well!
I saw your van on tranny forum. Nice job. I was looking for a tranny but even with the high roof couldnt stand up in it so went for this insted at around the same £.
Thanks for the help, i pick it up at the weekend. Will post up progress as and when it happens! Want to make it part time camper as well for summer hols and occasional working away.
Jimbo
« Reply #5 on: July 23, 2014, 01:17 PM »
Result! It's great when things like that happen. You will need to buy a bit more though, 3 sheets won't be enough.
I'm a shorta*se, so headroom isn't a problem for me!
I've stayed away in mine for a few nights now, and I hope you don't mind me giving you a few pointers that might help you planning yours:
1. Really think about how much space you have, and what you want to fit into it. I put a lot of thought into what tools I wanted in there, but very little about what camping essentials I needed & where they were going to go. One of the first things I bought was a porta potty, but I didn't have anywhere to store it so ended up putting it in the space for my CT Mini, directly behind the driver's seat. The Mini now lives up the back by the rear doors (tip: if you're going to have a toilet, you want to put it as far forwards as possible - you'd really be surprised how much more the back end bounces around - even during normal driving - and that leads to sloshing... [embarassed]). Think about where you're going to store all your food, cooking equipment, bedding etc. too.
2. Fit a (powered) roof vent - I haven't fitted one yet, and it gets REALLY warm in weather like we're currently having. I've been advised by another self-converter who I met on a campsite to fit a powered one (i.e. one with a 12v fan built in) which I'm going to do. That way, at the flick of the switch you can change all the air in the vehicle in just a few minutes.
3. What are you doing regarding windows? I'm getting the sliding door glazed (hopefully next week!). I think it will make a big difference to the 'feel' of the vehicle.
4. Do you want a night heater? I thought I did, but having spoken to others unless you're going to be living in it for days at a time in the middle of winter, it's something that you probably won't use much, if ever (and if you'll have access to mains you could at a push use a small fan heater).
5. Where are you going to be staying mostly? I've not yet stayed anywhere other than a campsite, where you have access to electric hook-up, showers, etc., so I don't really rely on the 12v electrics. If I was staying on a job site, I'd almost certainly have access to at least electric. If however you're going to be 'wild camping' in it, you need to think about 12v systems, inverters etc. more.
6. Are you going to sign-write your van? Be warned - if you do, some campsites won't let you on. Personally, mine won't be signwritten. In fact I'm hoping that once I get the side window, roof vent, and an awning fitted it will look more like a camper than a work van, and will therefore appear less of a target to thieves!
7. A few links to things I've got & would recommend:
I've just bought one of these powered coolboxes. It works off mains or 12v, and works really well. Much cheaper than a 'proper' fridge!
I've also got one of these too. It's a TV receiver that broadcasts the signal over Wi-Fi, so you can watch live telly on your phone or tablet.
Lastly, I bought these lights for the back. You can get cheaper ones, but they're not as good a quality. These are really nice, machined aluminium bodies, with very bright LEDs - so bright in fact, I'm going to buy a dimmer for them for over the bed area!
Offline jimbouk
« Reply #6 on: July 23, 2014, 02:36 PM »
Jonny,
Thanks for taking the time to post that. Great tips most of which I hadn't considered.
Im after the camper look more than van also but very much a newbie with it all. Was thinking of doing windows both sides and a roof vent of some sort. Not sure but had though bonded windows although would be good if they have a blind that can be attached.
If i do any sign writing it will be magnetic so i can take it down easily but never been that bothered with it.
The coolbox lights and tv thing look great cheers I will get on the case with them.
Im hoping to do a bit of a trip to europe next summer for some traveling and camping. Aside from that i have a few jobs in the pipeline that will involve the odd night or two each week away from home. There will be decent (ish) facilitys on site so just want to save the cost of hotels where possible.
I kind of like the idea of some kind of solar panel and inverter with lesure batt but unlikely to get used enough.
Also need to work out space planning. How i can make a bed easily removable to allow work van one min and digs the next!
« Reply #7 on: July 23, 2014, 02:47 PM »
Depends how you feel about sleeping in a hammock... [big grin]
Offline jimbouk
« Reply #8 on: July 23, 2014, 04:19 PM »
Depends on what or how much booze has been consumed. ;)
I hadnt actually thought of that but normally sleep on my front so might take some getting used to!
Offline jimbouk
« Reply #9 on: July 23, 2014, 04:20 PM »
Can see this is going to take some head scratching and lots of sketches. Also going to have to go through a list of tools and systainers.
