Author Topic: Kapex and CT Sys  (Read 2597 times)
Offline Route24Design
    • My Personal Blog
Kapex and CT Sys
« on: December 21, 2019, 10:37 AM »
Looking for a permanent dust extractor for my miter station.  Will the CT Sys be good for the Kapex?
Festool TS 55 REQ-F-PLUS
Festool OF 1400 EQ-F-PLUS
Festool CT MIDI HEPA
Festool CT Sys HEPA
Festool Domino DF 500 Q-PLUS
Festool PRO 5 LTD (ETS 125 REQ)
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Festool FS 1400/2 (x2)
Festool FS 1400/2-LR 32 Guide Rail
Festool LR32 Router Hole Drilling Set
Offline ChuckS
Re: Kapex and CT Sys
« Reply #1 on: December 21, 2019, 11:11 AM »
Any system (even a shop vac) used with a dust deputy AND a 36mm hose (not too long) is good for the Kapex.
« Last Edit: December 21, 2019, 02:21 PM by ChuckM »
Offline JD2720
« Reply #2 on: December 21, 2019, 04:51 PM »
Unless you put a small cyclone between the Kapex & CT Sys, the small bag in the CT Sys will fill up very quickly.
Offline Birdhunter
« Reply #3 on: February 26, 2020, 09:10 PM »
I use a dedicated Midi. The CT Sys is way too small.
Birdhunter
Offline SRSemenza
« Reply #4 on: February 26, 2020, 11:18 PM »
Not only will it fill quickly it has less suction than the other vacs. CT-Sys 106cfm, Mini/Midi 130cfm, CT26 36 48- 138cfm.
   More is better for the Kapex.
Offline Michel
    • Lyrk Tømrer & Snedker Aps
« Reply #5 on: February 27, 2020, 10:12 AM »
Make sure you use the big hose, that goes on the outside on the mouthpiece on the Kapex. Much more effective than the small 27 mm.
Danish carpenter and cabinetmaker, just me and my padawan :)
http://www.lyrk.dk
