Author Topic: I want one....  (Read 21313 times)
Offline jmbfestool
I want one....
« on: January 13, 2016, 09:33 AM »
Ive been looking at clamps and clamping systems.
I like this one! I like the versatility.  From Clamping frames to clamping carcases.
Only takes up 800mm in depth.
Does any one know another good system i could look at.
Does any  one know where i can get this in the UK.
Its bloody expensive so im only thinking about it.
I am pondering the idea of building my own because how expensive this system is.
Im sure i could make it all for a 1/3 of the price.
*********************************************************************** [thumbs up]UK members click me
Offline KescoNY
Re: I want one....
« Reply #1 on: January 13, 2016, 09:48 AM »
Awesome idea...
i wonder if they can be shop built on a wall out of mdf panels with 20mm holes so you can have as many panels as your space will allow for production work
Kapex/UG Cart/UG extensions TXS Set CXS Set PDC 18/4+3 BHC18 T18+3 Centrotec Installer's Set TS 75 TS55 TSC 55  Carvex PSC Carvex 420 & Accessory Kit  Domino 500 Set  Domino 700 set OF1010 OF 1400 OF 2200 & Accessory Kit  LR 32 Rotex 90 Rotex 150 Rotex 125  ETS-EC 150 ETS-EC 125 ETS 150 ETS 125 DTS 400 RTS 400  CT Midi CT36AC CT48 w/boom MFT3 CMS GE set with TS75, TS55, OF1400 plate  CMS VL
Offline neeleman
Re: I want one....
« Reply #2 on: January 13, 2016, 10:36 AM »
Maybe you can use a few of these oil bottle jacks and connect it with a baseplate to a vertical kind of MFT plate with holes.
Cheap ones are made in PRC and cost very little these days (€12).
« Last Edit: January 13, 2016, 01:55 PM by neeleman »
Festoolian since 1998.
FESTOOL:
OF1010R | AGC18 | TPC18/4 | TID18 | OSC18 | RTSC400Li | CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
CHP26 | VCP260 | DSC-AGP125 | DSC-AGP230 | DSG-AGP125 | DRP16
Offline KescoNY
Re: I want one....
« Reply #3 on: January 13, 2016, 11:49 AM »
Maybe you can use a few of these air bottle Jacks and fix it with a baseplate to a vertical kind of MFT plate with holes.
Few of the cheaper ones i used tend to creep down under low pressure but i was thinking something similar or even incorporating a porta power using 1 pump on multiple rams to even out the pressure
Offline jmbfestool
Re: I want one....
« Reply #4 on: January 13, 2016, 01:01 PM »
Hey they are cheap like that idea.
Im leaning more and more towards a self build.
I just cant get my self to spend so much on one.
It looks amazing and I would love one but why is is soooooo expensive.
Offline Thunderchyld
Re: I want one....
« Reply #5 on: January 13, 2016, 01:43 PM »
I've been looking for another manufacturer as well, no such luck here.  Some metalworking tables that are similar but make the Barth look cheap.
Bit of a project to put one together, but it's a fun idea.  Might have to start working on a design, make it the first big project once I finally purchase a full size CNC router.  Upgrading my shop and making room for either a 4x8 or 5x10' CNC table and related accoutrements is on the list, but there's two remodels and a screen porch I have to get done for family before I can work on my own stuff, lol.
Have you seen the RPG-V model?  It combines the regular table with a flip up vacuum press.  No clue on what they want for that one, lol.  Not like the regular multi is cheap, starts at $8,000 or so, keeps going up and up as you add more clamps and accessories.  I can't remember where I saw the figure, but the rack, cart and all the extra clamps shown in the video have a grand total somewhere north of $30,000.
Offline jmac80
Re: I want one....
« Reply #6 on: January 13, 2016, 01:53 PM »
Festool MFW - Multi Function Wall
James
Offline Kev
Re: I want one....
« Reply #7 on: January 13, 2016, 11:34 PM »
I can actually see JMB making his own ... probably three times the height and doubles as his reconfigurable rock climbing wall [big grin] [wink]
Offline jmbfestool
Re: I want one....
« Reply #8 on: January 14, 2016, 07:27 AM »
lol loving the rock climing function.
One of the things I would like is more heigh actually..  The Barth has a 1500mm limit height. Which isnt enough for lets say french door frames.
It can go upto 4m in length but unless i wanna make french doors for people of MY height i needs it to be taller.
2.4m clamping height would be ideal.  So I will be looking at desiging something with that in mind.
Offline Charlie Mac
Re: I want one....
« Reply #9 on: January 14, 2016, 07:40 AM »
Couldn't you orient the door horizontally for clamping?
Offline jmbfestool
Re: I want one....
« Reply #10 on: January 14, 2016, 08:16 AM »
Its not the door its the frame.
Example I made a a few doors this weeks and one of the frames for the pair of doors was 1600x 2090.
I wouldnt be able to clampe the frame because its clamping limit 1500 in heigh.
Most french doors are atleast 2000 in height and width is normal atleast 1500+mm
Offline Charlie Mac
Re: I want one....
« Reply #11 on: January 14, 2016, 09:20 AM »
OK, Gotcha.
Offline Kev
Re: I want one....
« Reply #12 on: January 14, 2016, 05:02 PM »
I'm thinking maybe a style of heavy gauge perforated steel sheet with a suitable hole pattern. Not only useful for clamping ... Could also be used as shelf bracket supports [big grin]
Offline Alan m
Re: I want one....
« Reply #13 on: January 14, 2016, 08:17 PM »
that's pretty cool
but for 30,000 for a full set . I would think your mad
you could build a whole array of dedicated assembly jigs and tables and a shed to put them in for that money
im sure you will build it for 10k or less.
a lot of the features are only showing off features that you could do cheaper other ways .
like gluing up worktops or wider boards
Offline Kev
Re: I want one....
« Reply #14 on: January 14, 2016, 08:43 PM »
that's pretty cool
I think it's a classic case of it being a niche product and having the typical niche price!
The thing in my mind is that your expensive station is tied up till the glue dries.
... wouldn't it be cool if there was a glue that stayed "wet" until you hit it with a signal, current, activator or something ... maybe a "sonic screwdriver" [big grin] so it instantly set. That'd save some time.
Offline Bohdan
Re: I want one....
« Reply #15 on: January 15, 2016, 02:22 AM »
In the early days of microwave (as in like a microwave oven) development I worked next door to a factory that welded thin sheets of plastic to produce things like raincoats. This was a large machine that on any particular cold morning would be surrounded by a happy bunch of women warming up their rears, by pressing them against the machine, while it welded away.
Nobody had heard of microwave radiation leakage or of its effects.
Microwave activated glues are a dim distant glow in the deep dark corners of my memory. I would think that they were abandoned for general woodworking use because of the difficulty of preventing the radiation leakage from cooking the operators but I do seem to remember that they worked very well and were very quick.
Offline Nippychippy
Re: I want one....
« Reply #16 on: January 15, 2016, 02:24 AM »
that's pretty cool
Funny you should say that Kev because they are developing and wood fusion system seen it on YouTube a few months ago it's based on metal fusion welding it's crazy it turns your joined piece  it one solid piece
Offline Nippychippy
Re: I want one....
« Reply #17 on: January 15, 2016, 02:28 AM »
Here's one link
Offline jmbfestool
Re: I want one....
« Reply #18 on: January 15, 2016, 02:50 AM »
that's pretty cool
You on about this kinda wood welder?? I wanted to buy one a couple years ago but that is another tool which isnt that cheap.  Only works with water based glues
My mate has one. He got his for £100 or from a company going under.  Jammy buggar
Offline jmbfestool
Re: I want one....
« Reply #19 on: January 15, 2016, 03:01 AM »
that's pretty cool
I know mental how much it cost when you add it all up.
Ive decided 100% to build my own.   I would have considered buying it if it was £6-7k with all accesories included.  Im sure many more people would be it.
Ive got a couple of welders and an aswome welding mask i bought.
So ill get onto welding some box section frame for the rear when i get time.
and get some box section with holes in and see how much £££ to have 6mm steel with holes costs or might just use 30mm birch and cnc the holes my self or maybe alluminium but thats expensive.
Offline Upscale
Re: I want one....
« Reply #20 on: January 15, 2016, 03:52 AM »
[quote author=jmbfestool
Ive decided 100% to build my own.   I would have considered buying it if it was £6-7k with all accessories included.  I'm sure many more people would be it.
I've got a couple of welders and an awsome welding mask i bought. [/quote]
Sure, you might be saving money on material by building one yourself, but you're putting in the labor building it and that has to be worth something too.
Offline jmbfestool
Re: I want one....
« Reply #21 on: January 15, 2016, 04:38 AM »
[/quote]
Yes thats very true!
However i believe material cost will be £2000 at most.  My dad isnt very good pratically but he can weld. Im pretty junk at it im still learning.  So i can get my Dad to do all the welding.... free
His job isnt very hands on so he loves working with his hands when hes off for a month at a time.  All i have to is design it for him and cut all the steel correct angles and sizes because hes not very pratical like that.
but still i dont think it would take that long to make it all and i would be saving well over 10k
If it took me a week to do i dont earn 10k a week lol
Offline Charlie Mac
Re: I want one....
« Reply #22 on: January 15, 2016, 07:36 AM »
I don't know where the 30K figure came from but this is what's showing in the US. It's still not tall enough for JMB and it looks like the package doesn't include everything shown in the video annnd the accessories are costly but it's a lot less than 30K.
Rangate Link
* Edit: It's really not clear what's included as far as accessories.
« Last Edit: January 15, 2016, 07:48 AM by Charlie Mac »
Re: I want one....
« Reply #23 on: January 15, 2016, 08:19 AM »
Charlie, I'll do some digging, see if I can't find the info link I got the number from.
From the summary I was reading a few months back, the initial price is just the frame and table, zero clamping elements.  Each of the uprights is $600 or $1500, depending on rack and pinion or hydraulic, $3500 for the lateral press portion, $500 per for each rack and pinion plug(of which the video shows 8 at one time) $4000 for the equipment cart, and so on.
Offline Charlie Mac
Re: I want one....
« Reply #24 on: January 15, 2016, 12:58 PM »
I think that if it came with nothing, that would end my consideration of investing in it.
Offline Nippychippy
Re: I want one....
« Reply #25 on: January 15, 2016, 01:19 PM »
that's pretty cool
That's the one I was Looking for jmb. You pal was a lucky bugger
Offline Upscale
Re: I want one....
« Reply #26 on: January 15, 2016, 02:56 PM »
Quote from: jmbfestool
Anyone know if the base sheet with all the holes is aluminum or steel? How readily are sheets like that available? And, when you finally get your hands on one, you lose half your mind drilling 5,000 holes in it.   :)
Offline Charlie Mac
Re: I want one....
« Reply #27 on: January 15, 2016, 04:51 PM »
From the Rangate site (although the holes don't look like 2mm):
Product Description
The perforated plate is made of solid 6mm steel, with 2mm holes at precise 50mm intervals. There's enough flexibility to support and press any shape or curve you can glue. Optional rack and pinion press elements can slot right into the plate like a pegboard, and exert pressure at any position and angle your workpiece needs.
Offline jmbfestool
Re: I want one....
« Reply #28 on: January 15, 2016, 05:20 PM »
Product Description
I tottally agree when i read 2mm my first thought was no way do they look like 2mm holes.
I thought might be miss type and they meant 20mm
Offline Kev
Re: I want one....
« Reply #29 on: January 15, 2016, 06:24 PM »
Product Description
They've got to be 20mm .. plus the "intervals" must mean 50mm between the edges of the holes, in other words 70mm centres
