Author Topic: I have a problem with my new shop I brought home today.  (Read 11083 times)
Offline wow
  • Inactive Member
Here is the problem. It's 24' long by 8' wide by 8' high. It's EXTREMELY well insulated:
106592-0
The problem is that there are no windows, no door, and no space inside. Do you suppose that's an issue?
 [wink]
Actually, this is the SECOND load of foam boards that are going on the ceiling in my shop. When it's done I'll have around R60 for my ceiling. Oughta make the heating bills a LOT less next winter...
Right now, though, it just looks like a great big stack of WORK!!!
Offline Tim Raleigh
    • Oakville Cabinetry
Re: I have a problem with my new shop I brought home today.
« Reply #1 on: May 22, 2014, 09:52 PM »
Wow, that's a load of foam!
Tim
Offline Greg Powers
  • Metric convert
    • Stargate Unofficiial
« Reply #2 on: May 22, 2014, 09:52 PM »
must be a very nice size workshop.
Greg Powers
Offline unityroad
  • photos
« Reply #3 on: May 22, 2014, 10:22 PM »
Hi, Was spray foam  ever considered? seals the gaps much better. Good luck with that.  [eek]
You are only as good as your ability to get PAID.
Offline wow
  • Inactive Member
« Reply #4 on: May 22, 2014, 10:29 PM »
It's 1800 Square Feet / 167 Square Meters.
Offline wow
  • Inactive Member
« Reply #5 on: May 22, 2014, 10:31 PM »
Yes, but to get the R-value I wanted was going to be like $16,000. I can do a lot of work and sealing for that kind of money!
Offline Kev
« Reply #6 on: May 23, 2014, 04:21 AM »
 [eek]
CRIPES!!
Offline batcave
« Reply #7 on: May 23, 2014, 06:21 AM »
An igloo?
To the batcave!
Offline Sparktrician
« Reply #8 on: May 23, 2014, 06:57 AM »
What, you couldn't find any green foam?  Whatsamatter you?  Just think of the Festool Cooler you could have with that amount of foam...
 [poke]
- Willy -
Offline fdengel
« Reply #9 on: May 23, 2014, 09:11 AM »
Or use some sort of spray foam to fill the gaps between these panels?
Offline leakyroof
« Reply #10 on: May 23, 2014, 09:17 AM »
 [poke]
  LOL........
Offline Thunderchyld
« Reply #11 on: May 23, 2014, 10:15 AM »
Heh, I've been in that situation before.  It's kind of weird having a load that big but that light.
Going to be in the situation again this summer, if we can ever come to an agreement on the property I'm trying to purchase.
The bldg I want to become my shop is pretty large, about 8k sq ft, used to be a manufacturing facility filled with sewing machines.  Has a couple of Modines, but they never insulated most off the building, standard block walls for most of it.  Some small parts are insulated, but those were the offices.  It also happens to need some roof repair, probably served best by a full replacement.  Then there's the second building on the property, needs more work, would add about 6k sq ft to the roof total.  Probably rent that one out or just let it sit as storage.  Could likely use a new roof as well.
IF, and that's a big if, I get the property, I'm also going to be picking up a full spray proportioner system for doing foam and coatings.  My reasoning behind this is fairly simple, as part of the negotiations re the property I've had contractors in to give me quotes on what needs to be done to make it work for me, and the roofing and insulation guys were insane.  First off, the spray insulation guys in my area won't do roof coatings, and the guys that do spray on roofing won't do insulation, so if I want things done that way, I need to use two contractors.  Secondly(maybe should be first, $$$ is important, lol) is the cost.  For insulation and roofing the two buildings, the quotes tally up to nearly $60k.  I can buy the other things I need for installing sprayfoam for under $20k, and materials should cost me about $15k.
Then of course, there's the fact that when we finally do get around to building our "cabin" on our camping land, I want to do a monolithic dome set into the hillside, and foam plays a big part of that structure.
« Last Edit: May 23, 2014, 10:53 AM by Thunderchyld »
Offline Kev
« Reply #12 on: May 23, 2014, 11:51 AM »
 [poke]
Now I have a metal image of wow's workshop being a giant T-Loc systainer [eek]
« Reply #13 on: May 23, 2014, 12:26 PM »
 [poke]
Well, from experience with foam, it can be dyed.  Fairly easily, all you need is RIT clothing dye.  Same stuff we used in school to make tye-dye shirts, lol.
Easiest method is to dip the foam sheets in the dye solution.  Last time I had to do this we made a 5x10' tray out of 2x4 and an old billboard tarp(coated PVC, I've seen roofing materials less durable than these billboards).
If you need/want to do it to foam that's standing/installed, it's doable, just requires two people.  One to spray the dye solution on with a misting sprayer, one to follow with a rag mop and sop up what doesn't soak in.   Going to get better color and saturation dipping, but it can be a pain trying to deal with that many sheets o foam dying and drying.
Offline wow
  • Inactive Member
« Reply #14 on: May 23, 2014, 07:21 PM »
Well, with the addition of the mezzanine I guess you could say it has an 'attic' lid?!
Offline Paul G
« Reply #15 on: May 23, 2014, 11:35 PM »
Wow, are those fire rated? If so I'd like the details on the product, I've got the opposite problem in a garage I want to keep cooler when it's 110 degrees in the summer. Also how do you attach it?
+1
Offline wow
  • Inactive Member
« Reply #16 on: May 23, 2014, 11:47 PM »
No EPS product is fire rated. In a habitable area you must cover it with something like sheetrock. In a detached shop like mine I can leave it exposed.
Ultimately I want to put a ceiling in there though...
« Reply #17 on: May 25, 2014, 01:27 AM »
Paul G,
You can get spray foam that's fire rated, but I don't know of a manufacturer that sells it in premade sheets.
There's also a variety of coatings designed to bring the fire rating of spray foam up to Class 1 standards, for example, Certainteed has CertaCoat, a latex based intumescent designed for their CertaCoat sprayfoams.
Offline wow
  • Inactive Member
« Reply #18 on: May 25, 2014, 01:45 AM »
Paul G,
There's also a variety of coatings designed to bring the fire rating of spray foam up to Class 1 standards, for example, Certainteed has CertaCoat, a latex based intumescent designed for their CertaCoat spray foams.
Certacoat is a nice product. Expensive, but nice. But it's an Ignition Barrier, not a Fire Barrier.
I am unaware of any spray-on coating that would make EPS suitable for a habitable area - AFAIK you must use a product like 5/8" firecode sheetrock. (P.S. my daughter is a state fire marshall and I grilled her on this as well.)
If you know of something, please let me know 'cause I'd be interested big time!
Offline RobBob
« Reply #19 on: May 25, 2014, 06:06 PM »
Ask your daughter about fire rated sheetrock vs. fire rated plywood.  I used fire rated plywood in my shop and have been wondering about the difference.
Offline allenwiggins
« Reply #20 on: May 25, 2014, 09:28 PM »
Wow… now you have to work!
Any day I get to make saw dust is a good day!
Offline wow
  • Inactive Member
« Reply #21 on: May 25, 2014, 10:28 PM »
Fire-rated plywood is suitable for a lot of uses/ Interior walls are one of those uses. Ceilings, however, are currently not allowed to be fire-rated plywood in habitable areas.
Offline wow
  • Inactive Member
« Reply #22 on: May 25, 2014, 10:32 PM »
Yes I do!
With my health being what it is, I can only work for a few hours each day so that load of stuff is gonna take a LONG time to work through. As long as I can get most of it in before the snow flies I'll be fine. But living in Minnesnowta, I should probably get going as I may only have another few weeks...
 [big grin]
Offline Asterix
« Reply #23 on: June 26, 2014, 03:31 PM »
(Attachment Link)
 [wink]
it doesn't like a big stack of work! IT IS!!  [big grin]
TDK 15,6 CE-NC 45-Plus | CS 50 EB Precisio + sliding table | RO 125 E | ATF 55 EBQ | BS 75 E | OF 1010 EBQ | CTL 22 | EHL 65 E-Plus | OFK 500 Q-Plus | PSB 300 EQ Plus | DF 500 Q-Plus | LR 32 system | SYS 1 CE-Sort | Toolie | many Festool accessories :-)
Walko workbench | SYSTAND | True32 metric tape | Qwas dogs | Kreg Jig
LEICA Lino L2P5 | LEICA Disto
Wishlist:  to less characters left...
