Author Topic: How do you store parts/fasteners?  (Read 13646 times)
Offline elfick
« on: March 28, 2019, 12:46 PM »
It's time to rein in my mismatched group of organizers... a bunch from HF, a Milwaukee parts organizer, a Tanos-branded Raaco rack-box (https://www.amazon.com/Tanos-80000061-Rack-Systainer-Rack-Box-Anthracite/dp/B00GQZJI5G), and couple others that I can't remember at the moment.
I have basically three use cases: Fixed in the shop, mobile in the shop or around the house, and mobile away from the shop/house.
I'd like a single matched system that will work in all these instances. Bins that can be moved between fixed, semi-mobile, and mobile carriers seem to be the way to go. To this end, I just put in an order for a Sys 4 Sortainer, Sys-Storage, and a few sets of bins... I probably should have asked this before I did.  [smile]
How do you handle your fasteners/parts? Also, does anyone know if there are comparably sized bins available elsewhere cheaper? If not, I can also just dump from other bins into my mobile bins if necessary.
Offline Dick Mahany
Re: How do you store parts/fasteners?
« Reply #1 on: March 28, 2019, 01:15 PM »
I use several metal drawer/storage units for most of my fasteners.  They came from Costco a number of years ago and cost around $80 for a four drawer set.  They are branded Thorsen and were originally filled with a large assortment of cheap fasteners, pins, o-rings, electrical connectors etc. most of which have been replaced with things that I'll actually use.  The boxes are removable and have carry handles and they also have rounded individual compartment bottoms for ease of fastener removal.  The down side is that they are quite heavy when filled.
I recently purchased two Festool Sys1 small parts organizers and like those also but they are on the pricey side for what they are.  I'd like to have a single system to store everything, but that isn't going to happen, so I'll just continue on with what I have.
Offline RKA
« Reply #2 on: March 28, 2019, 02:14 PM »
Sortimo T boxxes.  They don't tick the budget friendly requirement, but they work well for me.  Mostly I have small quantities of a lot of different stuff, so the shallow depth in these works nicely for me.  I need a clear lid to see inside, I want the lid to seal each container so small parts don't get tossed about and I want to be able to move containers between the boxxes to reorganize as needed.  As it happens the molded side runners on the boxxes will slide over a piece of 3/4" ply perfectly, so making a cabinet for them is an easy task (for standard 3/4" hardwood you'll need to shave them down a little to make them fit).  The hard part is sorting through my "misc" bins and emptying my other bin holding boxes I've accumulated (akro and keter).
In addition to that I do have some smaller plano boxes that I use for some misc car stuff (like hose clamp assortments).  The T boxxes are too large, and typically these would stay in my mechanics tool chest or the garage anyway, so sizing a box just big enough for what it needs to hold is better.
-Raj
Offline zapdafish
« Reply #3 on: March 28, 2019, 02:44 PM »
husky small parts organizer
Offline elfick
« Reply #4 on: March 28, 2019, 03:02 PM »
@RKA The Bosch iBoxxes were one of my finalists and I believe they are made by Sortimo. They are a way cheaper than the Festool options and are fairly available on Amazon. $35-$55 per container. The only reason I didn't go with them was that I would have to come up with my own way to carry/integrate them in a mobile situation.
@zapdafish I looked at a Husky organizer. They have a single layer organizer with like 12 bins that's only $10 and locally available from HD. The only problems I had with it was that it didn't look like it would do well with small stuff (washers and the like) or small quantities as they would require some kind of sub-divider like baggies and also the lack of integration. It was definitely the price leader in what I looked at and I may still use it for my fixed storage needs and just dump from their large bins into the smaller Festool bins.
I also considered the Allit products from Lee Valley and was close to going with them based on price.
Offline RKA
« Reply #5 on: March 28, 2019, 03:20 PM »
They absolutely don't integrate with Festool systainers, they have a larger footprint (more on that in a second) and no integrated latching which is one of the biggest drawbacks.  But you could build a small box with casters that would hold 3-4 T boxxes.  On top you could cut the recesses to accommodate a smaller footprint systainer and try to add latching to lock a systainer on top.  It's a lot of messing about for something that's expensive to begin with.  Ideally, you would keep what you need for a job/task in a single box (or rearrange in advance if needed) and just carry it solo with the briefcase style handle.  If you needed other common supplies, you keep several of these racked in a van and organized by task.  The different size bins are really great for this.
-Raj
Offline SRSemenza
« Reply #6 on: March 28, 2019, 04:43 PM »
I use several different things. But I would say that Raaco fits for your purpose. They can easily be fixed shop, semi-mobile, mobile. The modularity makes them completely transferable and re configuring is a snap. EX- when adding in a new size of screw or what not.  I have my shop screws (except for bulk extras / refills), and my mobile screws in Raaco. I can take just a couple containers or a whole rack box. They happen to work nicely in tool box drawers too.
I do use Plano for all sorts of misc. hardware and such. Cost wise if it could all be Raaco it would be. But I don't use or move the misc. to justify it.
I also have some parts sorter bins for larger misc. stuff.
Raaco makes boxes to hold smaller quantities of "compartment / containers" too. Sometimes those are good for just taking a few sizes.  And there are about twice as many size compartments available as what comes with the Tanos Racktainer. Basically every modular increment in both row and column is available.
Offline elfick
« Reply #7 on: March 28, 2019, 04:49 PM »
@SRSemenza Which Plano model do you use?
Offline SRSemenza
« Reply #8 on: March 28, 2019, 09:37 PM »
Actually the ones I have are branded for Bass Pro but made by Plano. They are the 3700 series in 2" height. With up to 48 compartments (adjustable in increments). I am not sure the exact same model is still made. But there are several in the 3700 size series with varying compartment division schemes.
I saw that Bass Pro (in store) had stacks of them on sale a couple weeks ago. I did not look closely to see if they were the exact same model. But if still on sale they were a good price at $3.99.
« Reply #9 on: March 28, 2019, 10:46 PM »
I've used Plano for years, they're cheap and readily available. The down side are they have no handles and the partitions are easily moved accidentally when removing fasteners with your clubby fingers. This results in the partitions being elevated and the fasteners being mixed up. Worse yet is when the partitions cannot be pushed down by hand because there are fasteners underneath them, the cover will not close and you then need to remove the fasteners with a tweezers to realign the partitions.
Despite these issues the Plano work well...just use a tweezers or a needle nose pliers.
I also have some Raaco style (Durham) drawers that are all metal and they are the charm. They slide into their own cabinet, have handles and they're sweet. I just can't afford them for all the fasteners I have.  [tongue]
« Last Edit: March 29, 2019, 10:50 AM by Cheese »
Offline SRSemenza
« Reply #10 on: March 29, 2019, 12:08 AM »
I keep a 3/4" x 6" long dowel with a round self adhesive magnet on the end on top of the plano rack. Makes fastener retrieval easy.  [thumbs up]
Offline Vondawg
« Reply #11 on: March 29, 2019, 06:59 AM »
darn....you guys are walking hardware stores........nice organization!
« Reply #12 on: March 29, 2019, 10:23 AM »
Great idea Seth...  [thumbs up]  ...one small issue, those socket head cap screws are all stainless.  [tongue]
Offline Sparktrician
« Reply #13 on: March 29, 2019, 10:40 AM »
@SRSemenza, who sells the Raaco products in the US?  I really wish that Festool hadn't discontinued the Racktainer.
- Willy -
Offline Dick Mahany
« Reply #14 on: March 29, 2019, 10:44 AM »
@Sparktrician Lee Valley sells the Tanos version of the Racktainer if you don't mind the blue.
Offline SRSemenza
« Reply #16 on: March 29, 2019, 11:07 AM »
Not the easiest to find in the USA. I know I got some through Ebay. At one point there was a USA retailer with a limited selection. I also had someone in UK buy and ship to me.
Here is the Raaco site that shows all the inserts. The 55 series is the height for the boxes that come in a Racktainer. The series number is the height in mm. Two 27s will stack to the 55 height and are the modular foot print of one of the 55 sizes. In looking at the series 55 they show ten different ones. But I am pretty sure I have more sizes than that. Maybe Raaco has reduced the options. Not sure.
https://www.raaco.com/productsgroups-1120.aspx?GroupID=Indsatse
Offline rvieceli
« Reply #17 on: March 29, 2019, 11:12 AM »
@Sparktrician
There's a pretty good selection via Amazon though a lot of it is from a third party seller. Don't know if the prices are in line or not.
https://www.amazon.com/s?k=raaco&ref=nb_sb_noss_1
Ron
Offline dicktill
« Reply #18 on: March 29, 2019, 11:24 AM »
I strongly second the use of the Raaco units. I bought out the last of the ones Lee Valley had in '13-'14. Expen$ive, but worth it for me.
When I needed some more, I bought them from "Newark element14" (https://www.newark.com/w/search/prl/results?brand=raaco). IIRC, the shipping was expensive, but the same whether I bought one or four "quad" units; guess which way I went?
Dick
Offline Richard/RMW
« Reply #19 on: March 29, 2019, 11:55 AM »
Schaller makes/sells a version of the individual bins that are pretty reasonable.
http://www.schallercorporation.com/
Depths are sized to fit standard rolling tools bins, nominally 1"/2"/3" deep and widths nominally 1"/1.5"/2"/3"/4"/6" by varying lengths up to 12".
I recently moved my fasteners from those bins in drawers to Raaco/Plano type boxes wall mounted in cubbies similar to Seth's. I needed the floor space to cramp the welding table in. In my case I never take anything out of the shop so I opted to go cheap (still questioning that decision) and went with, uhmn... Harbor Freight:
https://www.harborfreight.com/19-bin-portable-parts-storage-case-93928.html
https://www.harborfreight.com/24-divider-storage-container-94458.html
They are OK in terms of holding the load full of screws/bolts/etc. but if I ever drop one I'm expecting a major mess. I wouldn't use them for a mobile application. 30 of the large boxes and another 8-10 of the smaller ones set me back around $300 total.
Where I'm regretting the choice is after building the cubbies I don't think I could ever justify revamping with better boxes. I could probably walk away from the $300 and replace them someday with better boxes but I don't want to take the time to rebuild the cubbies. Doing it again I would invest a couple hundred bucks more and get better boxes.
RMW
« Reply #20 on: March 29, 2019, 01:00 PM »
@Dick Mahany, thanks for that!  I didn't think of that option.   [smile]
- Willy -
Offline GoingMyWay
« Reply #21 on: April 03, 2019, 10:59 PM »
I'm late replying to the party.  I use Bosch (Sortimo) to store my small parts.  Adam Savage was my inspiration (http://www.youtube.com/watch?reload=9&v=1OPSbF6kM9k) for initially investing in the Sortimo system (specially branded Bosch since it's easiest to get in the US).
It is really nice to just be able to remove the individual bin of specific screws that I need rather than needing to take out the whole box.
Inquiring Minds Want to Know
Offline badtoytrd
« Reply #22 on: April 07, 2019, 11:21 PM »
Here is the idea I came up with. Used shelf pins and organizers from Harbor Freight. It's still a work in progress. Similar to DIY sys port and I am going to add drawers to the one for my systainers.
Offline kent B
« Reply #23 on: April 08, 2019, 10:11 AM »
 I also use the Bosch _L boxes. Buy them from CPOoutlets.
Cpo offers reconditioned L Boxes for $32.00 - $35.00 each , usually are L Boxes that have been used at trade shows - all the reconditioned items CPO sells offer 120 return policy also NO FINE print in the return policy.
Offline AndrewG
« Reply #24 on: April 08, 2019, 06:42 PM »
Anyone using sortainers to store small parts? I got a 6 drawer sortainer a little while ago but haven’t really found a use for it. I like having my screws in the Sys 1 assortment box with the coloured bins. Maybe someone can show how they use theirs to give me some inspiration!
Cheers
Offline deepcreek
    • TimberFire Studio
« Reply #25 on: April 08, 2019, 08:21 PM »
I've become a big fan of the Milwaukee 10 compartment deep organizer.
They stack like Systainers and the removable trays are easily reorganized.
I buy them at Home Depot for $25 each.
https://www.homedepot.com/p/Milwaukee-10-Compartment-Red-Deep-Pro-Small-Parts-Organizer-225046/205847797
Joe Adams
TimberFire Studio
Houston, Texas
Offline Knight Woodworks
« Reply #26 on: April 09, 2019, 04:43 PM »
Nice Joe. Where did you get the horseshoe shaped shims?
John
Offline Kevin C.
« Reply #27 on: April 09, 2019, 09:55 PM »
In the shop and in the truck I use Dewalt and Stanley boxes with the removable inserts. In the shop, I built this so I can leave them all in drawers and not have the boxes on the bench.
Offline SRSemenza
« Reply #28 on: April 10, 2019, 09:40 AM »
For the shims topic please follow link ---------------------->
                       http://festoolownersgroup.com/building-materials/thin-plastic-shims/
Offline Mark Katz
« Reply #29 on: April 10, 2019, 11:39 PM »
I use the Infinite Divider System by Flambeau which is sold by Lee Valley http://www.leevalley.com/us/wood/page.aspx?p=32178&cat=1,43326. Several decades ago I built a 24" wide cabinet for use with bins. The inside width of the cabinet is 22 1/2" which fits two of the boxes, side by side.
Offline Andersrl
« Reply #30 on: July 06, 2019, 06:05 PM »
I built a cabinet to hold Stanley hardware containers. The cabinet is sufficiently sturdy to hold the weight and the individual containers readily slide out to carry around the shop.  There is a built in keyboard tray that doubles as a pull-out shelf when I want to take out specific hardware sizes.
Offline broseiden
« Reply #31 on: July 07, 2019, 02:50 AM »
Dewalt Tough System organizers -- I bought 3, ditched two of the boxes themselves but kept the modular containers, and built shelving to hold them in my trailer. The idea was that I could grab whichever fasteners / containers i needed, put them in the tough box, and they'd be spill proof, water proof etc. In reality though I never used the tough box and got rid of it as well.
Now I keep a sys-roll with a few sortainers and transfer the contents from my shelves to the sortainers as needed. I do wish I had some bigger drawers on my sys-roll as I cant even fit my Dewalt impact without removing the battery, but it's still the best method I've found so far.
Offline WillAdams
« Reply #32 on: August 05, 2019, 02:43 PM »
My needs are a bit more modest and small scale than shown thus far, so I standardized on the 18 compartment small organizers from Harbor Freight --- they're affordable enough that whenever I'm passing by, if I have time, I grab one w/ a 20% off coupon.
Since they're transparent, labeling isn't an issue, and they stack neatly enough, and mostly fit in other containers well, so have worked out (for example, I have all my archery stuff in one in an inexpensive plastic toolbox).
All of the odd containers are gradually getting pushed off to odd uses, or discarded/replaced as opportunity comes up.
Offline Bob D.
« Reply #33 on: August 06, 2019, 06:17 AM »
If you're at HF don't pass up one of their small parts sorting trays, very handy.
I got one similar from somewhere (might have been Rockler)  years ago and
keep it in my parts cabinet.
https://www.harborfreight.com/easy-sorter-funnel-tray-37081.html
Offline Rob Z
« Reply #34 on: August 06, 2019, 10:21 AM »
OP, that looks like a great solution.  I have about the same number of the larger Stanley containers, but mine just ride around the shop floor on top of two Grizzly skates (don't know the proper name-it's a piece of plywood with casters).
Offline vkumar
« Reply #35 on: August 06, 2019, 11:48 AM »
@WillAdams please share the link to the harbor freight item
Vijay Kumar
Offline WillAdams
« Reply #36 on: August 06, 2019, 12:37 PM »
It's these:
https://www.harborfreight.com/18-divider-storage-container-94456.html
I find them small enough to sort pretty finely (a specific size of metric hardware for instance), but large that there isn't much overlap until I get into the larger fasteners (1/4"-20 covers 3 containers I think).
Offline ryanjg117
« Reply #37 on: September 10, 2019, 09:32 PM »
@kent B How often does CPO Outlets have the recondition L boxes? I don't see any right now, but maybe I'm not looking at the right spot. Also, what size L boxes are you mentioning priced at $32-35?
Offline kent B
« Reply #38 on: September 11, 2019, 10:24 AM »
call CPOoutlets , if no recon L boxes on website , when you call voice mail asks you to press ext. no.of person , I usually order from Dennis -ext.27106 - Dennis will check or contact you when some recon L Boxes are available. I prefer LBox 2-3-4 , other sizes available.
 Have purchased from CPO for a number of years always very well satisfied , never had a problem .
Offline Dusty.Tools
    • Dusty.Tools
« Reply #39 on: September 13, 2019, 08:16 PM »
I just took delivery of 50 Auer boxes :)
@dusty.tools
Offline tekbench
« Reply #40 on: September 25, 2019, 01:08 PM »
I'm in heavy with the Milwaukee bins. About 20+ of them. One thing that would be really nice - a clip adapter to throw a stack of these on a systainer. IF you lock more than 4 of these they get really heavy fast, but the think I really like is you can open each one while they are still latched together.
The old style Lboxx can't do that. (the brand new ones can apparently).
Systainers obviously can, but they are literally 4 or 5 times the price.
My local Home Depot has them for $19 on occasion, so I buy a few at a time.
the NEW packout system is apparently taking over. I don't know how much longer they'll sell these deep bin organizers.
(Attachment Link)
Offline rst
« Reply #41 on: September 25, 2019, 05:01 PM »
Tekbench, I too use the Milwaukee parts bins.  I just wish they had an adaptor that would allow connection to the new packouts which I have been buying as I like them better despite the price tariff but I only buy them on sale usually from Acme Tool.
Offline dupe
« Reply #42 on: October 03, 2019, 08:38 AM »
I've invested in quick a few L-Boxx when I see them pop up on Craigslist - the last set I bought was from a college lab professor witch came with 3 L-BOXX-1A with 13 inserts - these are fantastic, but I wouldn't buy them new given the price, form factor ( a bit clunky for small parts), and if I wasn't already using this system.
I would absolutely buy the L-BOXX-3D with the thin drawer and thick drawer. This is my most grabbed case witch holds an impact/drill combo up top and the majority of the fasteners/bits I'd need. Getting off topic, but all these cases have held up really well and containers don't shift or throw parts everywhere - great for mobile and serve me well for hobby carpentry.
305068-0
Looking for containers with a bit more capacity, I just stumbled across this bundle set which seem pretty reasonable.
305066-1
 The large case butterflyies open and the container size(s) look perfect for more than a handful of longer screws for decks/framing (2.5-3.5"). It also has eye holes for wall hanging up or down. The hardware case looks perfect for electrical connectors. Not sure I would use it, but the belt clips on the containers is a nice idea. Wonder how they hold up given more moving parts. On that note: these FastCap Power Mags are a real game changer. Years on my impact through dirt and drops - pricey but on several of my drills now. Similar to Festool, you have buyers remorse until you use it..
« Last Edit: October 03, 2019, 08:52 AM by dupe »
MFT.1080    CT.Midi    DF.500    DTS.400    ETS.EC150/3    RO.150    RO.90    CXS 10.8
Offline JJ carpentry
« Reply #43 on: October 15, 2019, 12:43 AM »
Do you know if they ship to canada?
Offline ChuckM
« Reply #44 on: October 15, 2019, 01:47 AM »
You can get Scotch extreme mounting tape (Canadian Tire or HD) and attach a large rare earth magnet or more to your drill.
Offline Bob D.
« Reply #45 on: October 15, 2019, 04:13 AM »
But will it cost you $22 ?
Offline ChuckM
« Reply #46 on: October 15, 2019, 05:18 AM »
Much less. Tape is about $7 Cdn, long enough for 30 to 40 drills (1" tape per drill, say). Just add the cost of one to two 1" rare earth magnets per drill. I've been using this kind of trick for years.
« Last Edit: October 15, 2019, 05:23 AM by ChuckM »
Offline Bob D.
« Reply #47 on: October 15, 2019, 06:23 AM »
I figured as much, I was making a funny. :-)
$22 for a magnet and some double stick tape is highway robbery.
Offline guitarchitect
« Reply #48 on: November 11, 2019, 09:38 AM »
Another vote for Plano 3700 boxes! I'm a shop-based hobbyist so I don't need to throw things in a van or around a jobsite, which probably makes a big difference. I buy the ProLatch boxes at Canadian Tire - I love that they are modular and all sorta fit together. If you aren't picky about optics you can get a plano bag that they fit neatly within - it'll just have fish on it rather than a tool name :)
I too found that the dividers pop out easily... a dab or two of CA fixes that easily, and it's not so much that you can't pull it out if you need to. The things come with so many dividers that I have more than I will probably ever need! I also find that I don't really move them, ever, because once I find a place for the hardware, that's where it goes.
In the attached pic, each of those is holding a full pack of 50/100 pcs, so they really are the right size. I have one for #6/8, one for #10/12 of both pan head and countersink, a box for 1/4-20 and 5/16 hardware, and a few for random parts. I have other random holders that I bought infrequently at LV which, by the time I needed more, LV had discontinued... so I kinda swore off the specialized stuff in favor of a more universal system that was likely to stick around!
Offline WillAdams
« Reply #49 on: November 11, 2019, 10:13 AM »
Does anyone have a comprehensive list of the Plano organizers, their sizes, maximum/minimum number of compartments (and the sizes of the compartments) and availability of accessories/holders?
« Reply #50 on: November 11, 2019, 11:52 AM »
their website has a good amount of info! "Pro-Latch" are the minimum I would consider for fasteners/tools, the original uses a latch system that wouldn't hold under deformation of heavy stuff.
https://www.planomolding.com/fishing/stowaway-utility-boxes/prolatch
The sizes work with each other - so the 3700 has a regular, thin, deep, and half-size version which all work together (14" module). 3600 has its own design and full/half size (11" module). Unfortunately I don't recall seeing an "overview" that would show the various sizes and options all in one place.
Offline todd_fuller
« Reply #51 on: November 11, 2019, 01:47 PM »
I use the 'small' metal Durham ones. I have two stacks of 6. Lots of internal divider options to pick from. Made in USA of sheet metal.
I also have a bunch of their plastic ones which I use for electronics parts as well as LEGOs. They're pretty good too. I'm not sure I would trust them full of washers or something heavy though.
I usually buy from zoro.com using a coupon. ~$150 per stack.
Offline mike_aa
« Reply #52 on: November 11, 2019, 02:51 PM »
Cabela's sells them and I found this link that shows some of the sizes.
I hope this helps!
Mike A.
Offline Lincoln
« Reply #53 on: November 11, 2019, 03:38 PM »
@Dusty.Tools - did you order these direct from Auer? How do you like them?
Offline WillAdams
« Reply #54 on: November 11, 2019, 03:53 PM »
That helps a lot. Thanks!
Offline grobkuschelig
« Reply #55 on: November 11, 2019, 05:12 PM »
I mostly use a mix of the Festool SYS-Box Systainers, some Auer Boxes for Electronics stuff and a couple of the „clear“ Sortiment boxes shown in other posts above.
I like the Systainers with the colored boxes the most.
Best to carry and fitting to the stacks.
Although the Auer boxes are also quite nice with the clear lids...
Offline Dusty.Tools
    • Dusty.Tools
« Reply #56 on: November 11, 2019, 08:33 PM »
I’m very happy so far, really no complaints to be honest. If I lived in the EU I would highly recommend trying them out.
I wrote a review up on ToolGuyd:
https://toolguyd.com/auer-packaging-assortment-boxes-for-organizing-small-parts/
Getting them to the US is a pain. I use my brother to forward them on from the UK but shipping adds 40% to the cost! But Auer will then refund the tax. They still end up being a good price when compared to the alternatives.
Ben
@dusty.tools
Offline Dusty.Tools
    • Dusty.Tools
« Reply #57 on: November 19, 2019, 02:17 AM »
And here’s how I’m going to label each box:
@dusty.tools
Offline DynaGlide
« Reply #58 on: November 19, 2019, 05:57 AM »
The black on blue painters tape is the way to go   [cool]
Instagram @matts.garage
Offline Bert Vanderveen
« Reply #59 on: November 19, 2019, 07:07 AM »
This is how I label my Auers: A number and a bit of text that makes sense to me. All in vinyl.
Also: everything in the boxes is inventoried in a spreadsheet that 'lives' on an iPad in the shop.
Note that some are not numbered yet. It is an evolving situation (in flux…).
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set (next June!) … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950 | TaigaTools VacPods Pro Set
« Reply #60 on: November 19, 2019, 03:04 PM »
(Attachment Link)
Love this idea! Especially the inventory. I can never remember what I have or don't have, let alone where it is stored... especially when it comes to misc stuff. Using an app like Evernote (or a Google doc) would let you access it from any device
Sent from my SM-G973W using Tapatalk
Offline Dusty.Tools
    • Dusty.Tools
« Reply #61 on: November 19, 2019, 03:22 PM »
(Attachment Link)
Agreed! I’m thinking I will merge both designs :)
@dusty.tools
Offline Dusty.Tools
    • Dusty.Tools
« Reply #62 on: November 19, 2019, 03:49 PM »
It’s an A/B test :)
@dusty.tools
Offline threesixright
« Reply #63 on: November 19, 2019, 04:26 PM »
@Bert Vanderveen
If you close the lid of the augers, do they close well or is the content all over the bins when you’d shuffle box a tad to wild?
It’s what I hate about many of these systems.. either expensive or the individual bins aren’t closed properly.
Thanks!
« Reply #64 on: November 19, 2019, 04:55 PM »
Another thing I did was to use different colour boxes for different materials, eg in the "Pozidriv screws" Auer box most are galvanized steel in yellow boxes, but the stainless steel ones are in blue boxes. And of course everything arranged according to screw size and lengths.  [smile]
« Reply #65 on: November 19, 2019, 05:01 PM »
@Bert Vanderveen
Thanks!
They close well, though it takes somewhat of a coordinated action - you need to press both corners together with some force. Also, the grid lines on the transparent cover help fixing the boxes in place. With the ridges in the bottom this makes for hardly any rattle.
As you may be able to tell, I really like the Auer boxes. I also own some of their toolboxes and these lock together, somewhat like systainers, but more simple. Pressing down the handle locks, pulling it up unlocks. With a lot of accessories like trolleys (and the range is expanding all the time) — the Auer range is a more complete system of storage options than systainers (boxes configurable with drawers are also available).
« Reply #66 on: November 19, 2019, 05:25 PM »
@Bert Vanderveen
Thanks!
Thanks! You confirm what I already thought. I would like one system, this seems a good and reasonable priced solution.
Offline mrFinpgh
« Reply #67 on: November 20, 2019, 05:38 PM »
Ben
Ben,
Was Auer unable to arrange shipping?  I looked at the site and it seemed like they did provide it, but your feedback suggests they do not.
I was surprised that after requesting a quote, I received a book worth of marketing material from them.  I would think given that level of follow up, they would be positioned to arrange shipping?
They do look like a great option.
Thanks,
Adam
Offline Made by Mike
« Reply #68 on: January 15, 2020, 09:14 PM »
Kaizen makes a kit with bits that attach to the classic organizer so it will mount onto a packout set. unfortunately it'll only allow mounting on classic on the top of the packout stack and you'd have to mount your other organizers to the first adapted one to bring more along with you.
Here's a link: https://kaizeninserts.com/t/knex
If you search google or instagram you'll also find various people out there that have 3d printed these same bits. Free plans are available online, you just need to find access to a 3d printer. My town's public library has one for use and it's cheap, you might be lucky enough to find the same scenario. :)
