Author Topic: Have a look at how I did the lighting in my shop.  (Read 11211 times)
Offline David Stanton
  • Festool Dealer Affiliate
  • Carpenter & Joiner, Photographer, Youtuber.
    • David Stanton
« on: August 08, 2016, 04:49 AM »
I have refined the process of lighting through creating 3 new shops over the past 20 years. I hope you can pick up some tips by watching the video. [smile]
« Last Edit: August 11, 2016, 05:17 AM by David Stanton »
Click here for Dave Stanton on Youtube
KAPEX 120, ROTEX 150, TSC55, 800-1400-2700 TRACKS,  PDC 18-4 TEC, DOMINO XL, Domino 500, CXS, TXS, EHL 65, SYSLITE, HKC 55 EB, PSC 420 EB, CTL SYS, SYSROCK, 2 x CT 26, OF 1400, RTSC 400, OSC Vecturo 18V
Offline Holmz
Re: Have a look at how I did the lighting in my shop.
« Reply #1 on: August 08, 2016, 05:57 AM »
Ohh I like it.
Offline bdiemer
« Reply #2 on: August 08, 2016, 09:38 AM »
Thanks so much for the informative video. My shop is not attached to the house. I thought about digging line to light my path but those small solar lights would save me a lot of trouble.
Offline Sparktrician
« Reply #3 on: August 08, 2016, 06:54 PM »
The lights I want are these LED fixtures.  I've seen them and they throw some tremendous light.
- Willy -
Offline Brent Taylor
« Reply #4 on: August 09, 2016, 08:36 AM »
I'm in the process of building a small shed to store my tools and lawn stuff, I placed a 4' , 4 bulb florescent light and still had a dark alcove, so I installed a porcelain socket with a 60 watt equivalent led blub. Huge difference!  I'll be changing the other out asap.B
« Last Edit: August 09, 2016, 10:29 AM by Peter Halle »
Offline Woodwork Wizard
« Reply #5 on: August 09, 2016, 12:14 PM »
The best light is daylight, so anyone building their own workshop, have the entire roof (or as much as possible) made of clear polycarbonate. You won't need any windows so you'll get more wall space too.
« Reply #6 on: August 09, 2016, 12:47 PM »
And in that regard, the Solatube is wonderful for bringing in natural light.  When it's dark out, I'll go with the LED lights.
- Willy -
Offline PreferrablyWood
« Reply #7 on: August 09, 2016, 04:43 PM »
Excellent info, I'll keep these tips in mind!
TS 55 R EBQ, Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, OF 2200, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,
Festool 18V HKC 55, TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus   TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3
Offline Holmz
« Reply #8 on: August 09, 2016, 04:58 PM »
How much are they?
They give no information on that.
When I saw location-UK I chuckled.
« Last Edit: August 09, 2016, 05:00 PM by Holmz »
Online rvieceli
« Reply #9 on: August 09, 2016, 05:21 PM »
Offline James Metcalf
« Reply #10 on: August 09, 2016, 05:49 PM »
My shop is 40' x 60' with 16' side walls. I built it about two years ago. I used four of the high bay Big Ass lights. You could not want more light and my light bill is never over fifty dollars each month. The saying " Cry once and then it is over" applies here.
« Reply #11 on: August 09, 2016, 06:11 PM »
@Holmz
Here's a link to the store:
https://store.bigasssolutions.com/lights?_ga=1.30783359.139266014.1470747652
BUT USD $400 to 570
Yup.  One thing they're not is cheap.  Really good, but definitely not cheap.
- Willy -
« Reply #12 on: August 09, 2016, 06:17 PM »
Interestingly enough, the Bad Arse lights are available from Home Depot for $400.
Offline Motown
« Reply #13 on: August 09, 2016, 06:39 PM »
Well done! That is a great looking shop you have there....
Offline teocaf
« Reply #14 on: August 09, 2016, 09:07 PM »
here's another recent shop lighting setup.  has anyone else tried these low profile led lights?  i'm also looking to get away from the fluorescents.
« Reply #15 on: August 09, 2016, 11:30 PM »
@teocaf
Sweet...I've missed some of your lengthy, comedic and interesting dissertations...just kind of confused, why did you need to populate the box with those many drivers? Couldn't you have driven that array with 1 gigantic driver or several more powerful drivers?
Offline Kev
« Reply #16 on: August 10, 2016, 02:48 AM »
Another interesting thing that's touched on is solar power .. leads to the obvious storage complications. Anyone he got serious about storage?
Offline IWANTBLUE
« Reply #17 on: August 10, 2016, 03:46 AM »
Do this ggat gave fluorescent not use high frequency with rotating tools etc?? Especially lathes and the like?? Some fluorescent can give the effect of a still chuck/blade etc.  At the wrong speed...
Offline Grakat
« Reply #18 on: August 10, 2016, 07:09 AM »
Only on single tube fittings. A double tube fluro fitting will not give a strobe effect to a machine. I have worked on lathes where a double fitting was hung over it....no problem. However the single tube fittings can generate a stroboscopic effect, making moving machinery appear stationary, but only at certain speeds.
Regards
Graham
Festool ETS150/3, TS55, CT26, DF500+ Domino set, PS300, HKC55, RO150
Offline Holmz
« Reply #19 on: August 10, 2016, 08:19 AM »
Do LEDs not flicker/strobe as well?
« Reply #20 on: August 10, 2016, 09:14 AM »
I regularly use a small metal lathe (just yesterday) under a pair of 8' fluorescent lights and also have a powerful LED task light pointing at the chuck area where the part I'm turning is mounted. Both are powered on the 60 Hz mains without any strobe issues effecting the lathe. Just lucky??? Dunno...
Offline teocaf
« Reply #21 on: August 10, 2016, 11:31 AM »
@teocaf
@Cheese
thanks for the shoutout.  i should make it clear that the video link i posted was not my shop lighting, but rather something i found recently on youtube that addressed this thread and also my concerns as i'm now trying to individually replace some of my dying fluorescent ballasts with the led option.  i don't have an answer as to why the guy is using so many drivers for individual strips, but if anyone here knows or has better solutions, i would also be interested in the info.
i've only got 2 led lights so far in my own shop:  one that i got on sale from rockler exactly like the one mentioned in this thread, and it replaced one crapped out fl. ballast.  so far it works great and i hope it lasts as long as the hours it's rated for, because as i understand it, you just throw them out after that unless you find a way to retrofit them with fresh led strips.  the other one is a short modular one i got from home depot and it goes over one my workbenches.  it also replaced a fluorescent that i kept having to smack every time until it lit.  the new one is meant to take additional strips in a chainlike fashion.  as expensive as they are, they do have some nice advantages and can be moved around easier as the shop evolves or moves.  perhaps that is one reason that the dude in the video decided to have them all individually driven.  i'll be looking at this and other lighting threads as i'm mulling over my own needs.
as to the lack of sparkling commentary from me on this forum, it's probably a combination of reasons, but no need to derail the lighting thread.  still, i hope to see some of you foggies at festool connect soon.
Offline Richard/RMW
« Reply #22 on: August 10, 2016, 05:46 PM »
I received an email ad from Global Industrial offering 2' by 4' drop ceiling type led lights for around $85 each shipped free. 50W - 5000 lumens - 4000K.
Was thinking about using a couple of them in conjunction in a t-bar grid along with the 2' by 4' radiant heat panel to both finish the shop ceiling and provide heat/light.
Price seems good for the amount of light they should provide.
RMW
Offline Coach.carpenter
  • I like to make!
« Reply #23 on: September 04, 2016, 03:32 PM »
Thanks David, that's really helpful. I have absolutely terrible lighting conditions in my workshop and have been collecting light fittings over the last couple of months and all the necessary cabling etc to revamp it. I actually have a couple of lights on stands that i place over my bench or table saw. a junk set up that i will be working on.
Offline neilc
« Reply #24 on: September 04, 2016, 09:30 PM »
I looked at the Big A** lights but settled on these - https://www.1000bulbs.com/product/174170/PQL-55214.html
Equivalent light output for 1/3 the price and better CRI.
I installed 8 of them in a farm shop - 18' sidewalls with a space of 50'x75'.  Walls and ceiling are insulated with white-backed insulation so I get excellent reflection.
Very pleased so far.  Granted, these are rated at 50,000 hours versus Big  at 150,000, but I felt like 25 years was plenty of useful life!
« Last Edit: September 08, 2016, 11:40 PM by neilc »
Offline jobsworth
  • Festool Baby.....
« Reply #25 on: September 08, 2016, 01:16 PM »
Hey Ive been to a guys shop like that
