You clearly work at the same speed as I do...
![Big Grin [big grin]](https://www.festoolownersgroup.com/Smileys/default/biggrin.gif)
Assuming you mean 2m of 25mm
![Wink [wink]](https://www.festoolownersgroup.com/Smileys/default/winksmiley.gif)
, it's actually a neat way of doing it and the way I've discussed doing mine with my electrician. As you've been told, it removes the issue of nuisance tripping of your main RCD in the house if there are issues in the external building.
I actually have a board in the house that's full of RCBOs so it didn't quite make the same difference for me, but getting the SWA to that board (on an inside wall) versus the Henley block from the main fuse entry point (on an external wall) was just much easier. It also means I can easily put in a 230V 16A socket in the garage where the entry point is too, so win win.
Factoring in voltage drop, and assuming 230V, 6mm SWA in PVC or XLPE will cope with a 7-8kW load over that 50m run.
