Author Topic: garage wall interior options  (Read 9734 times)
Offline treesner
  • DESIGN / CRAFT / ROAM
    • Trailboundco
« on: August 07, 2020, 01:10 PM »
hey guys, going to insulate my 28x22’ garage shop soon and was planning on drywalling it. but then started thinking about it, having plywood would be better as you can screw stuff to it anywhere.  I also do a lot of photos / videos in the shop so want it to look good. Do you guys have any good options for interior siding? Was thinking about T1-11 painted white, anyone have photos of this?
« Last Edit: August 07, 2020, 01:27 PM by treesner »
Offline Peter_C
Re: garage wall interior options
« Reply #1 on: August 07, 2020, 04:39 PM »
3/4" plywood, not OSB, with 5/8" drywall over it. Will also help keep the neighbors in a peaceful state. The drywall makes it easy to seal up the garage for air movement. From there you can choose ventilation. Of course if you put your dust collector or air compressor outside the noise is a moot point.
Of note if it is an older home that hasn't been earthquake retrofited, now is the time to throw a few tension tie downs in on sistered studs with a top bracket, bigger plates on the bolts if currently only a washer, or bolts if an old home, and the plywood would be considered shear wall by the garage door no matter what. The year the house was built will mostly likely dictate what should be done, unless it is a well built custom home.
« Reply #2 on: August 07, 2020, 04:42 PM »
Raw wood, T1-11 or whatever, unsealed, will reduce swings in humidity.
Offline treesner
    • Trailboundco
« Reply #3 on: August 07, 2020, 05:20 PM »
the detached garage was built in 1980 California (Sierra Nevadas), so guessing thats on the older side?
I'm on 2.5 acres and neighbors cant be seen through the trees but they did kind of give me that impression that they like to garden outside and like their quietness.. not sure I want to pay double for my garage interior for them though
Offline treesner
    • Trailboundco
« Reply #4 on: August 07, 2020, 05:21 PM »
if its painted it will still have humidity swings?
« Reply #5 on: August 07, 2020, 05:41 PM »
Raw wood will absorb some of the vapor in the air when it’s high and release it when the air is dry but I just realized you’re in the Sierra Nevadas which is an alien climate to me. Humidity might not be an issue there?
Painted wood is pretty much sealed from the humidity.
Offline DeformedTree
« Reply #6 on: August 07, 2020, 05:41 PM »
T-111 will always look like T-111, that's not good.  It is better than OSB, but that's not a big step up.
Do drywall over plywood, or nicer plywood/wood over lesser plywood.  I can't get into the idea of a place to do nice woodworking in would have ugly wood products surrounding it all.  Drywall gives you an ability to change and patch stuff.  Even some color.  Adds more thermal mass to help even out temp swings.
I would suggest taking a good look at getting the walls spray foamed first.  If it's a shop, and wide open the cost won't be that bad, but it will provide a vapor barrier without the potential issues of moisture trapped in the walls.  It will also stiffen things up.
If you are in an area with local saw mills where you might be able to get solid wood options cheap, maybe look at that.  Board and Batten, or lap joints.
Offline treesner
    • Trailboundco
« Reply #7 on: August 07, 2020, 05:53 PM »
I cant find any photos of painted t1-11 interior (probably have to hit with belt sander before installing but the look of this with the vertical lines is growing on me (I know that this is not t1-11 tho)
I cant find any photos of interior painted t1-11 (assuming I would have to belt sand before installing) but the look of the vertical lines painted white is growing on me
« Last Edit: August 07, 2020, 05:56 PM by treesner »
Offline tjbnwi
« Reply #8 on: August 07, 2020, 08:38 PM »
I used LP SmartPanel.
The primed is a job I did for a client, you need to look past the doors to see the gray walls, in my garage back home.
Offline Peter_C
« Reply #9 on: August 07, 2020, 08:39 PM »
No neighbors close by is very nice  8)
Huh, I didn't know Santa Cruz was in the Sierra Nevada's. I thought it was a surfing city on the coast ;)
Plywood with paneling over the top? Could even do a wainscoting over drywall for a "look".
Back in 1980 they were just realizing how building for earthquakes was important, but didn't really start implementing major changes until circa 1985. A box with two door cutouts is about the worst design for earthquakes; think house of cards. I'd recommend just planning to earthquake retrofit it. When you look at the corners of the walls inside the framing you should see metal tie downs and bolts to the foundation often. If not, and I would guess not, spend many hundreds dollars and add some in. Often you will just see nails going down into the concrete through the mud sill. How fast can YOU  [scared] exit the building? Easy enough job though. Permitting is required per most counties, but it is an over the counter permit with drawings (Pretty sure on a garage you can use "Standard Plan A" and it could be just hand drawn). Shhhhh, is fine by me as any structural enhancement is beneficial and it is your own house.
A concrete drill can be rented for a short time, but you will need an epoxy gun ($65) or use a strong caulking gun for tube type epoxy to glue threaded rod into the holes. A way to cut the threaded rod like a grinder is necessary. Framing nailer will be needed for putting up the plywood shear walls. A nail every 4" around the outside of the plywood is too many nails to hand hammer, but if you enjoy hand hammering go for it. Minimum 5/8" plywood should be used for shear walls inside the framing, but 3/4" is better for screwing into as you desire. Plywood must be put up by the garage door opening as that is the weakest part of the garage. From there shear walls are needed near or all the way into the corners, on all sides. Sides with doors should be full plywood around the openings.
"Standard Plan A" will explain everything.
http://resilience.abag.ca.gov/wp-content/documents/Plan-Set-A.pdf
Visual of a shear wall, but leave out the blocking at the bottom, as your mud sill should be good enough.
Here is a random article from googling "shear wall".
https://www.finehomebuilding.com/2011/09/08/how-it-works-shear-walls
Each side of a shear wall, gets one of these "Hold downs" below. (DHC Supply has been awesome to work with in person over the years (They do internet sales too), and have great prices.)
https://www.dhcsupplies.com/store/p/5796-S/HDU6-Cold-Formed-Steel-Holdown.html
« Reply #10 on: August 07, 2020, 09:48 PM »
The board and batten look in the one photo is nice. Of course this can be done using plywood too.  Can be helpful if you will need ways to get behind the walls without much tear up.
Offline CeeJay
« Reply #11 on: August 07, 2020, 10:33 PM »
I did mine lined with 3/4 ply. It’s super practical for mounting pretty much anything, does a good job of insulating noise, cold and heat, and pretty cost effective too.
Offline StanB
« Reply #12 on: August 07, 2020, 10:47 PM »
I did tongue and groove pine.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM S ET | MX 1200 E MIXER | DF700 XL | PDC 18 | TID 18 | ConuoroKA 65  | Kapex KS120 REB | MFK700| RTSC 400 | LS 130 EQ
Online Cheese
« Reply #13 on: August 07, 2020, 10:54 PM »
Nice work area Stan...I'm jealous.  [big grin]
That's pretty much the size of our entire house.  [popcorn]  Including the detached garage... [jawdrop]
Offline Stan Tillinghast
« Reply #14 on: August 08, 2020, 12:34 AM »
Must be an interesting problem to have to worry about the garage wall interior finish; there will barely be any bare wall in the garage when I’m done building enough storage for what we have. It would help if the kids would take away their school papers my wife can’t bear to toss out. [crying]
Für uns...ist das Beste gerade gut genug!
Offline bruegf
  • Michigan
« Reply #15 on: August 08, 2020, 06:52 AM »
I put up a 24x50 with 12' walls pole barn a few years ago for a shop and storage and started with typar wrap on the outside of the wall under the steel sheeting.  Then left a 1" air space and installed radiant barrier, another 1" airspace, then 4" of styrofoam, another airspace and 5/8 osb, and finally covered with 1/2" drywall.
The osb allows me to hang most things anywhere I want and makes it unlikely to accidentally punch a hole through the drywall.  The drywall improves fire resistance and painted white gives me a nice bright work area.
I've got r49 insulation blown into the attic.
Even with weeks of temps at high 80s to mid 90s I've never had the temperature go above 74 degrees even though I don't have air conditioning.  For heat I've got an 18K btu ceiling mount shop heater than keeps the entire space at 55 degrees for about $20/month.
Fred
Fred
Offline Sparktrician
« Reply #16 on: August 08, 2020, 08:48 AM »
T-111 also catches a whole bunch of sawdust, dirt, debris, spiderwebs, small children and dog hair.
Hear, hear!!!
- Willy -
Offline Kevin D.
« Reply #17 on: August 08, 2020, 10:48 AM »
I put T1-11 inside my shop over the drywall.  I hit it with a belt sander to remove the burr face it comes as, and it has been there for 17 years now with no issues.
You don't see the seams from one panel to the next, it looks nice and cozy, and you can make previous holes to fasten things to disappear for the most part using wood filler.
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
Offline greg mann
« Reply #18 on: August 08, 2020, 11:56 AM »
Ahh, school papers. My mother gave some of mine when she moved into assisted living. My kids thought they were going to give me grief over my old report cards. When they looked at my grades, I just smiled. Easiest part of my life.
Greg Mann
Oakland, Michigan
Offline Gone
« Reply #19 on: August 08, 2020, 01:36 PM »
Wall covering depends on if you are a hobbyist looking for the pretty shop or a production shop looking for maximum function. There's lots of pretty shops pictured. Consider using 3/4 plywood up to 48" then using 3/4" Slotwall above instead of drywall and all the BS it entails. You can paint both and screw to them any where. That's along with all the useful hangers and shelf supports available. Both are relatively cheap and can take a good impact unlike typical pine tongue and groove.
Offline treesner
    • Trailboundco
« Reply #20 on: August 12, 2020, 01:55 PM »
T1-11 paitnted white mockup vs just ply or drywall
hard to get a feel from a mockup up tho
Offline treesner
    • Trailboundco
« Reply #21 on: August 13, 2020, 12:24 PM »
went to local home depot in Sacramento
this duratemp is 27.98 which is a plywood and I think I like the look. of the narrower. planks
but the LP smart siding is 32.98 which is an OSB
Do you think one is ply is better than osb?
they're both 3/8". which is probably fine for holding hand tools and such with a screw
there is a cheaper T1-11 Brown engineered primed 8 thats .43"  thick for $21 but it looks much rougher for the dust, probably need more primer to paint it up too
and the.59" version is $39
Offline StanB
« Reply #22 on: August 13, 2020, 12:33 PM »
I think I paid like 1.15/sqft for standard/common pine tounge and groove picked up. KYlumber.com
Offline treesner
    • Trailboundco
« Reply #23 on: August 13, 2020, 01:31 PM »
wish wood was as cheap here in California
Offline treesner
    • Trailboundco
« Reply #24 on: August 13, 2020, 01:32 PM »
example of horizontal plywood, I like the darker wood trim
Offline Mario Turcot
« Reply #25 on: August 22, 2020, 08:40 PM »
Yes avoid OSB....
I have cheap BB 3/4" with french cleat rows at every ~18"
« Last Edit: August 22, 2020, 08:46 PM by Mario Turcot »
Mario
Offline GilbertV
« Reply #26 on: August 31, 2020, 11:42 PM »
When we were building our new house we decided to a stand alone shop in order not to have to deal with the POA at a later date.  So we built a 30' x 32' x 12' brick building finished on the outside but just a shell on the inside.
When I was doing the finish work we thought about using 3/4" plywood but decided to go with sheetrock instead as I really don't  like hanging tools on the walls (except for clamps). For flooring we went with vinyl flooring as it is easier to keep clean and easier on the feet.
« Last Edit: September 04, 2020, 11:10 PM by GilbertV »
Offline cubevandude
« Reply #27 on: September 02, 2020, 03:03 PM »
If you like this look, then why don't you buy a 1x10 or 1x12 board and half lap the joints.  You could then customize the spacing, profile and paint it whatever colour you like? You could even start with a 2/4 plywood and rip it into strips if that is what you have to work with.
A good video on what I am talking about:
Of course you'll have to either block the walls or strap them.
Something like this:  https://www.lowes.com/pd/5-375-in-x-8-ft-White-Pine-Shiplap-Wall-Plank-Coverage-Area-3-58-sq-ft/1000422301
Here's a good video if you want to use full sheets:
« Last Edit: September 02, 2020, 03:34 PM by cubevandude »
Offline Joelm
« Reply #28 on: October 06, 2020, 07:47 AM »
Just curious what you ended up going with.
Any updates?
Offline mkasdin
« Reply #29 on: October 06, 2020, 05:31 PM »
Drywall and good insulation. Nice white walls. Stick some French cleats to hang tools. OSB or plywood on a corner or a wall if you want to add shear value to the framing if needed.
