Author Topic: Ford transit fit out  (Read 4528 times)
Offline Kevin C.
« on: January 24, 2021, 08:05 PM »
 After driving my 2006 Ford E350 for the last 9 years and towing a trailer since 2003 it was time for an upgrade. I got a 2019 Ford Transit 350 HD high top extended dual rear wheel Ecoboost v6.
 It started with a couple shelves and a headache rack in it. I added a second battery and a set of inverters for onboard power. Then, picked up a bunch of plywood and got to work on the vertical panels.  I knew I wanted the shelves to be adjustable to be able to move tools around as tools change over the years. I wanted to be able to keep materials up off the floors while in transport because the van is 2 feet less space then my current trailer.  Having places to attach straps for materials or whatever else is something that always seems to be an afterthought, and now it is built in. I had these parts all cut on my shapeoko cnc because there were about 30 of each part.
 So here she is, set up for me and the way I work. I install plantation shutters for a local manufacturer in Saint Petersburg, Florida. The miter saw runs off 20v batteries and the shop vac is hooked up to the inverter and to a foot switch on the bottom left cabinet.
 The front wall has a sliding door with latches on the cargo side that I can open to bring 16 foot materials into the truck and transport them with the rear doors closed.
 Its still a work in progress, but thusfar I am very happy!
Offline afish
Re: Ford transit fit out
« Reply #1 on: January 24, 2021, 08:22 PM »
Congratulations, on the new vehicle and awesome looking fit out.  Looks well done and thought out.  Can you share how the lumber rack supports work?  They look like they are removable and adjustable.
Offline Tik Tok
« Reply #2 on: January 24, 2021, 08:32 PM »
This is awesome. Looks really well thought through - good job by you sir!!
Offline Kevin C.
« Reply #3 on: January 24, 2021, 08:35 PM »
Thank you!  They are not removable,  instead  they slid in between the vertical panels. If I need them, just pull them out. If not, they just stay tucked away. The pieces are about 18 inches deep and that gives me about 9 inches of material shelf when they're pulled out. The hole in the shelf is so I can strap it to the anchor point above it and it can't bounce off while driving.
Offline mkasdin
« Reply #4 on: January 24, 2021, 09:41 PM »
Nice work. 👍 I like the pull out material holders. Clean organization. Are you planning on putting a security door between the cab and storage?
Offline Kevin C.
« Reply #5 on: January 24, 2021, 09:51 PM »
I did put in a rolling door with latches that can only be opened in the cargo area. It is a pretty stout door
Offline Imemiter
« Reply #6 on: January 24, 2021, 10:36 PM »
Jealous of all those packing blankets!
Offline mkasdin
« Reply #7 on: January 24, 2021, 10:43 PM »
the point of entry typically through the cab. The cargo door is a plus
Offline Kevin C.
« Reply #8 on: January 24, 2021, 11:05 PM »
I use the packing blankets every day between the shutters, they take up a lot of room but make delivering finished products way easier.
 I figure I will do everything I can to keep bad guys out, but if they really want in there isn't much I can do. Beefy locks,, solid door to keep the cargo area secure and a stout door. Locks only keep an honest man honest. Scumbags and thieves will always find a way, sadly.
Offline mkasdin
« Reply #9 on: January 24, 2021, 11:14 PM »
if you park in a gated side yard, back yard, inside a garage or inside a storage space. Then it’s typically safe. Security camera, flood lights with motion sensor and some (animal shelter) dogs that bark at the slightest notice will keep them away.
Offline notenoughcash
  • too many ideas, not enough cash....
« Reply #10 on: January 26, 2021, 04:20 PM »
very nice. all you need to do now is to change the yellow tools for green and black ones [tongue]
in all fareness, i am a makita guy, and am to far invested in their 18v to go compleatly festool 18v or any other brand for that matter, and seeing that you had a far bit of dewalt sitting round, i wouldnt blame you if you dont want another cordless system......
turns out that woodworking is 1% making things you'll use, 4% making bespoke high end firewood, 15% cleaning, and 80% looking for the blinking thing you just put down
Offline Kevin C.
« Reply #11 on: January 26, 2021, 08:34 PM »
Thank you.
  If Festool had enough cordless options, I would be in! Dewalt has a cordless router, blower, inflator, nail guns, miter saws, table saws...and on and on and on.. Makita has even more.  Makita has a coffee maker even!
Offline gunnyr
    • Compass Custom Creations
« Reply #12 on: January 26, 2021, 09:30 PM »
Great job on the adjustable transport racks!
I love my DeWalt 20v MiterSaw.  I use it for small trim and my HKC for the larger, longer stuff.  You can buy an adapter for the 20v Vac to attach to the MiterSaw, but none of the DeWalt adapters will allow the vac to hook up to the DeWalt 60v TableSaw!  Thank God that 3M makes a blue universal adapter material! [big grin] [cool] [crying]
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|ETSC 125|DTSC 400|RO 90|RO 150|OF 1400|OF 1010|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|STL 450|DUO-SET|SYSLITE KAL II
Offline Kevin C.
« Reply #13 on: January 26, 2021, 10:33 PM »
The 60v platform is probably my next step. Ill get rid of my table saw and get the cordless one at some point. Its one of the few corded tools I still use regularly.
Offline mkasdin
« Reply #14 on: January 27, 2021, 12:46 AM »
I’ve got my outdoor Makita cordless tool. The leaf blower. It’s really good. And their small Makita chainsaw I use to cut down the bamboo. I think once your invested in a battery system it’s hard to jump to another brand. I did see that there are a few companies that make adaptors to go from ryobi to Dewalt, Makita to Milwaukee, etc. so if push comes to shove there’s always alternative without reinvesting in xyz battery platform
« Reply #15 on: January 27, 2021, 05:24 AM »
Thank you.
at least someone still has a sence of humor these days [big grin] [tongue]
Offline Bob D.
    • My Cordless Workshop
« Reply #16 on: January 27, 2021, 06:15 AM »
"You can buy an adapter for the 20v Vac to attach to the MiterSaw"
@gunnyr , do you know the part number for this adapter? I searched the DeWalt site but couldn't find anything that says it is for the DCS361 miter saw.
I don't have the DeWalt vac but if this adapter improves dust collection on this saw I would be interested if it could be used with other hose such as my Festool that I use with the TSC55 or my sanders.
Offline gunnyr
« Reply #17 on: January 27, 2021, 08:06 AM »
Bob,
Here's the adapter to connect the Dewalt 20v vac the Dewalt MiterSaw, Sander and others.  They also have some other adapters you can add but I've not yet aquired any of them as I find that 3M Blue Tape is an excellent universal adapter! [smile] [mad] 8)
Semper Fi,
Jeff
Offline Bob D.
« Reply #18 on: January 27, 2021, 08:50 AM »
Thanks, I think I will get one.
I have used tape but I take the MS in and out of the shop  once or twice
a month so it would be nice to have an easy quick-connect like this.
Offline gunnyr
« Reply #19 on: January 27, 2021, 11:07 AM »
Most of my work is site based!  My truck and memory is not good enough to carry all the adapters!  You'd think Dewalt could make their tools play nice with each other!  Festool has it figured out (kind of...) If only Festool's SysVac were battery....  I have the Dewalt DCV581H 20v Vac.  It is of only marginal quality as the filter gets clogged LONG before there is much in the way of debris in the canister.  I'd love to have a bag in it just to improve the function.  I've used the Milwaukee and the Ridgid battery vacs.  The main things about the DeWalt vac is that it is dual 120v/20v, and it is very light weight.  It doesn't charge batteries but it's nice to plug it in.
Semper Fi,
Jeff
Offline Kevin C.
« Reply #20 on: January 27, 2021, 11:34 AM »
I've got Dewalt little 20v vac and its been running in my truck for years. The sys-vac i picked up last week is in the truck but because you have to plug it in, I think it is not going to make the cut.
Offline gunnyr
« Reply #21 on: January 27, 2021, 01:46 PM »
I carry a Midi and my 20v DeWalt Vac on my truck.  I added one of the cloth like filters to my DeWalt and it greatly improves the suction, but it is a mess to empty.  The convenience and price of the DeWalt makes up for its short comings.  I don't see the SysVac as providing anything I don't get from the Midi, plus I would lose capacity and suction adjustment.
Semper Fi,
Jeff
Offline Kevin C.
« Reply #22 on: January 27, 2021, 07:15 PM »
Well, you've talked me into another vac.  What is the cloth filter you've upgraded to?
Offline gunnyr
« Reply #23 on: January 27, 2021, 08:27 PM »
 It's just a generic bag filter from Home Depot.  I put it over the pleated filter in the DeWalt Vac.  Seems to improve the overall performance of the vac.
Semper Fi,
Jeff
