Author Topic: STM 1800 as sawstop outfeed table  (Read 1572 times)
Offline Route24Design
    • My Personal Blog
« on: August 13, 2021, 04:00 PM »
Anyone use the STM 1800 with a top on it as outfeed for a sawstop PCS table saw?  Does the STM height adjustability work out for the sawstop?
Festool TS 55 REQ-F-PLUS
Festool OF 1400 EQ-F-PLUS
Festool CT MIDI HEPA
Festool CT Sys HEPA
Festool Domino DF 500 Q-PLUS
Festool PRO 5 LTD (ETS 125 REQ)
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Festool FS 1400/2 (x2)
Festool FS 1400/2-LR 32 Guide Rail
Festool LR32 Router Hole Drilling Set
Offline squall_line
Re: STM 1800 as sawstop outfeed table
« Reply #1 on: August 13, 2021, 05:24 PM »
I don't see why it wouldn't.  The SawStop is at 34", I think the max height on the STM1800 is 35 and change, but adjustable down to 27 and change in 2" increments.
Dropping it one step would take you to 33 and change, so then just figure out if a 1/2" or 3/4" sheet would work better for the height you want.  If it's an 1/8th low, it probably wouldn't be the end of the world.
Offline jobsworth
  • Festool Baby.....
« Reply #2 on: August 14, 2021, 12:13 PM »
you always make a large shim to level the 1800 to the height of yer table saw. I like mine just a tad lower then the outfeed of my TS. The bc I use a ts75 in my CMS as my only table saw, the 1800 is compatable with it
