« on: June 02, 2017, 05:03 PM »
Hi all
I getting a bit confused as I'm setting up the dust extraction in my work shop but having terrible suction. I think I know the problem so looking for some advice to resolve the issue. I have a 3kw twin bag extraction unit which is reduced from 100 to 50mm pipes. Then to festool extraction hose to my tools. But the suction is poor so would presume this is due the reducing of the pipes. Does anyone have a solution without ripping out the 50mm pipes.
All help and advice is gratefully received
TS 55 R, CTL MIDI, RAILS 1400mm, DF 500 Q, OF 1400, CMS-OF, CMS-GE GB 240V, CMS-TS55, ETS 150/5, BS 75 E, MFT/3, KS120, MFK 700 EQ, T 18+3 FL, CTL 36,PS 420 EBQ, ETS EC 150/3, RTS 400 REQ, FS5000/2, FS 1400/2-LR 32, SYSROCK BR10, VAC SYS Set SE1, SYS3-Set SURFIX, FS-PA, FS-PA-VL, LR 32-SYS
