Hi all
I have just purchased a 2hp single stage dust collector for my garage workshop. I got tired of emptying out my festool/dust deputy vac when using the 13" ryobi thicknesser. I hooked it up to the new dust extractor and found after a very short time, like 1 minute the large clear flex hose was filling up and backing up from the inlet port of the extractor. After switching it all off and waiting for the impeller blades to stop spinning, I find the shavings are getting blocked by the plastic attachment Y fitting (it can take two hoses, for now one is capped). Inside this piece it has a couple of plastic guards I assume to stop any large bits getting to the extractor itself. The extractor also has a metal star shape grill further restricting access for the shavings. So I am disappointed to say the least at this moment. Back to stopping, emptying hose restarting...I'm thinking of cutting the two plastic strips in the fitting to help remove the jamming up off the pipe. Also find myself considering a big rubbish tin of some sort and feed inlet and outlet hoses unresrticted to it and the extractor. ...
And since I have to get more pipe, am thinking of running smooth overhead piping around the workshop.
I have seen examples on the net of 4" plastic piping and others of metal piping. Cost wise I can only stretch to the plastic tubing. Since I work alone and use only one machine at a time, is 4" piping ok? I have read it is best to have 5" to increase airflow but 4" is fine if only using one machine at a time. I will run the usual drops to smaller hoses to power tools such as table saw and Kapex and drill press.
Carba-tec in Aus-NZ sell this kit of clear tubing with blast gates and connectors.
http://www.carbatec.co.nz/clear-dust-extraction-ducting-kit_c21121 Is there an alternative similar?. I could get 4" plastic pipes from Bunnings/Mitre10 here in NZ (big box DIY stores) and fiddle around making a setup. I guess I'd just like any advice thanks.
