Author Topic: Dust Collection Pipe System  (Read 35686 times)
Offline Mario Turcot
« on: April 27, 2019, 04:10 PM »
Open to suggestion**
I start working on my dust collection system last weekend. I was tired of tripping on the flex hose that was running on the floor that connects on the table saw and band saw.
Everything start on that corner. Pipes are supported on French cleat. I'm using 45deg avoiding straight 90deg.
I know my bag is full  [tongue]
Here I capped one end and switch directly to the table/band saws. Those tools are in the middle of the shop and both mobile.
Please disregard the plastering. I had a friend that came to help last summer and he offer to do it. It didn't last long before I asked him to move on something more important  [eek]
First question, I have to put two blast gates or else for the two tools. Because the tools are mobile what height should I put them?
Again disregard the plastering  [embarassed]
The pipes is supported here on the garage door rails. Not nice but effective  [big grin] Here is the last drop for the drill press and a floor sweep.
and another picture of where the drill press blast gate for the drill press will be.
There is no glue on the pipes yet. I was planning to use alum duct tape for easy removal, once I'm totally done. I am looking for a cad file for blast gate that I can run on my CNC, something similar to
Any comment and suggestion is welcome.
« Last Edit: April 28, 2019, 12:11 PM by Mario Turcot »
Mario
Offline Bob D.
    • My Cordless Workshop
Re: Dust Collection Pipe System
« Reply #1 on: April 28, 2019, 07:26 AM »
Sometimes with a layout like yours with the dust collector located in a corner it's better to run your main line diagonally across the shop ceiling and branch out from there. You can often eliminate a few fittings and some pipe footage which affect system overall performance more than anything else except maybe undersizing your pipe or joint leaks. And if you plan your branch connections so you use WYEs in place of combos you'll have even less restriction and significantly reduce the chance of a clog from the occasionally long silver that gets sucked up.
Also remember that running your pipe on the ceiling means everything must be pulled up to whatever your ceiling height is which takes work and further reduces your systems effectiveness. Not so bad with dust from a sander, table saw, band saw but for a planer or jointer with larger, heavier chips it might be. For those tools with the larger, heavier debris try locating them closer to the DC, so they have shorter pipe runs and therefore more suction. This may mean rearranging your shop tools or the DC. If neither work out with your situation then reducing the number of bends and overall pipe footage becomes even more important.
Try laying it out on paper with a diagonal main line across your shop and 45 off to each tool or a couple tools if they are close.
« Last Edit: April 28, 2019, 08:51 AM by Bob D. »
Offline Bob D.
« Reply #2 on: April 28, 2019, 07:49 AM »
Still sideways here Peter. :-)
Offline Peter Halle
« Reply #3 on: April 28, 2019, 07:51 AM »
Working on it.
Offline Peter Halle
« Reply #4 on: April 28, 2019, 08:01 AM »
Offline Bob D.
« Reply #5 on: April 28, 2019, 08:08 AM »
You can get a great tool for manipulating your images for free from Microsoft. That tool is MS Office Picture Manager which used to be included with MS-Office up until Office 2013. You can get it now as part of SharePoint Designer, the trick is to just install Picture Manager by choosing Custom Installation during setup. It's all explained in the link below and very easy.
Picture Manager let's you batch resize, rename, adjust exposure, rotate, and more.
Follow the instructions here from Microsoft.
https://support.office.com/en-ie/article/where-is-picture-manager-58837c3e-34db-4904-95e8-4eca7b7c5730
« Reply #6 on: April 28, 2019, 09:40 AM »
Thank you Bob & Peter. This is the first time this happen and I know why. A new phone  [embarassed] The thing is I open them in MS Paint to reduce the size and they were just fine.  [mad]
Bob, I understand your explanation about going diagonal and I thank you for taking the time to explain. You see this is why I planned to only use tapes for the joints  [big grin]. Yesterday I did a test with two ends 4" open and the further end was sucking debris like a champ  [smile]. One of the reason I went square with the wall is because I have my CNC on the north wall close to the corner (pict 3) it usually sit right under the air cleaner. I plan to make an enclosure for it and have the two extraction system work together for direct and ambient suction. This is a "concept" to be proven.
Bigger debris, funny that you mention that. I am looking at a combo Hammer A3 31 with mobile base. If you look at my extractor the fan has a 5" outlet that split in 3x4" and will be moving the power tool right next to it using one of the extra 4" outlet  [big grin]
Thanks again to you both   [thumbs up]
Now I really need to get on that blast gate design  [crying]
Mario
Offline Alanbach
« Reply #7 on: April 28, 2019, 11:40 AM »
Here are my comments regarding blast gate height. You want to be able to see them from all around your shop. You will leave them open sometimes and being able to scan your shop to find which are open before moving on to the next machine is handy. I like mine somewhat low when possible so that the flex hoses can drop or stay level. The flex hoses really steal cfm  from the collector so keeping them as short as possible and not at steep inclines will help performance. If they need to be higher to stay out of the way make sure that they are high enough to not hit your head on them. Mine are metal and they would take a chunk out of my noggin if I let them.
« Reply #8 on: April 28, 2019, 01:02 PM »
@Alanbach , thank you for your input. This is exactly what I was affraid. Put the blast gates high enough to not get hurt by walking into them or having shorter flex hoses.
When you say flex steal CFM, I believe you but I would like tyo know why? Is it because of "collapsing" effect?
Some updates: I visit my local L.V. this morning with a piece of 4" sewer pipe & fittings to check how their blast gates and fittings fit.   The 4" self cleaning blast gates (L) have a pretty snug fit but the flange is a bit short (3/4") for my taste. The 4" to 2 1/2" reducer (F) is snug as well but the sweep floor (M) is too loose. It has a taper fit inside the pipe but the flange will go in by a shy 1/2".
Mario
Offline Bob D.
« Reply #9 on: April 28, 2019, 02:22 PM »
I believe the problem with the corrugated flex hose is the inside on most is not smooth and that creates turbulence in the hose.
« Reply #10 on: April 28, 2019, 03:41 PM »
Make sense, I'll keep em short  [smile] thank you.
Mario
Offline Alanbach
« Reply #11 on: April 29, 2019, 01:43 AM »
I wish that I could give you a proper technical / scientific answer. I can only tell you that over the years I have had many conversations by phone with the good people at Oneida and they have taught me a lot about techniques to improve the efficiency of my system as my shop has evolved. The issue of significantly greater cfm loss in flex duct vs. smooth piping has come up many times. Now I wish I had asked them for a chart of cfm loss on a part by part basis. They can rattle it off for you, unfortunately I cannot. For example when I switched from a Unisaw to a Sawstop a year or so ago they calculated the cfm loss in 18’ of flex duct vs. 2 long radius 90’s, fifteen feet of straight duct and three feet of flex duct and it resulted in 100 more cfm at the saw and greatly improved results. I definitely think that  the ridges on the inside of the flex duct create turbulence that reduces flow but I can’t back that up with the proper technical explanation. I hope this helps.
Offline Bob D.
« Reply #12 on: April 29, 2019, 04:41 AM »
Those 'self-cleaning' blast gates are position sensitive. I have 6 of them around the shop. The ones mounted in drops (vertical) pipe seem to do better than those in runs (horizontal). One is in a 45V drop to my bandsaw and I have the gate withdraw to the bottom because it's easier to reach and it cleans out the track each time I close it. If it was installed with the gate coming out the top then each time you close it sawdust will get packed into the corners and eventually you won't be able to fully close the gate. I had that problem with one of mine and had to reorient the gate to mitigate the problem. Maybe the newer plastic gates lie this don't have that problem, but those in your photo look just like mine that are 15 years old.
On my DW735 stand as I mentioned in another thread I closed in the bottom of the stand to act as a chip collector. Where my planer is in the shop it sits near the TS and the jointer near the center of the shop floor. The box has four ports; one for the DW735, one for the jointer, one for the TS, and the fourth goes out to the DC. They all have gates on them. The jointer and planer gates are side-by-side with the gates facing each other and spaced so that when one is opened the other is closed by the same motion. But, they are NOT tied together, that's not necessary and would not allow for both to be closed when running the TS or using the planer outside the shop. The box also has a pair of flaps on the top with a furnace filter installed under the flaps. The flaps are configured so that they will seal under vacuum but open and vent under pressure such as when using the planer without external suction and relying on the chip ejector in the DW735 to expel the chips from the machine. It has worked quite well for over 10 years. I tried to get ShopNotes (sent them a short writeup and photos) interested in it as a years ago but they didn't see it as a viable project, not a wide enough appeal I guess.
As usual I have stayed off topic somewhat but to bring it back those 4 blast gates are all mounted so the gates withdrawal from the side, on one I had a problem with it clogging up and what I did was cut the corners off at the bottom of the gate travel with about a 1/2" x 1/2" chamfer on only the one side. If you look close one side is flat and the other is formed to create a space for the gate to ride in, that raised half is all you want to cut. I used a hacksaw blade and did it by hand. I can take a photo if you need it to understand what I am saying.
Offline BarneyD
« Reply #13 on: April 29, 2019, 09:51 AM »
Let me first state that I am a cheapskate. I made all of my blast gates from scrap plywood. And I'm very happy with them. Each has a micro switch that when opened will turn on the cyclone. Fairly simple to make and if the cyclone in ON I know there's an open blast gate somewhere. This is one on my planer in the closed position:
There's just a piece of steel strapping that makes contact with the micro switch which in turn sends 24V to the motor starter for the cyclone. This last pic is with the port open:
Maybe just some food for thought? Good luck with your system.
Barney
« Reply #14 on: April 29, 2019, 09:54 AM »
Mario, a general rule of thumb is that each short 90º elbow is the equivalent of 10' of straight smooth tubing.
And 10' of corrugated hose is the equivalent of 20' of straight smooth tubing.
« Reply #15 on: April 29, 2019, 11:23 AM »
@BarneyD That;s very smart  [wink] I will keep in mind that process and the use of micro switch  [big grin] Thank you for the pictures.
@Bob D.  & @Alanbach Honestly that make a lot of sense. I have two different kind of flex hoses. One that came with the DC that I hate because it's stiff and one I bought from L.V. that claim to be xtra flexible.
The one blast gate I bought to test the fit with my pipes
Note: There is actually no glue, everything on that picture is snug fit  [smile]
Here a picture of the extra flex hose I was planning to use. Reinforced with metal brush making the ridges bigger.
And here a picture of the hose that came with the DC. Seems to create more static inside but a lot more smooth then the extra flex.
@Cheese That's an easy way to calculate, thank you. So far I have 28' of pipes. The drill press setup (pict 1) will probably end up with a short 2-3' of 2 1/2" flex.
Now I am debating to perm connect the table saw and band saw using a Y and two blast gates or... one blast gate for both and switching the flex that comes from both machines. I have to sit and analyse both options.
I have some magport I can use
but at the end I want the most efficient not necessarily the less expensive.
About the Magports, they are strong, they never disconnect on me. Very easy to install and made in St-Louis  [big grin]. I highly recommend their products. I ordered the starter kit and it took about 6 days to get to me  [wink]
« Last Edit: April 29, 2019, 11:32 AM by Mario Turcot »
Mario
« Reply #16 on: April 29, 2019, 11:34 AM »
Mario if you can keep the flex hose to 18" or less, the internal loss isn't that great.
I like the MagPorts a lot. I use them for all my connections.  [big grin]
« Reply #17 on: April 29, 2019, 11:37 AM »
Perhaps, it was YOU that introduce me to Magport on one of your post/reply [eek] who knows  [tongue]
Mario
Offline Bob D.
« Reply #18 on: April 29, 2019, 04:16 PM »
I like the Magports but have not bought any yet. Most of my stuff stays connected, but I can think of one place where the Magport would be handy.
Offline mwolczko
« Reply #19 on: April 29, 2019, 10:46 PM »
I hadn’t seen the MagPorts.  I use Dryer Dock connectors, which perform the same function, but with a plastic interlock. Rough handling will break a tab, though.
I recently re-did half of my network using the clear 4” tubes from busybeetools.com, and replaced my plastic gates with metal. I really like the clear tube, even though getting them to the US was expensive (busy bee doesn’t export). I’ve written to LV asking that they consider stocking them; if you’re interested, join in!  I plan to re-do the other half later this year.
« Reply #20 on: April 29, 2019, 11:32 PM »
As Mario stated, these things really hang tough. It takes an act of God to pull these things apart.
I had those cheap friction fit connectors sold by Woodcraft and others and the things always disconnected by themselves. They really are are a POS, I have 4 of them that I will recycle for the scrapers. These MagPort connectors are real slick.
The other neat thing is if you don't want to drop the hose on the ground, you can attach the hose to the port but in a disconnected manner.
« Reply #21 on: April 29, 2019, 11:34 PM »
Yes clear tubes is a must but at x9 the price  [eek] I'd think twice. Care to show some picts?
The magports are really robust and get disconnected in a simple & easy 1/8 twist... works for lefties too  [tongue]
@Cheese, thank you for the picts... you know how I like them  [wink]
Look what you have me do,  after thinking about your suggestion to make the flex shorter.
Before
After
Reduced the flex of 4' shorter.  [smile]
I did a test at the drill press and the suction was stronger then my shopvac.
« Last Edit: April 29, 2019, 11:43 PM by Mario Turcot »
Mario
« Reply #22 on: April 29, 2019, 11:53 PM »
That's sweet Mario, it doesn't take much shortening of the flex hose to make a major difference in the capabilities of the dust collector.
Just like an HVAC system, it's the systemic losses throughout the system that make the difference.  [big grin]
I like the lefties comment...it reminds me of my dad...he was a southpaw.  [smile]
« Last Edit: April 29, 2019, 11:55 PM by Cheese »
Offline Bob D.
« Reply #23 on: April 30, 2019, 05:09 AM »
Do Magports come in sizes other than 4"/100mm ?
I have a 4" drop near my router table which I have a 4x2 wye to run to my router table fence. But I also use this with my long shop vac hose for general cleanup around the shop because it is centrally located and I can reach everywhere from that one connection. Having the Magport connector on there would be great as the hose is always falling out of this elevated connection.
I'll have to look. Sounds like a good Father's Day gift suggestion.
I found them quickly enough.
https://magport.net/products/magport-2-5-magnetic-coupling-used-in-dust-collection-for-woodworking
« Last Edit: April 30, 2019, 05:14 AM by Bob D. »
Offline Bob D.
« Reply #24 on: April 30, 2019, 05:30 AM »
Mario/Cheese,
I blame you both for me buying a bunch of Magports just now. :-)
Looking forward to using them to improve my dust collection system.
I think the 2.5 inch will be the most useful for quick connections at
the router table and drill press.
Thanks.
Anyone tried fitting the 2.5 inch ports to the larger Festool hoses?
« Reply #25 on: April 30, 2019, 07:57 AM »
@Bob D.  Thank you for putting a  [big grin] on my face this morning. I'm sure you won't be able to resist to the temptation of showing off your Magport setup [popcorn]
Mario
Offline mwolczko
« Reply #26 on: April 30, 2019, 07:48 PM »
Here you go.  Yes, they're expensive, but if you've ever had to clear a blockage you'll appreciate the time saved.
« Reply #27 on: April 30, 2019, 07:51 PM »
Awesome, thanks for the pictures  [thumbs up]
Q: What glue you used for the blast gates?
Mario
Offline mwolczko
« Reply #28 on: May 01, 2019, 02:07 AM »
I used a silicone caulk. It sticks enough to hold, but is easily cleaned off if you want to take them apart.
The clear tubes are a very tight push fit in the unions — no sealer or tape needed.
Offline Bob D.
« Reply #29 on: May 01, 2019, 04:18 AM »
In your second photo, if you could rotate that wye 45° toward the path of the flex hose you would take that sharp bend out of the flex and improve flow significantly.
