Author Topic: Dropped a router lift into my table saw extension  (Read 1705 times)
Offline CeeJay
« on: April 05, 2021, 08:35 AM »
So I finally got around to installing a router lift into my table saw this weekend.
I bought the router (Makita 2301), the lift (Sherwood, a really nice one actually), and fence (Incra Wonderfence) from a guy who was clearing his whole shop about a year ago. This set up had never been installed - it was all still packaged and boxed.
I spent along time figuring out where and how I wanted it.
First challenge was the right template for the router plate detent cut. I always planned on using the MFS as a template. I needed a 38mm bit to get the plate corner radius exact. So I got the biggest copy ring I could find for the OF1400 - 40mm. Then got a 38mm bit. Bummer - the 40mm copy ring has a 37.5mm ID so that plan was a bust.
Next biggest bit I could find was 35mm so gave that a go on an MDF test. Not an exact fit but pretty close - good enough.
So I set up to butcher my lovely Powermatic table saw extension. Did a 1mm cut first to try and minimise laminate chip-out, then took it to a 7.5mm detent for the 6mm router plate.
I was then going to break out the P1CC for the cutout,  but realised if I left the MFS clamped in place and swapped the 35mm bit for a 6mm bit I’d get a perfect 14.5mm shoulder for the plate to sit on - worked out beautifully.
Then set about building a dust box from bits of scrap ply. Worked out nicely. Currently plumbed into the MIDI but when I get the right fittings shipped will be connected up to the 2HP 4” extractor system the table saw is connected to.
Finally installed the NVR switch at knee level and all systems go. The dust box works great - used draught excluder foam tape on top and bottom surfaces and getting great airflow through the table.
Next week routing in some T-track and installing the Wonderfence.
« Last Edit: April 05, 2021, 08:44 AM by CeeJay »
Offline Bob D.
    • My Cordless Workshop
Re: Dropped a router lift into my table saw extension
« Reply #1 on: April 05, 2021, 10:03 AM »
Looks great. You mentioned installing t-track.
Is that just for the fence and will you use miter track across the front so you can make use of your TS miter gage.
Something like Woodpeckers combo track maybe?
https://www.woodpeck.com/woodpeckers-combo-track.html
Offline CeeJay
« Reply #2 on: April 05, 2021, 04:29 PM »
Thanks Bob.
I can use the mitre slot from the steel portion of the table saw - it’s close enough to the router I think. So initially I’ll add two T-tracks for the Incra fence and hold downs for stops etc.
I can of course use the table saw fence as well, for cuts where the fence is not over the bit, and use the Incra fence where I need the split fence and dust extraction capability.
If I need to add a mitre slot it later i will do so.
Offline CeeJay
« Reply #3 on: April 05, 2021, 04:30 PM »
Plus I already bought basic T-track!
Offline CeeJay
« Reply #4 on: April 11, 2021, 12:10 AM »
Now connected up to the mainline dust extractor to both router dust box and the fence, and T-tracks installed for the fence.
The dust collection is amazing.
Super happy with how this has come out.
