Author Topic: Racking to a 2013 transit  (Read 5197 times)
Offline paulc75
« on: March 11, 2016, 04:03 PM »
got bored onsite last night and needed an OCD fix [big grin] [big grin]
Offline joiner1970
Re: Racking to a 2013 transit
« Reply #1 on: March 12, 2016, 04:26 PM »
What's that yellow thing is it a new type of transformer or splitter
Nice job by the way
« Last Edit: March 13, 2016, 04:55 AM by joiner1970 »
Offline paulc75
« Reply #2 on: March 13, 2016, 05:12 AM »
Light wand base / splitter. Plug it into the CT then I can plug in kapex and a plug it simultaneously and both will auto start.
Offline demographic
« Reply #3 on: March 13, 2016, 05:52 AM »
I like the ones that work like a Weeble.
Amble past and knock them and they wobble about a bit then steady.
Heavy things to cart about in a van though which is where the type you have comes in.
Offline john molloy
« Reply #4 on: March 19, 2016, 05:06 PM »
how high did you raise floor .do you find it hard to get into as the floor is out to edge of van .would you put a step there if you were doing again
Offline paulc75
« Reply #5 on: March 31, 2016, 07:42 AM »
John,
Floor is raised 300mm from existing bed. It is inset back so I can still utilise the side step and rear step. Best of all it will allow 15 sheets @18mm to stow underneath.
Offline TSO Products
    • TSO Products
« Reply #6 on: March 31, 2016, 09:53 AM »
John,
Floor is raised 300mm from existing bed. It is inset back so I can still utilize the side step and rear step. Best of all it will allow 15 sheets @18mm to stow underneath.
what is the size of your Transit? - roof height? - wheelbase -?
how long have you been using this general set-up?
what would you change if you had to start over?
TSOproducts.com
