In order to allow a Systainer to clear the front of a cabinet so that the lid can be opened fully, you’ll need to use either of the following drawer runners:
- 350mm full extension ball bearing side mount with over-travel
- 400mm full extension ball bearing side mount
- 550mm single extension roller bearing bottom mount
Using a single extension runner is a bit of a false economy as the cabinet will need to be made quite a bit deeper to accommodate the longer length as Guido shows in the video. Some wasted space at the rear as well.
