Author Topic: After the Dust Settles  (Read 8415 times)
Offline Owego
« on: November 22, 2015, 10:48 AM »
My shop is 30'x30'x10' with a variety of things that generate a lot of wood dust.  Even though all my stationary and hand power tools are attached to dust collection systems, a fine layer of dust accumulates in non-trafficed areas over time - in the corners, on top of things that don't get accessed often, under tables, behind stationary tools, etc. Disturbing one of these areas invariably generates fine, air born dust - probably of the most unhealthy kind.  To address this problem I once donned my Trend Air Pro (full face shield and respirator), opened the doors and stacked 3 box fans in one of them (to generate cross air flow), fired up my compressor, and blew all that sitting, sleeping dust into air born dust.  WHAT A DISASTER !  This shi# storm of dust resettled as a fine layer over everything.   The "flow through" sirocco was totally ineffective.
   That was last year.  Now those sleepy corners have again acquired a dust layer booby trap awaiting the next minor disturbance. Has one developed an approach to addressing this problem ?
Offline EA Custom Millwork
    • www.eacustommillwork.com
Re: After the Dust Settles
« Reply #1 on: November 22, 2015, 03:53 PM »
I recently bought a Build Clean 360 air cleaner for jobsite air cleaning, but it works great in my garage as well.
Check out BuildClean.com
Offline andreasg
« Reply #2 on: November 23, 2015, 02:06 AM »
CAn I ask what it costs? Couldn´t see the price on their site. Is it 110v only?
Offline Kev
« Reply #3 on: November 23, 2015, 02:26 AM »
I put a brush head on the vac and suck the stuff up when I feel there's enough residual dust lying about.
Offline Woodwork Wizard
« Reply #4 on: November 23, 2015, 03:45 AM »
I have an Oneida Dust Deputy on a CT-36 extractor with a Tradesman cleaning set in my workshop. The bags I use in the DD cost very little, just a few pence each. With this lot there's no reason to have a dusty workshop anymore as this lot makes a great vacuum cleaner.
Anyone thinking of buying a 36mm hose should consider the Tradesman set as it works out slightly more expensive than the hose by itself and you get stainless steel tubes and a full set of attachments all in a SYS-5. The basic cleaning set with its very bendy plastic tubes is poor by comparison to this kit.
« Last Edit: November 23, 2015, 04:11 AM by Woodwork Wizard »
Offline Alex
« Reply #5 on: November 23, 2015, 04:03 AM »
Indoors, dust settles everywhere. Houswives have been battling this problem since the 50's with a vacuum cleaner and a damp cloth.
« Last Edit: November 23, 2015, 06:35 AM by Alex »
Offline hopper
« Reply #6 on: November 23, 2015, 06:18 AM »
I have a Stihl leaf blower and large garage doors at either end of my garage.  I open both doors and blow in the direction the wind is blowing through the shop/garage. Works great, but i have to make sure small items are "nailed" down.
« Reply #7 on: November 23, 2015, 07:17 AM »
About $950 plus extra filters and a 20" hose to move exhast air away if you want for another 250
Online neeleman
« Reply #8 on: November 23, 2015, 07:33 AM »
I use the Felder AF500 in my workshop which only cost €209 exc.VAT.
Works well and has a timer and 3 levels of suction: 480, 600 en 720 (m³/h).
Catches 98% dust of 5 micron and 85% dust of 1 micron.
Has an infra-red remote and can also be taken to jobsites.
Same model as another FOG member @dolph uses.
Festoolian since 1998.
FESTOOL:
OF1010R | AGC18 | TPC18/4 | TID18 | OSC18 | RTSC400Li | CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
CHP26 | VCP260 | DSC-AGP125 | DSC-AGP230 | DSG-AGP125 | DRP16
Offline Bohdan
« Reply #9 on: November 23, 2015, 07:54 AM »
I agree with you, your system works real well.
I use an electric blower and every time that the wind is blowing strongly from the right direction the leaf blower leaves the workshop dustless and sawdust free in less than a minute. (I live on a farm so there are no near neighbours to complain about the dust cloud)
Offline Untidy Shop
« Reply #10 on: November 23, 2015, 03:34 PM »
And in Little River, for this purpose Bohdan often 'enjoys' a hot and blustery Northerly Wind.
As for the Untidy Shop, I vacuum and obviously this is long over due!  [eek]
@Bohdan
« Last Edit: November 23, 2015, 03:38 PM by Untidy Shop »
Offline andreasg
« Reply #11 on: November 23, 2015, 04:18 PM »
@neeleman
Thanks for that tip! That was a decent price from a wellknown brand. Refreshing my small workshop now, and will even put in a small desk, because the workshop is in a quiet part of the house (got small kids:). With the Felder AF 500 I could probably have quite decent air in there:)
Offline Holmz
« Reply #12 on: November 23, 2015, 04:27 PM »
Do you do windows? [wink]
Offline Kev
« Reply #13 on: November 24, 2015, 12:09 AM »
@Holmz
HAH!! [eek] [blink] [huh] .. bloody cheek [wink]
I was coincidentally looking at those Karcher window vacs last weekend .. tempted.
Offline andreasg
« Reply #14 on: November 24, 2015, 02:59 AM »
Guess openings in two ends of the garage might not be the norm, and that solution doesn´t apply to most?:)
Sort of 2 subjects here. One is to clean up the woodshop, and the other to keep the air cleaner to avoid breathing in the fine dust. And for myself, I´m leaning towards getting all that fine dust out of there before it even settles.
When that is said, I´m also thinking about having doors on cabinets with small tools and screws and that kind of things. Just to avoid to cleanup were it will be more difficult.
Offline Bert Vanderveen
« Reply #15 on: November 24, 2015, 09:53 AM »
Useful tip @neeleman ! Ordered the Felder AF500 yesterday. Current price at the Felder eShop is € 209,– excluding VAT. Incl+s+h: € 270,07. Seems fair enough.
Question: how do you use it? Standing/hanging in a stationary position, or?
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline GarryMartin
« Reply #16 on: November 24, 2015, 10:28 AM »
The Felder AF500 looks like a number of other air filters. Is Felder the manufacturer or are a number of companies just "branding" a standard device, with wildly varying pricing?
Record Power AC400 - http://www.recordpower.co.uk/product/two-stage-air-filter-with-remote-3-speeds-and-time-delay
Rutlands - http://www.rutlands.co.uk/sp+woodworking-workshop-equipment-dust-collection-dust-extractors-vacuums-two-stage-air-filtration-system-with-remote-control+dk6680
Online neeleman
« Reply #17 on: November 24, 2015, 10:59 AM »
You're right about that.
It's sold as a Felder but in fact alas a rebranded PRC model.
I use it on a shelf but it can be hung from the ceiling as well.
At 16 kg you must be sure about the bolts in the ceiling.
You can also look at the video of another FOG member @dolph.
FESTOOL:
PROTOOL:
Offline jbasen
« Reply #19 on: November 24, 2015, 01:39 PM »
Dedicated air cleaners are obviously great but you can also do this on a budget with an inexpensive box fan and an auxiliary filter.  The box fan can also help to keep you cool in the summer
Check out:
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=box+fan+filter
Offline jobsworth
  • Festool Baby.....
« Reply #20 on: November 26, 2015, 04:31 AM »
I used  Jet Air Filter in my shop in the states and will use it when I get back.  What I like about it and should be mandatory on all these air filters is a timer. I run the filter when in the shop and set the timer to run a hour after I shut the shop up closing the door locking it tight.
Does this eliminate the fine dust? No I don't thing you can totally eliminate the fine airborne dust even with festools.
But it can cut it down quite a bit. Also make sure your filters are clean they have a inner and outer filter. If they get clogged then it makes it hard to filter the air.
Oh yea though a lot can not do this based on the configuration of the shop, its best to hang the filter from the ceiling and centre of the shop.
Offline GarryMartin
« Reply #21 on: November 26, 2015, 06:33 AM »
The Rutlands branded one is in their Black Friday sale TODAY (26/11/2015) at £119.95 incl VAT (£5.95 delivery) if anyone is interested. Extra £20 off the previous price.
