Author Topic: My Hobbyist Woodworking Shop  (Read 6532 times)
Offline squarecut
  • It Is What It Is
« on: April 25, 2016, 10:33 AM »
I finally got around to shooting a photo album of my woodworking shop that I have set up in my two bay garage. All shop fixtures have been built by myself. Some woodworkers choose to build their shop fixtures to almost furniture standard but I chose the utilitarian route when building these units. That process also served as a training exercise while I taught myself the various methodology of woodworking.
My shop album is posted on Flickr and can be viewed at this link - https://www.flickr.com/gp/139753597@N08/8kjPT3
Hope you enjoy viewing it. Comments & Questions are most welcome.
Largest private sawdust producer in Huntington NY
Offline ear3
Re: My Hobbyist Woodworking Shop
« Reply #1 on: April 25, 2016, 01:13 PM »
Fantastic setup, and a remarkably effective use of every square inch.  I like how you have the router bits set up in the drawers.
What is that box/jig you have the Festool router mounted on top of?
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • Planex Easy • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 36AC w/BT module • CT Sys w/Long-Life Bag • CT-VA 20 • MFT/3 • STM 1800
Offline #Tee
« Reply #2 on: April 25, 2016, 01:20 PM »
love it! how many years of collecting and setup?
When youre feeling depressed just treat yourself to a systainer even if its a mini systainer its ok.
IG: tee212
Offline squarecut
  • It Is What It Is
« Reply #3 on: April 25, 2016, 02:13 PM »
Edward, I assume you mean this unit. It is my router rest so that I can set the router down upright without waiting for the bit to stop. The last image shows the device used on one of my work surfaces where I have embedded t-track so I usually clamp it down.
(Don't know why image 3 is on it's side - do not know how to correct it - sorry!
« Last Edit: April 25, 2016, 02:21 PM by squarecut »
Offline squarecut
  • It Is What It Is
« Reply #4 on: April 25, 2016, 02:19 PM »
Started out in this hobby when I retired - going on 16 years now
Offline rvieceli
« Reply #5 on: April 25, 2016, 02:25 PM »
@squarecut Very nice set up and execution.
I have a question though, I see the big dust collector under the work surface. But I notice some smaller dust collection stuff going on behind the miter stand and the router table. Is there a shop vac sized unit hidden in there somewhere or does it tie back to the big collector.
thanks
Ron
Offline squarecut
  • It Is What It Is
« Reply #6 on: April 25, 2016, 02:32 PM »
thanks
Ron
Ron,
Each photo has a short description below it - you must have missed that on the sanding station, main bench, miter saw & router table. Your assumption is correct, those stations are connected to a Ridgid Shop Vac which is hidden behind the Festool systainers and controlled by the two start/stop stations & orange blast gates
Offline ear3
« Reply #7 on: April 26, 2016, 05:39 PM »
Got it.  I was thrown off by the hole in the back through which you insert the clamp/hold down.  I thought at first it might be some sort of dowel making jig.
I guess you must love the quick start/stop of the ETS-ECs then, since the pad stops spinning even before you have time to set the unit down.
