Author Topic: Retractable vac hose  (Read 3864 times)
Offline DynaGlide
« on: October 05, 2018, 01:30 PM »
I'm in the middle of sorting out how to hang my hose from the ceiling using bungee's and I came across this video. I thought it was pretty ingenious and I will likely be copying using a hose reel coupled to the vac hose.
Instagram @matts.garage
Offline RustE
Re: Retractable vac hose
« Reply #1 on: October 05, 2018, 04:28 PM »
I’d probably use some sort of retractor from Gear Keeper.  Might have to contact them about the length and weight you need.  Their website isn’t the easiest to navigate.
Offline Sparktrician
« Reply #2 on: October 06, 2018, 07:51 AM »
You might want to consider using a Unistrut trolley inside a length of Unistrut.
- Willy -
Offline jeffm13
« Reply #3 on: October 27, 2018, 10:27 AM »
Another option from Rockler:
https://www.rockler.com/rockler-promotions/current-promotions/ceiling-track-system
I'm hoping to install two tracks end-to-end in the next few days/weeks.
Festool: TS75, DF500, DF700, OF1400, LR32, ETS EC 150/5, DTS400, RS2E, T18, TXS, CT36, PS420, FS1400 (2), FS1400/2-LR 32, FS 2424/2-LR 32, Tradesman/Installer Cleaning Set; TSO: MTR-18, GRS-16 PE, TDS-10, TPG-20/30; UJK: Parf Dogs, Super Dogs, Parf Guide System MkII, Seneca: Parallel Guides, Domiplate, Domishim; Makita: 3000mm Guide Rail; Jessem: Mast-R-Lift w/metric conversion kit, Pow-R-Tec Router, Mast-R-Fence, Mit-R-Slide, ClearCut Stock Guides; Grizzly: G0441 Cyclone, G0691 Table Saw; Laguna: 18BX Bandsaw; Robland: X31 Combination Machine; Incra: MagnaLock Cleansweep; Woodpecker: 1281-300mm, 600mm T-Square, 1200mm Ruler, 1200mm Story Stick Pro; Bosch: GCM12SD Glide Miter Saw
