Makita battery tracker/Bluetooth
I've seen that there are a few people that's gotten their tools stolen Lately that may find this helpful and I'll bet you'ed love to catch the thieving BA.....DS! Even if you're not going to do this please share with as many Tradesmen as possible and it might put the thieves off stealing our tools even if a few people do it. we all know that the batteries a very expensive and tools no good without them.
Some of you may think this is a waste of time on 1 battery but its only about £30 and no monthly fee, and when you've spent as much on tools as me then it's nothing. As I've got a few broken Makita batteries why not. I work as a Kitchen fitter and alway have my tools on people's drives when I am doing worktops etc. I make sure to have this on one of my tools on the drive. Keep it with or on you most expensive tool. The battery lasts about 3 days with no use and a full charge.
1) Strip the 3Ah Makita battery and throw the inside away.
2) Strip the copy 1.5Ah battery and desolder the batteries as you need to glue the circuit board in place as it doesn't stick though the other side of the Makita case far enough.
3) Put the sim card in the tracker and keep the top up card safe as you'll need this to put money on at a Pay Point if your tools go missing. Record the date of expire on your phone calendar and you'll need to change the nut battery at this time. The sim cards are only a pound and you can get them with a year till the expiry date.
4) you'll need to cut the sheath off the cable and notch the plastic so the wires come out the side.
5) In the Makita base, you'll need to cut the plastic lumps that go in between the batteries.
6) Pair the Nut with your phone and use Playdoh the same thickness as the Nut. don't put too much in as this can arc the batteries.
7) Lay the batterie back over the circuit board that you glued in and resolder. (make sure you get the wires the right way round.)
Reinstall the base cover.
9) put £10 on for your first month so you now how to work it after that replace the sim card with a new one.
Love to here your feedback and if you'll do it?
Regards
Graham
