Congrats on your new house & shop. Very nice building, your floor seems to be in good shape. Any plan on epoxy? If so do it first while it's empty
![Big Grin [big grin]](https://www.festoolownersgroup.com/Smileys/default/biggrin.gif)
. I did my floor with the BM kit when their paints went 50% off, cost me $125CAD and did it myself. Not a professional job but I like it, no concrete dust to mix with the wood dust.
The existing wiring is bad, boxes with no connectors and fabric insulated wires. Everything is going away. I'll put in a sub panel that I saved from my previous shop (Siemens) since I have all the breakers I need and the existing panel (Square D) is pretty old. I'll have the electrician review the installation. I'm not sure if I need a local ground or not (Ontario).
I haven't decided what to do with the sink yet. It drains right outside the wall.
Electrical installation are always dependent of local regulations. Hard to tell but in Québec you do not need of a dedicated ground if your sub-panel do not have a main switch. If the panel have a main switch you
can put one to save the trouble to kick off your house main panel. I have a 200 amps main that feed my shop 100 amps. The Eaton 100 amp 20/40 package came with 12 breakers and just under $250CAD. The panel is almost full already with some twins breakers
Lightning: Get DEL.. my shop is 20x20 with 4 24"x24" DEL on each corners and a 12"x48" in the center, right over the table saw (no shadow). The DEL are expensive but really efficient, instant light with very large diffusion.
Post more pictures along with your changes.
P.S. Feed that dog
![Tongue Out [tongue]](https://www.festoolownersgroup.com/Smileys/default/tongue_smilie.gif)
