Author Topic: Alternatives to drywall for shop walls?  (Read 42343 times)
Offline ryanjg117
« on: May 13, 2018, 11:01 PM »
I'm looking to finish my 1,100 square foot detached workshop. Right now it is insulated just on the side walls, with otherwise open studs. I've got a quote of about $1,500 delivered for the 75 pieces of 12x4 foot drywall (1/2" for the walls and 5/8" lightweight for the ceilings, attaching to joists 24" OC) and mud/tape. That's with me (and a friend or two, I hope) doing all the heavy lifting.
Watching April Wilkerson's new shop build-out on YouTube and I noticed she used a pretty low grade plywood for the interior walls rather than drywall. I'm not a huge fan of cheap plywood as I've had to many unhappy projects built with it, but I do like the idea of being able to drive a screw and mount a tool anywhere in the shop. That said, I still think I'll be hunting for studs to mount the heavy stuff... And now that I'm thinking this through, I wonder if a studfinder would even work through plywood?
Maybe I just answered my own question here and I'll stick to drywall, with my own french cleat system I'll install later attaching to the studs.
But curious if there are any other good alternatives to drywall, which aren't terrifically more expensive?
Thanks!
Offline neilc
Re: Alternatives to drywall for shop walls?
« Reply #1 on: May 13, 2018, 11:40 PM »
I watched Aprils shop build as well.  It may look fine even with the lower grad ply after she paints it.  That's a big shop for her!
I built a 75x50 farm shop a couple of years ago and lined the interior with 16" on-center studs followed by 3/4" sanded plywood that I painted.  Sheeting was placed up to 7' high around the perimeter.   Definitely more expensive than drywall!
Now this is on a farm shop, so I was more concerned with durability where I would not be everyday with tenants in the building for storage and maintenance tasks.  But I'm glad I went with 1) a darker color on the wainscoting and 2) plywood for durability and flexibility on where I hang things.  I did choose to do the wiring and piping for air around the shop on the SURFACE of the finished walls to make it easy to either add new drops / outlets or easily repair.
In your case where it's a woodworking shop, you could go with drywall everywhere.  Or you could choose to go with ply on one wall.  Or go to a french cleat system for hanging things around the shop.  The advantage of drywall is it's cheap.  But with 24" on center studs, you may find you want more surface area for hanging things.  In my home shop, it's all drywall with studs on 16" center and it's served me well for 20 years.
I'd definitely insulate before siding as it will help with climate control and does not cost that much.  Should also help with sound attenuation if you are in a residential neighborhood with potential concern on noise.
As for finding studs, if you put the plywood up with a nail gun as I did, you won't have any problem finding a stud later on.  No need to fill the holes.  They give you plenty of evidence where the studs are.  But 24" OC with 1/2" drywall doesn't give you much flexibility on where you hang things.
I was in a retail store a few weeks back and they had the perimeter sided with baltic birch, but they drilled holes similar to an MFT top every 1' on a grid around the perimeter.  Very cool look and it gave them a lot of flexibility for shelving and racks.  So another idea for you that I thought was unique.  Unfortunately, I did not take photos.
Studs were actually built in sections and set in place behind the perlins before the exterior insulation and side walls were installed.
Once building was in place, interior sheeting was applied.  I painted the sections behind the posts before installation, then did the rest of the install and painted the rest.  I used an exterior grade paint / primer from HD and it's held up really well with 1 coat and a little touch up - all rolled on.
« Last Edit: May 13, 2018, 11:54 PM by neilc »
Offline Upscale
« Reply #2 on: May 14, 2018, 05:55 AM »
I'm so jealous to have a shop like you've got. It's big enough that you could build a small office and bedroom in a corner of it. If I had a shop like that, I'd be sleeping in it much of the time.  8)
Offline RobBob
« Reply #3 on: May 14, 2018, 08:28 AM »
How about T1-11 siding?
Offline JBag09
« Reply #4 on: May 14, 2018, 08:59 AM »
Wow! Very impressive. Looks like a great space and excellent building.
« Reply #5 on: May 14, 2018, 09:07 AM »
Hey @neilc , the extra stud wall with a plywood surface is a real nice solution to the metal building problem.  [thumbs up]   [thumbs up]
I used to rent motorcycle fabrication space in a building like that and the walls were pretty much off limits for anything. It was even tough to run some simple air lines on the walls. [eek]  Electrical cords were just laid on the floor and were always a trip hazard.
Offline sprior
« Reply #6 on: May 14, 2018, 11:37 AM »
It's only a basement shop, but I went with T1-11 on the walls and I'm very happy with it.  Not an issue for me, but since it's outdoor grade moisture won't be an issue.  And I LOVE the fact that I can mount things anywhere.  I also like the slightly rough surface because I think it hides defects - I have some things hung from angles dowels and if I want to move a tool it's no big deal to cut the old dowel flush and install a new one somewhere else.
Offline Sparktrician
« Reply #7 on: May 14, 2018, 12:32 PM »
I think I'd still go with a wood-based product over drywall, just because it resists impact better.  Half-inch plywood comes to mind.  A French cleat system over the plywood, then painted (plywood and cleats) will give tremendous flexibility in relocating cabinets in the future.  Just be sure to use consistent spacing between the cleats.  My cleat system design has cleats at 12" AFF, then every 18" thereafter (30", 48", 66" and 84" AFF).  So long as any cabinet has a minimum of two cleats, it can be hung at any height, so long as two movable cleats are in contact with two stationary cleats.  Taller cabinets get more cleats to better handle the load anticipated.  Base cabinets get Ikea Capita legs at the front for strength as well as to make cleaning under them much easier.
- Willy -
Offline Mario Turcot
« Reply #8 on: May 14, 2018, 01:22 PM »
I put 3/4 ply G2S all around my shop. Why G2S because it was cheaper then any 3/4 ply [eek]
As suggested by Sparktrician I have one strip of French cleat and will probably put more as the shop evolve.
I finally fix my clamps problem last weekend. No more moving left and right  [big grin]
Mario
« Reply #9 on: May 14, 2018, 03:34 PM »
Unfinished wood is great for a small shop as it helps mitigate swings in humidity. The more wood the better, but it wouldn’t make much difference in a huge shop like Ryan’s new building.
Offline tjbnwi
« Reply #10 on: May 14, 2018, 04:58 PM »
This is LP Smart panel, 3/8" thick.
Offline RustE
« Reply #11 on: May 14, 2018, 06:21 PM »
I have to ask, why did you use 3/4-inch (19mm) plywood?
My thought is 1/2-inch (12mm) plywood, the same as typical drywall.
Offline mwolczko
« Reply #12 on: May 14, 2018, 06:42 PM »
I recently redid a corner of the 2-car garage I use for my shop, and I used MDF slatwall, with aluminum inserts, covered in a maple finish. I got it from Home Depot.  It’s probably too expensive for a big space, but it looks great and is very practical. There are all kinds of doodads you can get to hang things from it. Check the load ratings before you commit.
« Reply #13 on: May 14, 2018, 07:27 PM »
The G1S 1/2 was 67$ and 3/4 was 79$. I found that 3/4 G2S for 45$ a piece, that was a no brainer. Chinese ply by the way with some voids but not more then any home depot ply. The walls are 9' so I push the sheets tight to the ceiling leaving a 12" down (look at the picture). If ever I have some water problem I can simply remove that part and not the whole thing.
« Last Edit: May 14, 2018, 07:31 PM by Mario Turcot »
Mario
« Reply #14 on: May 15, 2018, 07:37 AM »
Very smart, Mario!   [smile]
- Willy -
« Reply #15 on: May 15, 2018, 07:50 AM »
@rusty Sorry I haven't address your question. Why 3/4?
I feel I can hang anything anywhere with 3/4 ply. So far so good, I have some clamp racks (shown on the picture above) that weight around 150lbs and there is no visible flex.
I used poplar for the French cleats, also because it's the cheaper semi-hardwood I could find. I did cut a 6" board at 45 degree making it a two identical parts. I broke the sharp edge with the hand block plane and voila! I plan to add a French cleat at 24" from the ceiling with L brackets to hold long boards.
@Sparktrician Thank you, I have some good friends that ARE smart :D
Mario
« Reply #16 on: May 15, 2018, 11:02 AM »
I'll second that thought.
Offline Getmaverick
« Reply #17 on: May 15, 2018, 03:57 PM »
I just used OSB.
Offline Master Carpenter
« Reply #18 on: May 16, 2018, 09:07 AM »
I'm not a fan of plywood shop walls, they just dont have a clean, finished look. If you have a rough idea of what height you'd be hanging random things, you could put in a few rows of 2x blocking between the studs before drywall.
There are many types of wall anchors for drywall that will hold for light items. I wouldn't trust 1/2" plywood to hold heavy cabinets or shelves and would be screwing into studs for those items, so unless going up to 3/4" ply, I haven't seen much advantage to using 1/2" ply on shop walls.
And a tip if you do go drywall, get yourself a drywall lift. I put 4x12 drywall on my shop ceiling solo, and while slower than muscling it in, it's so much easier to position the sheets.
Offline jobsworth
  • Festool Baby.....
« Reply #19 on: May 18, 2018, 11:58 AM »
T1-11 is what Im going to use. I like it cuz its structural. You can nail things dirrctly to it (with in reason) wo  having to locate studs.
If you need it brighter just paint it white
Offline mobetta
« Reply #20 on: May 19, 2018, 08:52 AM »
If you do go with Drywall, I'd consider 5/8 everywhere.
the 1/2 lightwieght board is pretty soft. 5/8 will be more impact resistant.
 And on the chance you do need to use a wall anchor it will hold up better.
The 5/8b is rated for longer exposure to fire.
I dont mind a plywood wall. Painted OSB would almost be acceptable, though I am not a fan of the product.
the current price of ply in my area would steer me to drywall.
RO125  pro 5  DTS400
DF500  DF700  TSC55  HKC55  TS55
DWC-18 Planex CT36AC  CT36  CTMidi  Ctsys x2
Offline Alanbach
« Reply #21 on: May 19, 2018, 10:29 AM »
My alternative to drywall is patches of Baltic Birch plywood over Sheetrock as needed. My oversized two car garage (no longer a garage) shop was already sheetrocked, taped floated and painted white when we bought the house. Whenever I have something substantial to mount, I cut a piece of good plywood large enough to span more studs than I need. I rout the edges, sand, prime and paint to match the walls before mounting. It works great, looks fine and is inexpensive. Used in this manner one or two sheets will go a long way. I can do it spot by spot for specific items or I can cut long strips and mount them at a designated height to create a flexible mounting surface.
Offline SouthRider
« Reply #22 on: May 19, 2018, 07:11 PM »
We used 1/2 B/C plywood which is sanded on one side, screwed to 16" on center studs with 1 5/8 torx screws.
As mentioned above the screw lines show you where every stud is.
Can mount lighter items wherever you want, and bridge 2 studs with a cleat for heavier items. A French cleat system would work just fine if desired.
We didn't finish ours, but easily could have.
"We, the willing, led by the unknowing, are doing the impossible, for the ungrateful. We have done so much, for so long, with so little, that we are now qualified to do almost anything, with nothing at all."
Offline JimD
« Reply #23 on: May 19, 2018, 09:21 PM »
I used 7/16 OSB, the stuff sold for roofs, skim coated with joint compound and painted white.  A quick glance and you think it's wallboard.  But I can hang tools anywhere I want.  Moved my battery chargers just today.  Plenty of strength and cost pretty close to drywall.
The skim coating helps the appearance and saves paint.
Offline Kevin D.
« Reply #24 on: May 20, 2018, 10:48 AM »
I went with T1-11 as well for my shop.  I did sand the surface to get rid of the burr face before installing.  That way when I need to fill a hole I just use wood filler and it pretty well disappears.
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
Offline ERG
« Reply #25 on: July 18, 2018, 06:14 AM »
@JimD What did you use for the skim coat?
« Reply #26 on: July 18, 2018, 09:28 AM »
For art galleries they imstall plywood first to ho;d anchors and then cover that with drywall for appearance.
Offline JimD
« Reply #27 on: November 16, 2018, 08:05 PM »
I skimmed the OSB with joint compound.  I only did one coat so it isn't totally smooth.  But one coat filled in the holes well enough that it painted much better.  And joint compound is cheap.  I also filled in the joints between the sheets so they are less apparent too.  I don't think I used it but if you want more water resistance you could use setting compound.  It goes on as easily and dries much faster but you have to mess with mixing it with water.
Offline Scorpion
« Reply #28 on: December 30, 2018, 02:46 AM »
Interesting seeing so many looking to plywood for their shop walls.  Having been in the metal fab business for years, I’m hesitant to not have the most fire resistant walls possible.  Since plywood is fuel and provides zero fire retardant properties, and drywall is actually designed to retard fire...it seems to me like there’s only one good choice.
As for needing plywood so you can hang things anywhere - is this really a problem?  Any cabinet would still need to go into a stud (if you want to put anything heavy in it).  Use french cleats?  Work just fine spanning studs.  Is it a tool display wall thing?  Using April as the example - in her vids, what’s hanging on the wall that she couldn’t have hung via studs?
Offline RussellS
« Reply #29 on: December 30, 2018, 03:56 PM »
I did not know what T1-11 is.  So I used Google to look it up.  Its exterior house siding for those others who don't know.  But the funny part is both Home Depot and Lowes sell the 19/32" x 4' x 8' sheets for exactly $34.12.  Both the exact same price down to the penny.  Apparently Festool is not the only one who uses price fixing for its vendors.
Offline DeformedTree
« Reply #30 on: December 30, 2018, 04:34 PM »
HD, Lowes and Menards keep their prices identical(nearly identical) for basically everything they all carry. It's also not like there would be a reason for the prices on the same stuff to be any different.  Also with the case of HD and Lowes since they have return policies that allow you to return anything as long as they sold it at least once, it means no one will try playing an exchange game returning something they bought at lowes to a HD to come out 3 cents to the positive and such.  Also I just don't want to think about people cross shopping lumber, buying some at one, and other part of their needs at the other outside of a situation where the quality at one is junk that day.
Offline Farming_Sawyer
  • Sawyer, builder, winemaker, farmer, chef
    • Foley's Custom Sawmill
« Reply #31 on: December 30, 2018, 08:36 PM »
If you can find it at a lower price, my lowes will match the cost. But generally if I find things at a lower price I buy them from the store offering it to support and keep the prices low and quality higher then HD, lowes, etc.
CT 26E, RO125, sys-mft, sys-toolbox, a bunch of 30 year old tools I'm looking to replace.
Offline bruegf
  • Michigan
« Reply #32 on: December 31, 2018, 07:06 AM »
I built a 24x50 shop about 5 years ago and used 5/8 osb and then 1/2 drywall over that.  Drywall gives me some fire protection along with a nice finished look and the osb gives me the ability hang things anywhere I want.  Been very pleased with the way it worked out.
Fred
« Reply #33 on: December 31, 2018, 07:24 AM »
Rather than the expense of double layering the walls with plywood and sheetrock, why not just add a few rows of blocking in obvious places? When I frame a kitchen, or bathroom if I have the option I put in as much blocking as I can to catch cabinets, towel bars, etc. It makes life so much easier.....
Offline kevinculle
« Reply #34 on: December 31, 2018, 08:38 AM »
In my basement shop I used 1/2" MDF on the walls dividing the shop area from the mechanical equipment and storage area.
Offline Bob D.
  • Inactive Member
    • My Cordless Workshop
« Reply #35 on: December 31, 2018, 09:26 AM »
It is possible to buy plywood that is treated with fire retardant. In many places I have worked that is all that we were allowed to use for scaffolding or any temporary structures like ramps on construction sites. It cost more, way more, but if it's all you're allowed to use (which was our situation) it's what you buy.
It's out there you just wouldn't want it for home use based on cost is 3x that of regular plywood plus you usually have to order it, at least around here, and the minimum is a draft or full bundle (40 sheets of 3/4") so a lot of plywood and a couple thousand dollars. I think they were hitting us for something like $100/sheet for 3/4" but wasn't involved in the purchasing so not positive on the price.
« Last Edit: December 31, 2018, 09:36 AM by Bob D. »
Offline RussellS
« Reply #36 on: December 31, 2018, 01:45 PM »
Because maybe there will come a day when he wants to install something in a NOT obvious place.  You yourself say you put in as much blocking as I can.  Does that mean blocking 100% everywhere?  To catch cabinets and towel bars everywhere and anywhere.  The double layering just eliminates any future problems with installing anything anywhere.  Its not the easiest or cheapest method, but is the most foolproof.
Offline duburban
« Reply #37 on: January 01, 2019, 01:14 AM »
Agreed. Best blocking in kitchens etc. is full plywood.
helper: i used a festool "circular saw" to do something simple and it made it really hard
me: exactly, it makes simple cuts complicated and complicated cuts simple
« Reply #38 on: January 01, 2019, 01:58 AM »
There is always extreme options such as covering the walls in 2 bye material.  Room covered in 2x12s is a room that isn't messing around, mount anything anywhere, plus can always take up axe throwing.
Slightly less extreme would be some sorta of profiled siding.  "car siding".  You can get it in pine, and it lays flat.
Slightly more extreme...Brick?  Good if you branch out to metal working/forge work.
Offline bruegf
  • Michigan
« Reply #39 on: January 01, 2019, 08:20 AM »
At the time I built the barn the cost of osb + drywall was only 2 or 3 bucks a sheet more than 5/8 plywood and cheaper than decent quality 3/4 plywood.  The small amount of extra cost was insignificant to the total cost of the barn.
Fred
Offline ryanjg117
« Reply #40 on: January 01, 2019, 11:45 PM »
Random update, but I went with drywall. Used 5/8" firecode for the ceiling as the trusses we're 24" OC to avoid sagging, and 1/2" on all walls. Insulated before drywalling and installed a little Cadet 240v dual-element wall heater fully understanding it wasn't going to make the shop comfortable but "bearable." Totally works for that intended purpose in our mild west coast winters.
Drywall was simply WAY cheaper than some of the other materials we've talked about here, the only really downside being how fragile it is, and the fact you have to find studs if you're mouting anything heavy. I still plan to wall-mount a few French cleat lengths and build some cabinets and tool hangers. Going to keep those cabinets lightweight and simple. Will take some pics when it's all done.
What's amazing is how much larger the shop feels when you get the drywall installed--white makes such a huge difference compared to the exposed studs and insulation. Also, gives me appreciation for the work of drywall pros. I enjoyed taping... Once you figure out how to use a curved trowel, things get a lot easier.
Onward to getting the 6" dust collection ductwork installed and copper fixed air lines... My project for the next three weekends.
Offline demographic
« Reply #41 on: January 02, 2019, 03:39 AM »
I've fitted out a few pubs over the years and in the toilet areas we often put plywood over the studs then plasterboard (drywall to you lot) over that.
Gives it the clean look but when some drunken headbanger has an argument with his girlfriend and punches the wall he only damages his fist.
Plus over the life of a pub they often want to attach quite a lot to the walls, hand dryers, sinks, sanitary product dispensors, condom machines and so on.
I've never seen a pub yet where the designer knew exactly where things go on the walls when the draw the plans up so it pays to just do the lot with ply before the plasterboard. That way everyone has a good fixing.
Plus it stops the rough arse plumbers from just braying a hole in the wall with a hammer for the waste pipes.
Finding studs isn't rocket science either, a magnet on a string finds the screws and you know the centres they are at so once you find one the rest are pretty easy.
Steel studding is even simpler.
Offline Kevin D.
« Reply #42 on: January 02, 2019, 12:13 PM »
I put the T-11 siding over my drywalled walls in my garage that I converted to a shop, but I also added an interconnected with my house's other smoke detection system a smoke detector in there as well just to be extra safe.
Part of the idea was with the dust collection system whereby I read that if you MAYBE sucked up some metal into your collection bin, a spark may start a slow smoldering fire that may go undetected for hours after one leaves the shop and is sleeping away upstairs.  The chances of this happening are frankly remote for many reasons that are arguably valid, but it really was cheap piece of mind for me to do such along with having a fire extinguisher, eye wash station, first aid kit, telephone, and a power outage emergency light in my shop for overall safety reasons.
The biggest risk of fire in a shop in my mind is leaving rags to dry that have had volatile finishes on them.  Those I just put outside on the grass or snow and lay some rocks on them for disposal the following day.
