Author Topic: 2 Systainer Deep Sysport ...  (Read 17833 times)
Offline mddharma
« on: April 06, 2017, 03:22 PM »
Has anyone built a sysport where each sliding shelf will hold two systainers deep?  Any thoughts on your experience or tips would be very much appreciated.
« Last Edit: April 06, 2017, 03:50 PM by mddharma »
Offline Richard/RMW
Re: 2 Systainer Deep Sysport ...
« Reply #1 on: April 06, 2017, 04:22 PM »
@mddharma  - there is a recent thread here.
RMW
Offline Jcwoodshop
« Reply #2 on: April 07, 2017, 08:59 PM »
Yes, completed mine several weeks ago. A great space saver for me, and aides in accessing my tools without much trouble. The way i arranged my systainers theres room for 14 systainers. The fact that I can move it about allows me to have access from all sides of the table top. The work top sits on the cabinet and held in place with wood blocks. I can easily remove it grab the leg set and go should I need to use the top on site. The slides are full extension, rated for the anticipated load and have been functioning fine. I had room for a couple of pull out drawers which hold extension cords, clamps tool boxes, etc. The overall work top height is slightly higher than the original MFT, however I prefer that for my style of work.
Offline mddharma
« Reply #3 on: April 08, 2017, 07:54 AM »
Very nice - I liked what you did in regards to placing labels on the drawers to know what is in each.  I was thinking of maybe making my stationary and using it for outfeed for the kapek when I get that.
« Last Edit: April 09, 2017, 06:17 PM by mddharma »
Offline RobBob
« Reply #4 on: April 08, 2017, 08:11 AM »
@Jcwoodshop Looks great.  Really like it.  Did you use 3/4" melamine?
« Last Edit: April 08, 2017, 08:33 AM by RobBob »
Offline mddharma
« Reply #5 on: April 08, 2017, 08:29 AM »
Just a question ... I am very new to the LR32 system (just bought the kit last week).  I have seen where the single drawer sysports have the holes but I am imagine that with the double wide I will have to drill more in the middle - is that correct?  How many columns of holes did you use?
Offline neilc
« Reply #6 on: April 08, 2017, 09:54 AM »
For side by side you may need to use shorter screws as the holes if drilled on both sides in 20mm ply will be thru.  You can get shorter 5mm screws and they work fine.
Offline Billedis
« Reply #7 on: April 08, 2017, 10:14 AM »
Do you have any plans for this unit?  Thanks for sharing.  Bill
Offline MrToolJunkie
« Reply #8 on: April 08, 2017, 06:08 PM »
This one looks great - awesome design and use of space. Would love to see plans if you have them. Also, what casters did you use?
Offline Vondawg
« Reply #9 on: April 09, 2017, 09:19 AM »
Jcwoodshop- yes what a great design!
Mddharma- I went much simpler...leftover qswo, case sitting on a shelf underneath, w/28" full ext. glides. Whole thing is heavy enough to not move easily but can be pulled forward to provide a ledge to set material on and front clamp and allows for small storage on top. Be sure to leave enough room between (top/bottom) for the latch to be left in unlocked position...on my two drawer side, if mine aren't locked the latch gets knocked off.
Offline Jcwoodshop
« Reply #10 on: April 09, 2017, 04:23 PM »
RobBob -
No ... I used 3/4" Birch Plywood sides, top, and bottom, 1/4" MDF back. Edge band with hot melt adhesive backed banding on exposed edges. My reason for choosing plywood was I wanted extra holding power for the slide screws. I used 6 screws for each slide into the cabinet walls and the same number into the draw sides. The slides are full extension with a 100# rating. (A little heads up: the ratings giving by the manufacturers I looked into were: 100# at 18" extension.) The drawers where made with 1/2" Poplar sides and back, 3/4 Poplar fronts, 1/2" plywood bottoms. I also ran a "divider" from side to side to add stiffness and extra bottom support. Drawer bottoms were routed, with 4 depressions, to capture the feet under the systainer boxes; that keeps them from moving around and also minimizes the height of the cabinet.
mddharma-
I left my LR32 in its box this time. I've used it before and love it, however for this build, to minimize clearance between systainer tops and tray bottoms, the slides were space to achieve minimum clearance. But your right about using additional slide support. I used 6 screws for each slide into the cabinet and 6 screws into each drawer side.
nelic-
If I had used a common wall for side by side systainers that would have been a concern.
Billedis-
Just hand sketches. I can pull together the overall dimension. Most dimensions were based on the size of the MFT and the number of systainers I needed to store, and an acceptable top height. I wanted a slightly higher work surface then my MFT so this arrangement suited my work habits and maximized storage ...  but I'll get them up on the board ASAP. Thanks for asking  ;)
ScotF-
Same as above as far as plans. The casters are from Lee Valley H-D Polyurethane Swivel Caster w/Brake 2" x 2-1/2" item #00K2121. I used 4 under each storage column for a total of 8 casters. Their rated at appx 90# each so that gave me plenty margin. They make it easy enough to move the cabinet around, and I rarely use the brakes, the weight of the cabinet keeps it in position ... and Thank you.
Vondawg-
Very nice!
Agree, you have to play with the spacing a little to be sure you can open the front most systainer lid, but there is room, especially with the 28" full extension slides. I've left all my green handles on but I'm playing with the idea of just taking off the handles on the rear systainers an storing them behind the box ... but for now I'm twisting handles to open the systainers :)
Thanks all for comments and interest ... I'll get dimensions up here ASAP
Offline mddharma
« Reply #11 on: April 09, 2017, 05:55 PM »
Wow ... thanks for all the people who have given tips and feedback.  As I will have side by side compartments and will be using 3/4 inch ply (19mm?). what is the shortest euro screw I should use?
Offline Jcwoodshop
« Reply #12 on: April 09, 2017, 06:10 PM »
md-
I've seen 5mm Euro screws that are 11.5mm long. They might fit just fine from both sides of the 19mm panel considering the thickness of the slide material. If need be just touch them against a grinding wheel.
Offline mddharma
« Reply #13 on: April 09, 2017, 06:16 PM »
 [big grin] Thanks again JCWoodshop.  I have found some that are 6.3 x 10.5 euro screws that some have said to use for 5mm holes.  Will the 6.3 work you think?
Offline Jcwoodshop
« Reply #14 on: April 09, 2017, 06:18 PM »
md- Check on line- http://www.quickscrews.com/catalog/euro-screws they have slightly larger dia 6.3mm x 10mm.
Offline GarryMartin
« Reply #15 on: April 09, 2017, 06:31 PM »
6.3mm is fine. You'll also see some at 6.0mm.
I use 10.5mm screws in the drawer slides in the centre panels of my 18mm units, and 13.5mm in the sides.
Offline mddharma
« Reply #16 on: April 09, 2017, 06:38 PM »
GaryMartin - Thanks!    [scared] I was getting nervous for the inside panels I would have to double up on the wood.  This has made my day!
Offline Billedis
« Reply #17 on: April 10, 2017, 11:16 AM »
Nice cabinet Gary Martin.  Thanks for sharing the pics.  Bill
Offline GarryMartin
« Reply #18 on: April 10, 2017, 11:49 AM »
Thanks @Billedis, it's part of a larger "system" of organisation I've been developing along one side of a single car garage. The drawer units are part of the Kapex station design.
Offline johnesher
« Reply #19 on: April 30, 2017, 10:20 PM »
...it's part of a larger "system" of organisation I've been developing along one side of a single car garage. The drawer units are part of the Kapex station design...
Gary,
How did you do the cutouts for the hand holds? I currently have some stand off handles on my miter saw station, but I'm getting tired of hooking my self on the end.
Offline ben_r_
« Reply #20 on: May 10, 2017, 05:40 PM »
RobBob -
How did you get the light grey coloring on the sides of the plywood sheets? Is that just paint or did you laminate them with Formica or something similar?
Offline GarryMartin
« Reply #21 on: May 11, 2017, 06:28 AM »
Sorry @johnesher I missed your question for some reason.
The hand holds are cut using a router bit I purchased from Wealden Tools in the UK. It's a good size to work with 18mm material. Here it's shown side by side with the Festool cutter which was used for the upper cupboards with 22mm material.
And this is the profile it creates on 18mm material.
I use a jig and the MFS to position the drawer fronts, then the cutter with a copy ring on the OF 1010 to cut them.
On the latest set of drawers, I changed the handle position for the lower drawer to the top of the cabinet; I found reaching down to almost ground level on the previous drawers was not optimal. I'll go back and change those at some point.
Offline grbmds
« Reply #22 on: June 20, 2017, 08:33 PM »
@Jcwoodshop Referencing your April post about your 2 drawer deep systainer, when you said you could access the drawers from all sides I assume you meant 3 sides; the front and each side. Correct?
Randy
Offline Bob D.
  • Inactive Member
    • My Cordless Workshop
« Reply #23 on: June 20, 2017, 10:53 PM »
That makes for a nice, clean look on the drawer fronts Garry, I like it.
