Need a little help here from the motor guys or electricians.
I have a jointer/planer with a 1-1/2hp, single phase, 115V Dayton motor on a 20A circuit. When I first start the machine, it trips the breaker. This is a 100A Square D panel and the only other thing running in the shop is lighting on a separate circuit. In other words, there is no other load in the shop at the time. I am using a 10 foot, 12 gauge extension cord. The wiring on all circuits is correct. It is on a GFCI outlet but the GFCI does not trip. After resetting the breaker at the time, the motor starts up without an issue. After it's been running, if I turn off the machine and then start it again within five to ten minutes, it starts up without tripping the breaker. If however, it's longer, say 20 minutes since it last ran, and I start it again, it trips. I have tried it on another similar 20A circuit and the same thing happens. These are new breakers. The motor is approximately twelve years old but only used in a hobby shop.
Does this likely indicate I have a bad motor capacitor?
Thanks for any help.
