Author Topic: Table extension slide recommendations?  (Read 800 times)
Offline ear3
« on: February 24, 2020, 04:21 PM »
I've taken on a commission to build a large extending dining room table -- and after initially saying that they had the hardware situation under control, and that I would just have to install the model they selected, the designers are now not quite as certain whether the slides they were recommending are going to work with a table as heavy as we are constructing.
So I'm wondering if anyone might have recommendations for heavy-duty table extension slides?  They have to be super robust and have a 36" capacity, which is the maximum size of the inserts that will be going in.
Offline Wooden Skye
Re: Table extension slide recommendations?
« Reply #1 on: February 24, 2020, 06:36 PM »
I'm not sure of any hardware specifically, but King Post Timberworks on YT recently did a large table that needed to be extended and built slides himself.  May be worth a look.
Bryan
TS 55, (2) 1400 Guide Rails, 1900 Guide Rail, MFT/3, Domino DF 500, 2 domino systainers, ETS 150/3, RO 90, CT 26, (2) OF1400, RO 150. RTS 400, LR 32 set, PS300 jigsaw, 3 abrasive systainers, (2) sys toolbox, (2) sys mini, clamps and other accesories
Offline Rob Lee
  • Festool Dealer
    • Lee Valley/Veritas
« Reply #2 on: February 25, 2020, 07:41 AM »
Hi -
We have a couple of slides that might fit your need....
These German ones:
German slides
Or these Heavy duty full extension slides, which you might be able to integrate into your design:
https://www.leevalley.com/en-us/shop/hardware/slides/side-mount/50505-extra-heavy-duty-slides
Cheers -
Rob
