Doing a favor for a friend, whereby I will be installing aluminum angle stock along the outer edges of an entryway to protect it.
My question is about the proper adhesive, since they don't want it to be screwed in. I figured that I could use a quick curing metal epoxy, something like
this to facilitate a lasting bond? If this is a good product, I was also thinking of mixing in at a few select points along the stock some faster acting CA glue for metal like
this, which would achieve a quick bond (particularly for the vertical piece) and allow the epoxy time to cure.
Does this sound like a good plan, or should I be looking instead at some kind of thicker, tube dispensed adhesive that will have more immediate tack?
