Author Topic: Is there a way to fix a warped door?  (Read 2850 times)
Offline Alex
Re: Is there a way to fix a warped door?
« Reply #30 on: February 19, 2021, 10:11 AM »
Packard, it is a solid panel door, but with a layer of veneer glued on. Pictures are above. Turned out the door is not as badly warped as I first thought, but most of the problem is in the door jamb. I scribed the jamb to the door and cut a thin stripe away so the door sits flush again.
