« Reply #6 on: July 21, 2022, 03:51 AM »
You can (in practice) install a 3.2mm blade in the TKS 80.
It should be a plain steel blade, not a teflon coated one like the red Freud/Diablo types. It needs to be conductive.
I use Festool, CMT and Freud industrial blades in mine. The TKS will confirm the blade conductivity by flashing the red light rapidly while stopped, if you touch the blade.
Keep in mind your fence index would need to be calibrated appropriately if this was a permanent shift.
TKS 80 EBS-SET, KS 60 E-Set, TSC 55 REBI, TS 75, HKC 55,
DF 500 & DF 700, OF2020, OF1010 REBQ, OF1010 EBQ, OFK 500,
T18+3, C18, PDC 18/4, TID 18,
RO 150, RO 90, RAS 115, RTS 400, ETS 125, ETS 150/5,
EHL 65, HL 850 EB,
CTL 26 E, CTL MIDI I, CTL-SYS, CT-VA-20
VAC SYS w/ SE1 & SE2, MFT/3, SYS PowerHub, DUO SYSLITE, & KAL.
